// Automatically generated configuration file for 'Hyperion daemon'
// Generated by: HyperCon (The Hyperion deamon configuration file builder
/// Device configuration contains the following fields:
/// * 'name' : The user friendly name of the device (only used for display purposes)
/// * 'type' : The type of the device or leds (known types for now are
/// APA102, Adalight, AmbiLed, Atmo, Hyperion-USBASP-WS2801, Hyperion-USBASP-WS2812, Lightberry, Lightpack, LPD6803, LPD8806, Multi-Lightpack, P9813, Paintpack, PhilipsHUE, PiBlaster, SEDU, Test, ThinkerForge, TPM2, WS2801, WS2812b, None)
/// * [device type specific configuration]
/// * 'colorOrder' : The order of the color bytes ('rgb', 'rbg', 'bgr', etc.).
"device" :
"name" : "MyPi",
"type" : "lpd8806",
"output" : "/dev/spidev0.0",
"rate" : 250000,
"colorOrder" : "brg"
/// Color manipulation configuration used to tune the output colors to specific surroundings.
/// The configuration contains a list of color-transforms. Each transform contains the
/// following fields:
/// * 'id' : The unique identifier of the color transformation (eg 'device_1') /// * 'leds' : The indices (or index ranges) of the leds to which this color transform applies
/// (eg '0-5, 9, 11, 12-17'). The indices are zero based. /// * 'hsv' : The manipulation in the Hue-Saturation-Value color domain with the following
/// tuning parameters:
/// - 'saturationGain' The gain adjustement of the saturation
/// - 'valueGain' The gain adjustement of the value
/// * 'red'/'green'/'blue' : The manipulation in the Red-Green-Blue color domain with the
/// following tuning parameters for each channel:
/// - 'threshold' The minimum required input value for the channel to be on
/// (else zero)
/// - 'gamma' The gamma-curve correction factor
/// - 'blacklevel' The lowest possible value (when the channel is black)
/// - 'whitelevel' The highest possible value (when the channel is white)
/// Next to the list with color transforms there is also a smoothing option.
/// * 'smoothing' : Smoothing of the colors in the time-domain with the following tuning
/// parameters:
/// - 'type' The type of smoothing algorithm ('linear' or 'none')
/// - 'time_ms' The time constant for smoothing algorithm in milliseconds
/// - 'updateFrequency' The update frequency of the leds in Hz
/// - 'updateDelay' The delay of the output to leds (in periods of smoothing)
"color" :
"transform" :
"id" : "default",
"leds" : "*",
"hsv" :
"saturationGain" : 1.5500,
"valueGain" : 1.2500
"red" :
"threshold" : 0.0000,
"gamma" : 1.0000,
"blacklevel" : 0.0000,
"whitelevel" : 1.0000
"green" :
"gamma" : 1.0000,
"blue" :
"gamma" : 1.0000,
"smoothing" :
"type" : "linear",
"time_ms" : 100,
"updateFrequency" : 25.0000,
"updateDelay" : 0
/// The black border configuration, contains the following items:
/// * enable : true if the detector should be activated
/// * threshold : Value below which a pixel is regarded as black (value between 0.0 and 1.0)
"blackborderdetector" :
"enable" : true,
"threshold" : 0.01
/// The configuration of the effect engine, contains the following items:
/// * paths : An array with absolute location(s) of directories with effects
/// * bootsequence : The effect selected as 'boot sequence'
"effects" :
"paths" :
"/opt/hyperion/effects"
"bootsequence" :
"duration_ms" : 3000
/// The configuration for the frame-grabber, contains the following items:
/// * width : The width of the grabbed frames [pixels]
/// * height : The height of the grabbed frames [pixels]
/// * frequency_Hz : The frequency of the frame grab [Hz]
//"framegrabber" :
//"width" : 96,
//"height" : 54,
//"frequency_Hz" : 25.0
/// The configuration of the XBMC connection used to enable and disable the frame-grabber. Contains the following fields:
/// * xbmcAddress : The IP address of the XBMC-host
/// * xbmcTcpPort : The TCP-port of the XBMC-server
/// * grabVideo : Flag indicating that the frame-grabber is on(true) during video playback
/// * grabPictures : Flag indicating that the frame-grabber is on(true) during picture show
/// * grabAudio : Flag indicating that the frame-grabber is on(true) during audio playback
/// * grabMenu : Flag indicating that the frame-grabber is on(true) in the XBMC menu
/// * grabScreensaver : Flag indicating that the frame-grabber is on(true) when XBMC is on screensaver
/// * enable3DDetection : Flag indicating that the frame-grabber should switch to a 3D compatible modus if a 3D video is playing
//"xbmcVideoChecker" :
//"xbmcAddress" : "127.0.0.1",
//"xbmcTcpPort" : 9090,
//"grabVideo" : true,
//"grabPictures" : true,
//"grabAudio" : true,
//"grabMenu" : false,
//"grabScreensaver" : true,
//"enable3DDetection" : true
/// The configuration of the Json server which enables the json remote interface
/// * port : Port at which the json server is started
"jsonServer" :
"port" : 19444
/// The configuration of the Proto server which enables the protobuffer remote interface
/// * port : Port at which the protobuffer server is started
// "protoServer" :
// "port" : 19445
/// The configuration of the boblight server which enables the boblight remote interface
/// * port : Port at which the boblight server is started
// "boblightServer" :
// "port" : 19333
/// Configuration for the embedded V4L2 grabber
/// * device : V4L2 Device to use [default="/dev/video0"]
/// * input : V4L2 input to use [default=0]
/// * standard : Video standard (no-change/PAL/NTSC) [default="no-change"]
/// * width : V4L2 width to set [default=-1]
/// * height : V4L2 height to set [default=-1]
/// * frameDecimation : Frame decimation factor [default=2]
/// * sizeDecimation : Size decimation factor [default=8]
/// * priority : Hyperion priority channel [default=800]
/// * mode : 3D mode to use 2D/3DSBS/3DTAB (note: no autodetection) [default="2D"]
/// * cropLeft : Cropping from the left [default=0]
/// * cropRight : Cropping from the right [default=0]
/// * cropTop : Cropping from the top [default=0]
/// * cropBottom : Cropping from the bottom [default=0]
/// * redSignalThreshold : Signal threshold for the red channel between 0.0 and 1.0 [default=0.0]
/// * greenSignalThreshold : Signal threshold for the green channel between 0.0 and 1.0 [default=0.0]
/// * blueSignalThreshold : Signal threshold for the blue channel between 0.0 and 1.0 [default=0.0]
"grabber-v4l2" :
"device" : "/dev/video0",
"input" : 0,
"standard" : "PAL",
"width" : -1,
"height" : -1,
"frameDecimation" : 2,
"sizeDecimation" : 8,
"priority" : 800,
"mode" : "2D",
"cropLeft" : 10,
"cropRight" : 8,
"cropTop" : 12,
"cropBottom" : 19,
"redSignalThreshold" : 0.4,
"greenSignalThreshold" : 0.2,
"blueSignalThreshold" : 1.0
/// The configuration for each individual led. This contains the specification of the area
/// averaged of an input image for each led to determine its color. Each item in the list
/// contains the following fields:
/// * index: The index of the led. This determines its location in the string of leds; zero
/// being the first led.
/// * hscan: The fractional part of the image along the horizontal used for the averaging
/// (minimum and maximum inclusive)
/// * vscan: The fractional part of the image along the vertical used for the averaging
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.6286, "maximum" : 0.6571 },
"vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
"index" : 1,
"hscan" : { "minimum" : 0.6571, "maximum" : 0.6857 },
"index" : 2,
"hscan" : { "minimum" : 0.6857, "maximum" : 0.7143 },
"index" : 3,
"hscan" : { "minimum" : 0.7143, "maximum" : 0.7429 },
"index" : 4,
"hscan" : { "minimum" : 0.7429, "maximum" : 0.7714 },
"index" : 5,
"hscan" : { "minimum" : 0.7714, "maximum" : 0.8000 },
"index" : 6,
"hscan" : { "minimum" : 0.8000, "maximum" : 0.8286 },
"index" : 7,
"hscan" : { "minimum" : 0.8286, "maximum" : 0.8571 },
"index" : 8,
"hscan" : { "minimum" : 0.8571, "maximum" : 0.8857 },
"index" : 9,
"hscan" : { "minimum" : 0.8857, "maximum" : 0.9143 },
"index" : 10,
"hscan" : { "minimum" : 0.9143, "maximum" : 0.9429 },
"index" : 11,
"hscan" : { "minimum" : 0.9429, "maximum" : 0.9714 },
"index" : 12,
"hscan" : { "minimum" : 0.9714, "maximum" : 1.0000 },
"index" : 13,
"hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
"index" : 14,
"vscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }
"index" : 15,
"vscan" : { "minimum" : 0.9000, "maximum" : 0.9500 }
"index" : 16,
"vscan" : { "minimum" : 0.8500, "maximum" : 0.9000 }
"index" : 17,
"vscan" : { "minimum" : 0.8000, "maximum" : 0.8500 }
"index" : 18,
"vscan" : { "minimum" : 0.7500, "maximum" : 0.8000 }
"index" : 19,
"vscan" : { "minimum" : 0.7000, "maximum" : 0.7500 }
"index" : 20,
"vscan" : { "minimum" : 0.6500, "maximum" : 0.7000 }
"index" : 21,
"vscan" : { "minimum" : 0.6000, "maximum" : 0.6500 }
"index" : 22,
"vscan" : { "minimum" : 0.5500, "maximum" : 0.6000 }
"index" : 23,
"vscan" : { "minimum" : 0.5000, "maximum" : 0.5500 }
"index" : 24,
"vscan" : { "minimum" : 0.4500, "maximum" : 0.5000 }
"index" : 25,
"vscan" : { "minimum" : 0.4000, "maximum" : 0.4500 }
"index" : 26,
"vscan" : { "minimum" : 0.3500, "maximum" : 0.4000 }
"index" : 27,
"vscan" : { "minimum" : 0.3000, "maximum" : 0.3500 }
"index" : 28,
"vscan" : { "minimum" : 0.2500, "maximum" : 0.3000 }
"index" : 29,
"vscan" : { "minimum" : 0.2000, "maximum" : 0.2500 }
"index" : 30,
"vscan" : { "minimum" : 0.1500, "maximum" : 0.2000 }
"index" : 31,
"vscan" : { "minimum" : 0.1000, "maximum" : 0.1500 }
"index" : 32,
"vscan" : { "minimum" : 0.0500, "maximum" : 0.1000 }
"index" : 33,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }
"index" : 34,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
"index" : 35,
"index" : 36,
"index" : 37,
"index" : 38,
"index" : 39,
"index" : 40,
"index" : 41,
"index" : 42,
"index" : 43,
"index" : 44,
"index" : 45,
"index" : 46,
"index" : 47,
"index" : 48,
"hscan" : { "minimum" : 0.6000, "maximum" : 0.6286 },
"index" : 49,
"hscan" : { "minimum" : 0.5714, "maximum" : 0.6000 },
"index" : 50,
"hscan" : { "minimum" : 0.5429, "maximum" : 0.5714 },
"index" : 51,
"hscan" : { "minimum" : 0.5143, "maximum" : 0.5429 },
"index" : 52,
"hscan" : { "minimum" : 0.4857, "maximum" : 0.5143 },
"index" : 53,
"hscan" : { "minimum" : 0.4571, "maximum" : 0.4857 },
"index" : 54,
"hscan" : { "minimum" : 0.4286, "maximum" : 0.4571 },
"index" : 55,
"hscan" : { "minimum" : 0.4000, "maximum" : 0.4286 },
"index" : 56,
"hscan" : { "minimum" : 0.3714, "maximum" : 0.4000 },
"index" : 57,
"hscan" : { "minimum" : 0.3429, "maximum" : 0.3714 },
"index" : 58,
"hscan" : { "minimum" : 0.3143, "maximum" : 0.3429 },
"index" : 59,
"hscan" : { "minimum" : 0.2857, "maximum" : 0.3143 },
"index" : 60,
"hscan" : { "minimum" : 0.2571, "maximum" : 0.2857 },
"index" : 61,
"hscan" : { "minimum" : 0.2286, "maximum" : 0.2571 },
"index" : 62,
"hscan" : { "minimum" : 0.2000, "maximum" : 0.2286 },
"index" : 63,
"hscan" : { "minimum" : 0.1714, "maximum" : 0.2000 },
"index" : 64,
"hscan" : { "minimum" : 0.1429, "maximum" : 0.1714 },
"index" : 65,
"hscan" : { "minimum" : 0.1143, "maximum" : 0.1429 },
"index" : 66,
"hscan" : { "minimum" : 0.0857, "maximum" : 0.1143 },
"index" : 67,
"hscan" : { "minimum" : 0.0571, "maximum" : 0.0857 },
"index" : 68,
"hscan" : { "minimum" : 0.0286, "maximum" : 0.0571 },
"index" : 69,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0286 },
"index" : 70,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
"index" : 71,
"index" : 72,
"index" : 73,
"index" : 74,
"index" : 75,
"index" : 76,
"index" : 77,
"index" : 78,
"index" : 79,
"index" : 80,
"index" : 81,
"index" : 82,
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
"index" : 88,
"index" : 89,
"index" : 90,
"index" : 91,
"index" : 92,
"index" : 93,
"index" : 94,
"index" : 95,
"index" : 96,
"index" : 97,
"index" : 98,
"index" : 99,
"index" : 100,
"index" : 101,
"index" : 102,
"index" : 103,
"index" : 104,
"index" : 105,
"index" : 106,
"index" : 107,
"index" : 108,
"index" : 109,
"index" : 110,
"index" : 111,
"index" : 112,
"index" : 113,
"endOfJson" : "endOfJson"
