Hat sich erledigt, lag an einer veralteten Serverversion!
#closed
#closed
Hallo forum, ich war gerade dabei, LAMP zu installieren und MySQL macht probleme.
Errors were encountered while processing:
mysql-server-5.5
mysql-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
Diese Fehlermeldung habe ich bekommen. Was soll ich jetzt tun?
Wnn jemand den genauen Installationsablauf braucht und versteht, der kommt jetzt.
An dieser Stelle schonmal für eure Hilfe!
MfG JalicX
root@vps:~# apt-get install mysql-server php5-mysql
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
heirloom-mailx libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl libmysqlclient18 mysql-client-5.5
mysql-common mysql-server-5.5 mysql-server-core-5.5
Suggested packages:
exim4 mail-transport-agent libipc-sharedcache-perl libterm-readkey-perl tinyca
Recommended packages:
mailx
The following NEW packages will be installed:
mysql-common mysql-server mysql-server-5.5 mysql-server-core-5.5 php5-mysql
0 upgraded, 12 newly installed, 0 to remove and 0 not upgraded.
Need to get 9664 kB of archives.
After this operation, 97.8 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://ftp.debian.org/debian/ wheezy/main libaio1 amd64 0.3.109-3 [9150 B]
Get:2 http://ftp.debian.org/debian/ wheezy/main libdbi-perl amd64 1.622-1+deb7u1 [892 kB]
Get:3 http://ftp.debian.org/debian/ wheezy/main libdbd-mysql-perl amd64 4.021-1+b1 [126 kB]
Get:4 http://ftp.debian.org/debian/ wheezy/main heirloom-mailx amd64 12.5-2 [274 kB]
Get:5 http://security.debian.org/ wheezy/updates/main mysql-common all 5.5.40-0+wheezy1 [75.5 kB]
Get:6 http://ftp.debian.org/debian/ wheezy/main libhtml-template-perl all 2.91-1 [72.0 kB]
Get:7 http://security.debian.org/ wheezy/updates/main libmysqlclient18 amd64 5.5.40-0+wheezy1 [678 kB]
Get:8 http://security.debian.org/ wheezy/updates/main mysql-client-5.5 amd64 5.5.40-0+wheezy1 [1890 kB]
Get:9 http://security.debian.org/ wheezy/updates/main mysql-server-core-5.5 amd64 5.5.40-0+wheezy1 [3401 kB]
Get:10 http://security.debian.org/ wheezy/updates/main mysql-server-5.5 amd64 5.5.40-0+wheezy1 [2093 kB]
Get:11 http://security.debian.org/ wheezy/updates/main php5-mysql amd64 5.4.35-0+deb7u2 [80.8 kB]
Get:12 http://security.debian.org/ wheezy/updates/main mysql-server all 5.5.40-0+wheezy1 [73.9 kB]
Fetched 9664 kB in 5s (1753 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libaio1:amd64.
(Reading database ... 13964 files and directories currently installed.)
Unpacking libaio1:amd64 (from .../libaio1_0.3.109-3_amd64.deb) ...
Selecting previously unselected package mysql-common.
Unpacking mysql-common (from .../mysql-common_5.5.40-0+wheezy1_all.deb) ...
Selecting previously unselected package libmysqlclient18:amd64.
Unpacking libmysqlclient18:amd64 (from .../libmysqlclient18_5.5.40-0+wheezy1_amd64.deb) ...
Selecting previously unselected package libdbi-perl.
Unpacking libdbi-perl (from .../libdbi-perl_1.622-1+deb7u1_amd64.deb) ...
Selecting previously unselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from .../libdbd-mysql-perl_4.021-1+b1_amd64.deb) ...
Selecting previously unselected package mysql-client-5.5.
Unpacking mysql-client-5.5 (from .../mysql-client-5.5_5.5.40-0+wheezy1_amd64.deb) ...
Selecting previously unselected package mysql-server-core-5.5.
Unpacking mysql-server-core-5.5 (from .../mysql-server-core-5.5_5.5.40-0+wheezy1_amd64.deb) ...
Setting up mysql-common (5.5.40-0+wheezy1) ...
Selecting previously unselected package mysql-server-5.5.
(Reading database ... 14314 files and directories currently installed.)
Unpacking mysql-server-5.5 (from .../mysql-server-5.5_5.5.40-0+wheezy1_amd64.deb) ...
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
debconf: falling back to frontend: Readline
Configuring mysql-server-5.5
While not mandatory, it is highly recommended that you set a password for the MySQL administrative "root" user.
If this field is left blank, the password will not be changed.
New password for the MySQL "root" user:
Repeat password for the MySQL "root" user:
Selecting previously unselected package php5-mysql.
Unpacking php5-mysql (from .../php5-mysql_5.4.35-0+deb7u2_amd64.deb) ...
Selecting previously unselected package heirloom-mailx.
Unpacking heirloom-mailx (from .../heirloom-mailx_12.5-2_amd64.deb) ...
Selecting previously unselected package libhtml-template-perl.
Unpacking libhtml-template-perl (from .../libhtml-template-perl_2.91-1_all.deb) ...
Selecting previously unselected package mysql-server.
Unpacking mysql-server (from .../mysql-server_5.5.40-0+wheezy1_all.deb) ...
Processing triggers for libapache2-mod-php5 ...
[ ok ] Reloading web server config: apache2.
Setting up libaio1:amd64 (0.3.109-3) ...
Setting up libmysqlclient18:amd64 (5.5.40-0+wheezy1) ...
Setting up libdbi-perl (1.622-1+deb7u1) ...
Setting up libdbd-mysql-perl (4.021-1+b1) ...
Setting up mysql-client-5.5 (5.5.40-0+wheezy1) ...
Setting up mysql-server-core-5.5 (5.5.40-0+wheezy1) ...
Setting up mysql-server-5.5 (5.5.40-0+wheezy1) ...
[ ok ] Stopping MySQL database server: mysqld.
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 146: logger: command not found
ATTENTION: An error has occured. More info is in the syslog!
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 236: logger: command not found
dpkg: error processing mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 127
Setting up php5-mysql (5.4.35-0+deb7u2) ...
Creating config file /etc/php5/mods-available/mysql.ini with new version
Creating config file /etc/php5/mods-available/mysqli.ini with new version
Creating config file /etc/php5/mods-available/pdo_mysql.ini with new version
Setting up heirloom-mailx (12.5-2) ...
update-alternatives: using /usr/bin/heirloom-mailx to provide /usr/bin/mailx (mailx) in auto mode
Setting up libhtml-template-perl (2.91-1) ...
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
dependency problems - leaving unconfigured
mysql-server-5.5
mysql-server
root@vps:~#
Alles anzeigen
Danke. Ich weiß zwar nicht warum, aber es scheint zu funktionieren
Liebe Grüße
JalicX
Hallo alle zusammen,
ich bekomme die history nicht mit history -c gelöscht!
Also an sich funktioniert es, wenn ich PuTTY neustarte, wird sie jedoch wieder anzezeigt.
Was soll ich tun?
Mit freundlichen Grüßen
JalicX
Info: Irgendwie kann ich debian grade nicht als Präfix auswählen,
Ich änder dass dann später.
Ja, ok, ich bin ne Flasche, ich gebs ja zu
Der witz war, letztendlich wars doch nicht ganz meine Schuld:
youtube-upload --email=zensiert@gmail.com --password=zensiert --title="Titel1" --description="Beschreibung1" --category=Entertainment --keywords="Bla" --unlisted /media/usb/v1.mp4
Mal so am Rande: Ich habe meinen Stick via
gemounted.
Wo ist also der Fehler? Nicht im Code!
Wie dieser User bemerkt hat, sollte man diese Einstellung ändern, sonst kanns nicht klappen!
Ich hab es ohne den Ordner youtube-uploads zu löschen einfach nochmal via
hochgeladen.
Sollte nachmal jemand so ein Projekt planen folgende Tipps:
- les dir den eigentlichen Thread durch
- Diese Diskussion, insbesondere Kommentar #14
- Diese Anleitung aus dem letsplayforum hat mir auch geholfen, jedoch hat der Install Befehl
bei mir NICHT funktioniert, deshalb würde ich den
wobei VERSION durch die aktuelle Version, aktuell 0.7.3 zu ersetzen ist. (siehe 1. Tipp)
Wer diese Tipps beachtet und ein wenig Ahnung von der Materie hat, krigt das Skript so innerhalb von < 20 Minuten ans Laufen!
Ein fettes nochmal an alle, die mir geholfen haben, insbesondere joh.raspi. Lief ja schon mit Hilfe nich so besonders, wie hätte es ohne ausgesehen?
Liebe Grüße
JalicX
Kann mir keiner sagen, wie ich den driss wieder los werde??
pi@RaspberryPi ~/youtube-upload/youtube_upload $ python youtube_upload.py –get-categories
Usage: youtube_upload.py [OPTIONS] VIDEO_PATH ...
Upload videos to youtube.
[OptionsMissing] Some required option are missing: email, title, category
Oh Gott danke für die tolle Hilfe.
War gerade echt am verzweifeln. Linux ist ja um es vorsichtig auszudrücken was besonderes. Aber toll, dass es Leute wie euch hier im Forum gibt, die so schnell helfen.
Danke,
JalicX
______________________________________________
EDIT
Haha, zu früh gefreut. ich bekomme immer eine bad authentification - meldung. Login und Passwort hab ich mehrmals überprüft. Kann ich jetzt einfach den Installationsordner löschen und es nochmal versuchen mit einer kompletten Neuinstallation oder msss ich da noch etwas anderes beachten? Die Anleitung ist übrigens an einigen stellen fehlerhaft.
Danke, JalicX
Vielleicht ist auch einfach der command ungültig. Ich bin jetzt mal den Pfad gefolgt.
pi@RaspberryPi ~ $ dir
Desktop Downloads ocr_pi.png python_games youtube-upload
pi@RaspberryPi ~ $ cd youtube-upload
pi@RaspberryPi ~/youtube-upload $ dir
bin build CHANGELOG examples README setup.py youtube_upload
pi@RaspberryPi ~/youtube-upload $ cd youtube_upload
pi@RaspberryPi ~/youtube-upload/youtube_upload $ dir
__init__.py __init__.pyc youtube_upload.py youtube_upload.pyc
pi@RaspberryPi ~/youtube-upload/youtube_upload $ youtube_upload.py –get-categories
-bash: youtube_upload.py: Kommando nicht gefunden.
demnach liegt im stammverzeichnis der ordner youtube-upload/youtube_upload/youtube_upload.py
aber was sind dann die .pyc? definitiv funkrioniert irgendwas nicht
Danke JalicX
Ich habe nun das skript nach dieser Anleitung installiert und leider geht es nicht. folgendes habe ich gemacht :
pi@RaspberryPi ~ $ sudo apt-get -y install python python-gdata python-progressbar python-pycurl Paketlisten werden gelesen... Fertig
python ist schon die neueste Version.
Vorgeschlagene Pakete:
python-gdata-doc libcurl4-gnutls-dev python-pycurl-dbg
Die folgenden NEUEN Pakete werden installiert:
0 aktualisiert, 3 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 609 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 3.519 kB Plattenplatz zusätzlich benutzt.
Holen: 1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-progres
Holen: 2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-pycurl
Holen: 3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-gdata a
Es wurden 609 kB in 11 s geholt (50,8 kB/s).
Vormals nicht ausgewähltes Paket python-progressbar wird gewählt.
(Lese Datenbank ... 73325 Dateien und Verzeichnisse sind derzeit installiert.)
Entpacken von python-progressbar (aus .../python-progressbar_2.2-2_all.deb) ...
Vormals nicht ausgewähltes Paket python-pycurl wird gewählt.
Entpacken von python-pycurl (aus .../python-pycurl_7.19.0-5_armhf.deb) ...
Vormals nicht ausgewähltes Paket python-gdata wird gewählt.
Entpacken von python-gdata (aus .../python-gdata_2.0.17+dfsg-1_all.deb) ...
python-progressbar (2.2-2) wird eingerichtet ...
python-pycurl (7.19.0-5) wird eingerichtet ...
python-gdata (2.0.17+dfsg-1) wird eingerichtet ...
Trigger für python-support werden verarbeitet ...
pi@RaspberryPi ~ $ wget https://youtube-upload.googlecode.com/files/youtube-upload-0.7.3.tgz
--2014-11-16 16:26:09-- https://youtube-upload.googlecode.com/files/youtube-upload-0.7.3.tgz
Auflösen des Hostnamen »youtube-upload.googlecode.com (youtube-upload.googlecode.com)«... 173.194.65.82, 2a00:1450: 4013:c00::52
Verbindungsaufbau zu youtube-upload.googlecode.com (youtube-upload.googlecode.com)|173.194.65.82|:443... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 11312 (11K) [application/x-gzip]
In »»youtube-upload-0.7.3.tgz«« speichern.
100%[=========================================================================>] 11.312 --.-K/s in 0,06s
2014-11-16 16:26:15 (175 KB/s) - »»youtube-upload-0.7.3.tgz«« gespeichert [11312/11312]
pi@RaspberryPi ~ $ tar xfvz youtube-upload-*.tgz
youtube-upload-0.7.3/
youtube-upload-0.7.3/README
youtube-upload-0.7.3/CHANGELOG
youtube-upload-0.7.3/youtube_upload/
youtube-upload-0.7.3/youtube_upload/__init__.py
youtube-upload-0.7.3/youtube_upload/youtube_upload.py
youtube-upload-0.7.3/setup.py
youtube-upload-0.7.3/examples/
youtube-upload-0.7.3/examples/upload_with_curl.sh
youtube-upload-0.7.3/examples/split_video_for_youtube.sh
youtube-upload-0.7.3/bin/
youtube-upload-0.7.3/bin/youtube-upload
pi@RaspberryPi ~ $ rm youtube-upload-*.tgz
pi@RaspberryPi ~ $ mv youtube-upload-* youtube-upload
pi@RaspberryPi ~/youtube-upload $ sudo python setup.py install
running install
running build
running build_py
creating build
creating build/lib.linux-armv6l-2.7
creating build/lib.linux-armv6l-2.7/youtube_upload
copying youtube_upload/youtube_upload.py -> build/lib.linux-armv6l-2.7/youtube_upload
copying youtube_upload/__init__.py -> build/lib.linux-armv6l-2.7/youtube_upload
running build_scripts
creating build/scripts-2.7
copying and adjusting bin/youtube-upload -> build/scripts-2.7
changing mode of build/scripts-2.7/youtube-upload from 644 to 755
running install_lib
creating /usr/local/lib/python2.7/dist-packages/youtube_upload
copying build/lib.linux-armv6l-2.7/youtube_upload/youtube_upload.py -> /usr/local/lib/python2.7/dist-packages/youtu be_upload
copying build/lib.linux-armv6l-2.7/youtube_upload/__init__.py -> /usr/local/lib/python2.7/dist-packages/youtube_upl oad
byte-compiling /usr/local/lib/python2.7/dist-packages/youtube_upload/youtube_upload.py to youtube_upload.pyc
byte-compiling /usr/local/lib/python2.7/dist-packages/youtube_upload/__init__.py to __init__.pyc
running install_scripts
copying build/scripts-2.7/youtube-upload -> /usr/local/bin
changing mode of /usr/local/bin/youtube-upload to 755
running install_egg_info
Writing /usr/local/lib/python2.7/dist-packages/youtube_upload-0.7.3.egg-info
pi@RaspberryPi ~ $ python youtube_upload/youtube_upload.py –get-categories
python: can't open file 'youtube_upload/youtube_upload.py': [Errno 2] No such file or directory
Alles anzeigen
am Ende kommt diese Fehlermeldung
Ich weiß jetzt auch nicht, was ich falsch gemacht habe, könnt ihr mir nochmal helfen? Wenn nicht, wie bekomme ich das wieder deinstalliert?
Alles anzeigen
Hi,Du musst nur das "VERSION" im Link mit der aktuellen Versionsnummer ersetzten. Die akutelle Versionsnummer lautet "0.7.3"
Und aus:
http://youtube-upload.googlecode.com/files/youtube-upload-VERSION.tgz
wird somit:
http://youtube-upload.googlecode.com/files/youtube-upload-0.7.3.tgzDas wird öfters so gemacht und stellt sicher dass die "Links" in der Dokumentation nicht auf einer veraltete Version zeigen. Somit müssen diese nicht bei jeder Versionserhöhung angepasst werden.
Grüße,
Joh
Danke auch dir, war wohl zu offensichtlich, um es zu bemerken
Danke dir. Diese Anleitung auf google ist doch recht unübersichtlich und falls noch jemand dieses Problem hat, rate ich ihm diese anleitung zu verwenden. Ich melde mich dann nochmal, ob es funkrioniert hat
als YouTube anfänger mit geringer Bandbreite und Pc mit relativ hohem Verbrauch stehe ich gerade vor einem Dilemma. Meine Idee war, das Pi als Upload Computer zu nutzen. Da ich nur einen Monitor habe und nicht ständig umstöpseln möchte habe ich mal gegoogelt und zahlreiche Tutorials von Remote - clients für das RasPi gefunden. Allerdings wäre es toll, wenn ich es allein durch SSH zugriff ausführen könnte, u.a. weil es auch Android SSH-Clients geben soll. Dazu habe ich folgenden Thread gefunden. Als ich "$ wget http://youtube-upload.googlecode.com/files/youtube-upload-VERSION.tgz" in das Terminal eingegeben hatte, kam jedoch nun eine Error 404 Fehlermeldung.
Wie komme ich nun zum Skript? Ich habe mal mit Python angefangen und kleine Programme bei Codeacademy geschrieben, allerdings reicht mein wissen längst nicht für sowas aus. (-> selber skripten scheidet aus)
Die Remotelösung wäre auch die letzte Alternative, weil das Uploaden später mit möglichst geringem Aufwand vonstatten gehen soll. Außerdem könnte ich mit vorstellen, dass die zusätzliche Remoteverbindung zusätzlich Ressourcen verbraucht, die beim Pi ja ohnehin knapp sind.
Hab ich vielleicht einen falschen Befehl benutzt? Bin auch Linux Neuling.
Wäre toll, wenn sich mit dem Skript doch noch was machen lassen würde.
Danke für eure Hilfe
MfG JalicX
