The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Nov 6 12:14:08 2017 from huawei-p9.fritz.box
pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.58+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1046 Tue Oct 24 16:57:45 BST 2017
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Model B Plus Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x1b400000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
[ 0.000000] Normal zone: 1008 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)[ 0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xdc800000 - 0xff800000 ( 560 MB)
lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05d7b08 (5951 kB)
.init : 0xc0841000 - 0xc08a4000 ( 396 kB)
.data : 0xc08a4000 - 0xc091ef48 ( 492 kB)
.bss : 0xc091ef48 - 0xc09d4648 ( 726 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000032] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000079] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000181] bcm2835: system timer (irq = 27)
[ 0.000650] Console: colour dummy device 80x30
[ 0.001389] console [tty1] enabled
[ 0.001447] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060365] pid_max: default: 32768 minimum: 301
[ 0.060834] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060904] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.062199] Disabling memory control group subsystem
[ 0.062411] CPU: Testing write buffer coherency: ok
[ 0.062512] ftrace: allocating 21715 entries in 64 pages
[ 0.179999] Setting up static identity map for 0x8200 - 0x8238
[ 0.182079] devtmpfs: initialized
[ 0.191690] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.192226] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.192325] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.193644] pinctrl core: initialized pinctrl subsystem
[ 0.195163] NET: Registered protocol family 16
[ 0.197617] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.207715] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.207809] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.207953] Serial: AMBA PL011 UART driver
[ 0.210963] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.261962] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[ 0.264772] SCSI subsystem initialized
[ 0.265108] usbcore: registered new interface driver usbfs
[ 0.265284] usbcore: registered new interface driver hub
[ 0.265528] usbcore: registered new device driver usb
[ 0.270061] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
[ 0.272014] clocksource: Switched to clocksource timer
[ 0.327490] VFS: Disk quotas dquot_6.6.0
[ 0.327689] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.328053] FS-Cache: Loaded
[ 0.328452] CacheFiles: Loaded
[ 0.348215] NET: Registered protocol family 2
[ 0.349635] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.349794] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.349925] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.350061] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.350128] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.350488] NET: Registered protocol family 1
[ 0.351295] RPC: Registered named UNIX socket transport module.
[ 0.351371] RPC: Registered udp transport module.
[ 0.351411] RPC: Registered tcp transport module.
[ 0.351447] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.352681] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.355190] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.376062] FS-Cache: Netfs 'nfs' registered for caching
[ 0.377925] NFS: Registering the id_resolver key type
[ 0.378039] Key type id_resolver registered
[ 0.378081] Key type id_legacy registered
[ 0.382694] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.383163] io scheduler noop registered
[ 0.383229] io scheduler deadline registered (default)
[ 0.383742] io scheduler cfq registered
[ 0.389842] BCM2708FB: allocated DMA memory 5b500000
[ 0.389973] BCM2708FB: allocated DMA channel 0 @ dc80d000
[ 0.398267] Console: switching to colour frame buffer device 82x26
[ 0.408482] bcm2835-rng 20104000.rng: hwrng registered
[ 0.411305] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.417742] vc-sm: Videocore shared memory driver
[ 0.445668] brd: module loaded
[ 0.461272] loop: module loaded
[ 0.464180] Loading iSCSI transport class v2.0-870.
[ 0.467804] usbcore: registered new interface driver smsc95xx
[ 0.470544] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.701631] Core Release: 2.80a
[ 0.704384] Setting default values for core params
[ 0.707020] Finished setting default values for core params
[ 0.910038] Using Buffer DMA mode
[ 0.912746] Periodic Transfer Interrupt Enhancement - disabled
[ 0.915366] Multiprocessor Interrupt Enhancement - disabled
[ 0.917975] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.920662] Dedicated Tx FIFOs mode
[ 0.923983] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[ 0.929522] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.942600] dwc_otg: Microframe scheduler enabled
[ 0.942734] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451738
[ 0.945380] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451a14 length 36
[ 0.948027] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
[ 0.950719] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.953477] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.956285] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.958902] Init: Port Power? op_state=1
[ 0.961440] Init: Power Port (0)
[ 0.964391] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.967078] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.969698] usb usb1: Product: DWC OTG Controller
[ 0.972325] usb usb1: Manufacturer: Linux 4.9.58+ dwc_otg_hcd
[ 0.974890] usb usb1: SerialNumber: 20980000.usb
[ 0.978614] hub 1-0:1.0: USB hub found
[ 0.981251] hub 1-0:1.0: 1 port detected
[ 0.984693] dwc_otg: FIQ enabled
[ 0.984704] dwc_otg: NAK holdoff enabled
[ 0.984710] dwc_otg: FIQ split-transaction FSM enabled
[ 0.984731] Module dwc_common_port init
[ 0.985240] usbcore: registered new interface driver usb-storage
[ 0.988253] mousedev: PS/2 mouse device common for all mice
[ 0.992495] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer[ 0.995644] bcm2835-cpufreq: min=700000 max=700000
[ 0.998911] sdhci: Secure Digital Host Controller Interface driver
[ 1.001599] sdhci: Copyright(c) Pierre Ossman
[ 1.004733] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[ 1.007819] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.011310] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.014432] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.017503] usbcore: registered new interface driver usbhid
[ 1.020281] usbhid: USB HID core driver
[ 1.024416] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0[ 1.029214] [vc_sm_connected_init]: start
[ 1.039655] [vc_sm_connected_init]: end - returning 0
[ 1.043155] Initializing XFRM netlink socket
[ 1.045981] NET: Registered protocol family 17
[ 1.048884] Key type dns_resolver registered
[ 1.053412] registered taskstats version 1
[ 1.063559] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.066690] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.891620] console [ttyAMA0] enabled
[ 1.900642] sdhost: log_buf @ db513000 (5b513000)
[ 1.982098] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.990610] of_cfs_init
[ 2.016091] of_cfs_init: OK
[ 2.022602] Waiting for root device /dev/mmcblk0p2...
[ 2.032412] Indeed it is in host mode hprt0 = 00021501
[ 2.042060] random: fast init done
[ 2.159866] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.175661] mmc0: new high speed SDHC card at address b368
[ 2.185290] mmcblk0: mmc0:b368 USD 7.46 GiB
[ 2.194763] mmcblk0: p1 p2
[ 2.252114] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.261668] Indeed it is in host mode hprt0 = 00001101
[ 2.333038] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.343465] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.492587] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.502429] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.513962] hub 1-1:1.0: USB hub found
[ 2.520847] hub 1-1:1.0: 5 ports detected
[ 2.611573] EXT4-fs (mmcblk0p2): recovery complete
[ 2.634742] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.648663] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.661976] devtmpfs: mounted
[ 2.669426] Freeing unused kernel memory: 396K
[ 2.677011] This architecture does not have kernel memory protection.
[ 2.842141] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.982862] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00[ 2.992955] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.007538] smsc95xx v1.0.5
[ 3.053186] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 3.076978] systemd[1]: Detected architecture 'arm'.
[ 3.118576] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c8:0f:69
[ 3.267621] NET: Registered protocol family 10
[ 3.277628] systemd[1]: Inserted module 'ipv6'
[ 3.288290] systemd[1]: Set hostname to <raspberrypi>.
[ 3.461947] uart-pl011 20201000.serial: no DMA platform data
[ 4.233053] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.247811] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.262142] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 4.275758] systemd[1]: Starting Remote File Systems (Pre).
[ 4.288945] systemd[1]: Reached target Remote File Systems (Pre).
[ 4.298732] systemd[1]: Starting Encrypted Volumes.
[ 4.569466] fuse init (API version 7.26)
[ 4.599698] i2c /dev entries driver
[ 6.030536] systemd-udevd[120]: starting version 215
[ 8.172677] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.292238] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 11.084971] systemd-journald[118]: Received request to flush runtime journal from PID 1
[ 22.722895] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 25.199148] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[ 30.564308] random: crng init done
[ 93.206549] Bluetooth: Core ver 2.22
[ 93.206757] NET: Registered protocol family 31
[ 93.206768] Bluetooth: HCI device and connection manager initialized
[ 93.206798] Bluetooth: HCI socket layer initialized
[ 93.206819] Bluetooth: L2CAP socket layer initialized
[ 93.206883] Bluetooth: SCO socket layer initialized
[ 93.334346] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 93.334362] Bluetooth: BNEP filters: protocol multicast
[ 93.334399] Bluetooth: BNEP socket layer initialized
pi@raspberrypi:~ $
