#!/usr/bin/python
import serial
import time
import sys
import getopt
from Adafruit_BMP085 import BMP085
# Example Code
# Initialise the BMP085 and use STANDARD mode (default value)
# bmp = BMP085(0x77, debug=True)
bmp = BMP085(0x77)
# To specify a different operating mode, uncomment one of the following:
# bmp = BMP085(0x77, 0) # ULTRALOWPOWER Mode
# bmp = BMP085(0x77, 1) # STANDARD Mode
# bmp = BMP085(0x77, 2) # HIRES Mode
# bmp = BMP085(0x77, 3) # ULTRAHIRES Mode
temp = bmp.readTemperature()
pressure = bmp.readPressure()
altitude = bmp.readAltitude()
print "Temperature: %.2f C" % temp
print "Pressure: %.2f hPa" % (pressure / 100.0)
print "Altitude: %.2f" % altitude
try:
opts, args = getopt.getopt(sys.argv[1:], "x:y:s:b")
except getopt.GetoptError, err:
# print help information and exit:
print str(err) # will print something like "option -a not recognized"
sys.exit(2)
x=0
y=0
s=""
clear = False
for o, a in opts:
if o == "-x":
x = a
elif o == "-y":
y = a
elif o == "-s":
s = a
elif o == "-b":
clear = True
else:
assert False, "Unhandled option"
# Open the serial port on J16
ser = serial.Serial(
port='/dev/ttyUSB0',
baudrate=115200,
timeout=1,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.EIGHTBITS
ser.write("U") # Autobaud char
rtc = ser.read(1) # Wait for a reply
if clear==True:
ser.write("E") # Clear screen
ser.write("s%c%c%c%c%c%s%c" % (int(x),int(y),1,0xFF,0xFF,s,0x00))
time.sleep(30)
ser.close() # Close Port
Wie bekomme ich die werte vom BMP085 auf das Display?
Sorry ich bin noch neu auf der python Ebene:s
