Stecker hab ich ihm heute gezogen und auf den ersten Blick startet er "normal"
den cronjob habe ich eingerichtet und auch mal das sudo tcpdump -c 20 -vvveni eth0 arp getestet.
Was müsste mir die Ausgabe sagen?
16:50:26.187360 a0:0b:ba:82:b6:4b > ff:ff:ff:ff:ff:ff, ethertype ARP (0x0806), length 60: Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.100.1 tell 192.168.100.26, length 46
16:50:27.344371 00:15:5d:64:24:04 > ff:ff:ff:ff:ff:ff, ethertype ARP (0x0806), length 60: Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.100.1 tell 192.168.100.170, length 46
16:50:28.553926 f0:42:1c:a4:6a:14 > b8:27:eb:7d:36:f2, ethertype ARP (0x0806), length 60: Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.100.67 (b8:27:eb:7d:36:f2) tell 192.168.100.29, length 46
16:50:28.554009 b8:27:eb:7d:36:f2 > f0:42:1c:a4:6a:14, ethertype ARP (0x0806), length 42: Ethernet (len 6), IPv4 (len 4), Reply 192.168.100.67 is-at b8:27:eb:7d:36:f2, length 28
16:50:29.194660 a0:0b:ba:82:b6:4b > ff:ff:ff:ff:ff:ff, ethertype ARP (0x0806), length 60: Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.100.1 tell 192.168.100.26, length 46
20 packets captured
20 packets received by filter
0 packets dropped by kernel
Ein Blick in die Logfiles, welche sich unter /var/log/ befinden ( wie z.B. messages ) ...
habe ich auch gemacht.
Das sind die letzten Einträge in der messages:
Dec 23 08:17:11 raspberrypi kernel: [ 20.545845] Adding 102396k swap on /var/swap. Priority:-1 extents:2 across:109052k FS
Dec 23 08:17:11 raspberrypi kernel: [ 21.566923] cfg80211: World regulatory domain updated:
Dec 23 08:17:11 raspberrypi kernel: [ 21.566947] cfg80211: DFS Master region: unset
Dec 23 08:17:11 raspberrypi kernel: [ 21.566956] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
Dec 23 08:17:11 raspberrypi kernel: [ 21.566967] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Dec 23 08:17:11 raspberrypi kernel: [ 21.566978] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
Dec 23 08:17:11 raspberrypi kernel: [ 21.566988] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
Dec 23 08:17:11 raspberrypi kernel: [ 21.566999] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
Dec 23 08:17:11 raspberrypi kernel: [ 21.567012] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
Dec 23 08:17:11 raspberrypi kernel: [ 21.567022] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
Dec 23 08:17:11 raspberrypi kernel: [ 21.567032] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
Dec 23 08:17:11 raspberrypi kernel: [ 21.567042] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
Dec 23 08:17:12 raspberrypi kernel: [ 22.272256] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Dec 23 08:17:12 raspberrypi kernel: [ 22.272559] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 23 08:17:13 raspberrypi kernel: [ 23.675299] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec 23 08:17:13 raspberrypi kernel: [ 23.676468] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xDDE1
Natürlich hab ich mir auch das/die dmsg angesehen.
Zumindest ist hier ein Grund für das Fehlende Bild, warum das so ist, kann ich aber nicht erklären.
[code]
dmesg
[ 2.947744] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 2.953431] [vc_sm_connected_init]: failed to initialize shared memory service
[ 6.000220] sd 0:0:0:0: [sda] No Caching mode page found
[ 6.011343] sd 0:0:0:0: [sda] Assuming drive cache: write through
[code]
Zu guter Letzt habe ich in einem SSH Fenster den Befehl eingegeben:
top -b -i -d -1200 > Logdatei
Leider hab ich kein NAS laufen, aber er logged ja fleissig, so dass man sich das dann anschauen kann.
Habe ich alles gemacht? Ist noch etwas zu prüfen? Besten Dank schon mal
