Sun May 1 19:08:09 2016 80.187.111.189:8311 TLS: Initial packet from [AF_INET]80.187.111.189:8311, sid=d86befcd 170f7bfe
Sun May 1 19:08:09 2016 80.187.111.189:6299 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sun May 1 19:08:09 2016 80.187.111.189:6299 TLS Error: TLS handshake failed
Sun May 1 19:08:09 2016 80.187.111.189:6299 SIGUSR1[soft,tls-error] received, client-instance restarting
Sun May 1 19:08:10 2016 80.187.111.189:8311 VERIFY OK: depth=1, C=DE, ST=CA, L=SanFrancisco, O=Fort-Funston, OU=MyOrganizationalUnit, CN=OpenVPN, name=EasyRSA, emailAddress=me@myhost.mydomain
Sun May 1 19:08:10 2016 80.187.111.189:8311 VERIFY OK: depth=0, C=DE, ST=CA, L=SanFrancisco, O=Fort-Funston, OU=MyOrganizationalUnit, CN=manu, name=EasyRSA, emailAddress=me@myhost.mydomain
Sun May 1 19:08:10 2016 80.187.111.189:8311 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun May 1 19:08:10 2016 80.187.111.189:8311 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun May 1 19:08:10 2016 80.187.111.189:8311 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun May 1 19:08:10 2016 80.187.111.189:8311 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun May 1 19:08:10 2016 80.187.111.189:8311 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sun May 1 19:08:10 2016 80.187.111.189:8311 [manu] Peer Connection Initiated with [AF_INET]80.187.111.189:8311
Sun May 1 19:08:10 2016 MULTI: new connection by client 'manu' will cause previous active sessions by this client to be dropped. Remember to use the --duplicate-cn option if you want multiple clients using the same certificate o
r username to concurrently connect.
Sun May 1 19:08:10 2016 MULTI_sva: pool returned IPv4=10.8.0.6, IPv6=(Not enabled)
Sun May 1 19:08:10 2016 MULTI: Learn: 10.8.0.6 -> manu/80.187.111.189:8311
Sun May 1 19:08:10 2016 MULTI: primary virtual IP for manu/80.187.111.189:8311: 10.8.0.6
Sun May 1 19:08:10 2016 manu/80.187.111.189:8311 PUSH: Received control message: 'PUSH_REQUEST'
Sun May 1 19:08:10 2016 manu/80.187.111.189:8311 send_push_reply(): safe_cap=940
Sun May 1 19:08:10 2016 manu/80.187.111.189:8311 SENT CONTROL [manu]: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 85.214.20.141,dhcp-option DNS 8.8.8.8,route 10.8.0.0 255.255.255.0,topology net30,ifconfig 10.8.0
.6 10.8.0.5' (status=1)
Sun May 1 19:08:52 2016 80.187.111.189:9687 TLS: Initial packet from [AF_INET]80.187.111.189:9687, sid=bfe3dea9 ad55aba7
Sun May 1 19:08:53 2016 80.187.111.189:9687 VERIFY OK: depth=1, C=DE, ST=CA, L=SanFrancisco, O=Fort-Funston, OU=MyOrganizationalUnit, CN=OpenVPN, name=EasyRSA, emailAddress=me@myhost.mydomain
Sun May 1 19:08:53 2016 80.187.111.189:9687 VERIFY OK: depth=0, C=DE, ST=CA, L=SanFrancisco, O=Fort-Funston, OU=MyOrganizationalUnit, CN=manu, name=EasyRSA, emailAddress=me@myhost.mydomain
Sun May 1 19:08:53 2016 80.187.111.189:9687 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun May 1 19:08:53 2016 80.187.111.189:9687 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun May 1 19:08:53 2016 80.187.111.189:9687 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun May 1 19:08:53 2016 80.187.111.189:9687 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun May 1 19:08:53 2016 80.187.111.189:9687 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sun May 1 19:08:53 2016 80.187.111.189:9687 [manu] Peer Connection Initiated with [AF_INET]80.187.111.189:9687
Sun May 1 19:08:53 2016 MULTI: new connection by client 'manu' will cause previous active sessions by this client to be dropped. Remember to use the --duplicate-cn option if you want multiple clients using the same certificate o
Sun May 1 19:08:53 2016 MULTI_sva: pool returned IPv4=10.8.0.6, IPv6=(Not enabled)
Sun May 1 19:08:53 2016 MULTI: Learn: 10.8.0.6 -> manu/80.187.111.189:9687
Sun May 1 19:08:53 2016 MULTI: primary virtual IP for manu/80.187.111.189:9687: 10.8.0.6
Sun May 1 19:08:53 2016 manu/80.187.111.189:9687 PUSH: Received control message: 'PUSH_REQUEST'
Sun May 1 19:08:53 2016 manu/80.187.111.189:9687 send_push_reply(): safe_cap=940
Sun May 1 19:08:53 2016 manu/80.187.111.189:9687 SENT CONTROL [manu]: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 85.214.20.141,dhcp-option DNS 8.8.8.8,route 10.8.0.0 255.255.255.0,topology net30,ifconfig 10.8.0
Sun May 1 19:09:45 2016 80.187.111.189:11752 TLS: Initial packet from [AF_INET]80.187.111.189:11752, sid=927c4351 5c6bf876
Sun May 1 19:09:55 2016 80.187.111.189:12131 TLS: Initial packet from [AF_INET]80.187.111.189:12131, sid=b8951620 67c8882b
Sun May 1 19:10:05 2016 80.187.111.189:12666 TLS: Initial packet from [AF_INET]80.187.111.189:12666, sid=d1c1c3e9 098db77f
Sun May 1 19:10:15 2016 80.187.111.189:13025 TLS: Initial packet from [AF_INET]80.187.111.189:13025, sid=821f16da f1434f93
Sun May 1 19:10:25 2016 80.187.111.189:13361 TLS: Initial packet from [AF_INET]80.187.111.189:13361, sid=e1dbe492 276b8a36
Sun May 1 19:10:36 2016 80.187.111.189:13851 TLS: Initial packet from [AF_INET]80.187.111.189:13851, sid=caff8eb6 bf34100a
Sun May 1 19:10:45 2016 80.187.111.189:11752 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Sun May 1 19:10:45 2016 80.187.111.189:11752 TLS Error: TLS handshake failed
Alles anzeigen
