The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Oct 9 13:05:20 2015 from 192.168.1.6
osmc@osmc:~$ sudo pip install rpi.gpio Flask configparser
Downloading/unpacking rpi.gpio
Downloading RPi.GPIO-0.5.11.tar.gz
Running setup.py (path:/tmp/pip-build-i8ktMc/http://rpi.gpio/setup.py) egg_info for package rpi.gpio
Downloading/unpacking Flask
Downloading Flask-0.10.1.tar.gz (544kB): 544kB downloaded
Running setup.py (path:/tmp/pip-build-i8ktMc/Flask/setup.py) egg_info for package Flask
warning: no files found matching '*' under directory 'tests'
warning: no previously-included files matching '*.pyc' found under directory 'docs'
warning: no previously-included files matching '*.pyo' found under directory 'docs'
warning: no previously-included files matching '*.pyc' found under directory 'tests'
warning: no previously-included files matching '*.pyo' found under directory 'tests'
warning: no previously-included files matching '*.pyc' found under directory 'examples'
warning: no previously-included files matching '*.pyo' found under directory 'examples'
no previously-included directories found matching 'docs/_build'
no previously-included directories found matching 'docs/_themes/.git'
Downloading/unpacking configparser
Downloading configparser-3.3.0r2.tar.gz
Running setup.py (path:/tmp/pip-build-i8ktMc/configparser/setup.py) egg_info for package configparser
Downloading/unpacking Werkzeug>=0.7 (from Flask)
Downloading Werkzeug-0.10.4-py2.py3-none-any.whl (293kB): 293kB downloaded
Downloading/unpacking Jinja2>=2.4 (from Flask)
Downloading Jinja2-2.8-py2.py3-none-any.whl (263kB): 263kB downloaded
Downloading/unpacking itsdangerous>=0.21 (from Flask)
Downloading itsdangerous-0.24.tar.gz (46kB): 46kB downloaded
Running setup.py (path:/tmp/pip-build-i8ktMc/itsdangerous/setup.py) egg_info for package itsdangerous
warning: no previously-included files matching '*' found under directory 'docs/_build'
Downloading/unpacking MarkupSafe (from Jinja2>=2.4->Flask)
Downloading MarkupSafe-0.23.tar.gz
Running setup.py (path:/tmp/pip-build-i8ktMc/MarkupSafe/setup.py) egg_info for package MarkupSafe
Installing collected packages: rpi.gpio, Flask, configparser, Werkzeug, Jinja2, itsdangerous, MarkupSafe
Running setup.py install for rpi.gpio
building 'RPi.GPIO' extension
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c source/py_gpio.c -o build/temp.linux-armv7l-2.7/source/py_gpio.o
unable to execute 'arm-linux-gnueabihf-gcc': No such file or directory
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Complete output from command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-i8ktMc/http://rpi.gpio/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-_19A8j-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/RPi
copying RPi/__init__.py -> build/lib.linux-armv7l-2.7/RPi
running build_ext
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/source
Cleaning up...
Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-i8ktMc/http://rpi.gpio/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-_19A8j-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-i8ktMc/rpi.gpio
Storing debug log for failure in /root/.pip/pip.log
osmc@osmc:~$
