/var/log/syslog [-M--] 109 L:[30626+ 0 30626/34047] *(2960381/3277905b) 10 0x00A
Oct 29 20:06:44 raspbmc xinetd[1718]: xinetd Version 2.3.14 started with libwrap loadavg options compiled in.
Oct 29 20:06:44 raspbmc xinetd[1718]: Started working: 4 available services
Oct 29 20:06:50 raspbmc kernel: bcm2708 watchdog, heartbeat=10 sec (nowayout=0)
Oct 30 04:00:04 raspbmc NetworkManager[801]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
Oct 30 04:00:04 raspbmc kernel: smsc95xx 1-1.1:1.0 eth0: link down
Oct 30 04:00:08 raspbmc NetworkManager[801]: <info> (eth0): device state change: activated -> unavailable (reason 'carrier-changed') [100 20 40]
Oct 30 04:00:09 raspbmc NetworkManager[801]: <info> (eth0): deactivating device (reason 'carrier-changed') [40]
Oct 30 04:00:09 raspbmc avahi-daemon[1546]: Withdrawing address record for 192.168.13.20 on eth0.
Oct 30 04:00:09 raspbmc avahi-daemon[1546]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.13.20.
Oct 30 04:00:09 raspbmc avahi-daemon[1546]: Interface eth0.IPv4 no longer relevant for mDNS.
Oct 30 04:00:09 raspbmc dbus[560]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Oct 30 04:00:09 raspbmc dbus[560]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 30 04:00:10 raspbmc ntpd[1305]: Deleting interface #3 eth0, 192.168.13.20#123, interface stats: received=342, sent=343, dropped=0, active_time=28464 secs
Oct 30 04:00:10 raspbmc ntpd[1305]: 212.19.47.108 interface 192.168.13.20 -> (none)
Oct 30 04:00:10 raspbmc ntpd[1305]: 129.70.132.36 interface 192.168.13.20 -> (none)
Oct 30 04:00:10 raspbmc ntpd[1305]: 85.10.199.217 interface 192.168.13.20 -> (none)
Oct 30 04:00:10 raspbmc ntpd[1305]: 84.38.65.142 interface 192.168.13.20 -> (none)
Oct 30 04:00:10 raspbmc ntpd[1305]: peers refreshed
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> (eth0): carrier now ON (device state 20)
Oct 30 04:00:12 raspbmc kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> (eth0): device state change: unavailable -> disconnected (reason 'carrier-changed') [20 30 40]
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Auto-activating connection 'Wired connection 1'.
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) starting connection 'Wired connection 1'
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> (eth0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 1 of 5 (Device Prepare) scheduled...
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 1 of 5 (Device Prepare) started...
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 2 of 5 (Device Configure) scheduled...
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 1 of 5 (Device Prepare) complete.
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 2 of 5 (Device Configure) starting...
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> (eth0): device state change: prepare -> config (reason 'none') [40 50 0]
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 2 of 5 (Device Configure) successful.
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 3 of 5 (IP Configure Start) scheduled.
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 2 of 5 (Device Configure) complete.
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 3 of 5 (IP Configure Start) started...
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> (eth0): device state change: config -> ip-config (reason 'none') [50 70 0]
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 3 of 5 (IP Configure Start) complete.
Oct 30 04:00:12 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 5 of 5 (IPv4 Commit) started...
Oct 30 04:00:12 raspbmc avahi-daemon[1546]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.13.20.
Oct 30 04:00:12 raspbmc avahi-daemon[1546]: New relevant interface eth0.IPv4 for mDNS.
Oct 30 04:00:12 raspbmc avahi-daemon[1546]: Registering new address record for 192.168.13.20 on eth0.IPv4.
Oct 30 04:00:13 raspbmc NetworkManager[801]: <info> (eth0): device state change: ip-config -> activated (reason 'none') [70 100 0]
Oct 30 04:00:13 raspbmc ntpd[1305]: Listen normally on 6 eth0 192.168.13.20 UDP 123
Oct 30 04:00:13 raspbmc ntpd[1305]: peers refreshed
Oct 30 04:00:13 raspbmc NetworkManager[801]: <info> Policy set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS.
Oct 30 04:00:13 raspbmc NetworkManager[801]: <info> Activation (eth0) successful, device activated.
Oct 30 04:00:13 raspbmc NetworkManager[801]: <info> Activation (eth0) Stage 5 of 5 (IPv4 Commit) complete.
Oct 30 04:00:25 raspbmc iptables: Configuring ip tables for interface eth0
Oct 30 04:00:46 raspbmc NetworkManager[801]: <info> (eth0): carrier now OFF (device state 100, deferring action for 4 seconds)
Oct 30 04:00:46 raspbmc kernel: smsc95xx 1-1.1:1.0 eth0: link down
Oct 30 04:00:48 raspbmc NetworkManager[801]: <info> (eth0): carrier now ON (device state 100)
Oct 30 04:00:48 raspbmc kernel: smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
Oct 30 13:15:41 raspbmc avahi-daemon[1546]: Got SIGTERM, quitting.
Oct 30 13:15:41 raspbmc ntpd[1305]: ntpd exiting on signal 15
Oct 30 13:15:42 raspbmc kernel: imklog 5.8.11, log source = /proc/kmsg started.
Oct 30 13:15:42 raspbmc rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="105" x-info="http://www.rsyslog.com"] start
Bitteschön Das ist von der Zeit mit dem reboot
