Beiträge von Chesstom
So ,da bin ich wieder. Daran soll es net scheitern.
Erstmal die config:
Alles anzeigen// Automatically generated configuration file for Hyperion ambilight daemon // Notice: All values are explained with comments at our wiki: wiki.hyperion-project.org (config area) // Generated by: HyperCon (The Hyperion deamon configuration file builder) // Created with HyperCon V1.03.1 (11.06.2016) { // DEVICE CONFIGURATION "device" : { "name" : "MyHyperionConfig", "type" : "lpd8806", "output" : "/dev/spidev0.0", "rate" : 250000, "colorOrder" : "brg" }, // COLOR CALIBRATION CONFIG "color" : { "channelAdjustment" : [ { "id" : "default", "leds" : "*", "pureRed" : { "redChannel" : 255, "greenChannel" : 0, "blueChannel" : 0 }, "pureGreen" : { "redChannel" : 0, "greenChannel" : 255, "blueChannel" : 0 }, "pureBlue" : { "redChannel" : 0, "greenChannel" : 0, "blueChannel" : 255 } } ], "temperature" : [ { "id" : "default", "leds" : "*", "correctionValues" : { "red" : 255, "green" : 255, "blue" : 255 } } ], "transform" : [ { "id" : "default", "leds" : "*", "hsl" : { "saturationGain" : 1.0000, "luminanceGain" : 1.1000, "luminanceMinimum" : 0.0000 }, "red" : { "threshold" : 0.0000, "gamma" : 2.3000 }, "green" : { "threshold" : 0.0000, "gamma" : 2.1000 }, "blue" : { "threshold" : 0.0000, "gamma" : 2.2200 } } ], // SMOOTHING CONFIG "smoothing" : { "type" : "linear", "time_ms" : 200, "updateFrequency" : 50.0000, "updateDelay" : 0 } }, // V4L2 GRABBER CONFIG "grabber-v4l2" : { "device" : "/dev/video0", "input" : 0, "standard" : "PAL", "width" : 720, "height" : 576, "frameDecimation" : 2, "sizeDecimation" : 8, "priority" : 800, "mode" : "2D", "cropLeft" : 0, "cropRight" : 5, "cropTop" : 0, "cropBottom" : 2, "redSignalThreshold" : 0.1, "greenSignalThreshold" : 0.1, "blueSignalThreshold" : 0.1 }, // BLACKBORDER CONFIG "blackborderdetector" : { "enable" : true, "threshold" : 0.1, "unknownFrameCnt" : 600, "borderFrameCnt" : 50, "maxInconsistentCnt" : 10, "blurRemoveCnt" : 1, "mode" : "default" }, // BOOTEFFECT CONFIG "bootsequence" : { "color" : [0,0,0], "effect" : "", "duration_ms" : 3000, "priority" : 990 }, // JSON SERVER CONFIG "jsonServer" : { "port" : 19444 }, // PROTO SERVER CONFIG "protoServer" : { "port" : 19445 }, // EFFECT PATH "effects" : { "paths" : [ "/storage/hyperion/effects", "/usr/share/hyperion/effects" ] }, // NO FRAME GRABBER CONFIG // NO KODI CHECK CONFIG // NO BOBLIGHT SERVER CONFIG // NO JSON/PROTO FORWARD CONFIG // LED CONFIGURATION "leds" : [ ], "endOfJson" : "endOfJson" }
Mit den Farben bin noch net ganz zufrieden und muss sie noch ein bischen besser einstellen. Zu dem Problem könnte ich höchsten mal einen kleinen Clip aufnehmen. Aber mom ist es ein bischen zu hell. Die Datenleitung zum Pi ist ein CAT 7 Netzwerk - Kabel. Takt und Daten sind je ein Paar.
Das Problem ist mir neulich erst verstärkt aufgefallen. Die installation ist schon älter, nur früher habe ich die config von hier genommen. Aber so 100% zufrieden war ich natürlich nicht. Iwann nach dem ich halt auch ein paar mal upgedatet habe ist es mir dann mal bei einem Fussballspiel - viel grün - aufgefallen.
Dann wollte ich auch die Farben selbst einstellen , und mit den rot/grün usw bildern fällt es extrem auf. Ich denke daß es verstärkt bei einzelnen Farben auftritt. Wenn die obere Leiste iwie von farben durchteilt ist es nicht sichtbar. Das muss ich aber noch genauer testen. Fakt ist aber, daß es nur über den Grabber nicht so recht geht.
Via dem Farbrad, passiert gar nix. Alles wie es sein soll. Egal welche Farbe. Wenn ich z.B ein rotes Bild angucke , flackert die oberen LED's. Wenn ich via Farbrad 255 rot vorwähle, flackert nix. Auch wenn ich eine ein andere Farbe dazu gebe. Zu dem Rot z.B.
Die LED Config ist momentan. 70 oben und auch unten. 38 links und rechts. Der TV hängt an der Wand. Deshalb keine Fussausblendung. Wie geschrieben - vllt mach ich mal bei gelegenheit - wenn der TV frei ist - einen Clip.
Es gibt mittlerweile auch einen günstigeren - http://audiovision.de/2016/07/05/neu…re-uhd-geraete/
oder auch hier -> http://www.grobi.tv/videotv/hdmi/h….2-auf-hdcp-1.4
mit o.g configuration mache ich schon eine weile herum. Im Prinzip funktioniert eigentlich alles. Aber nur wenn ich via Hyperion Configuration Programm die Farben vorwähle ,passt alles Tiipp Topp. Egal welche Farbe.
Die Kombi hab ich an einem 65' Tv dran, und komme somit auf 216 LED's. Grabber funzt auch soweit. Nur wenn die Geschichte über den Grabber geht, flackert die obere Zeile.
Die anderen nicht. Habe auch schon viel an der Verdrahtung rum gemacht - denke aber daß ich diese ausschliessen kann , weil es ja über Hyperion wunderbar funktioniert. Da kann ich keinen Fehler feststellen.Mir ist auch net klar warum es nur die obere Zeile betrifft. :s Der Screenshot vom Grabber sieht übrigens auch super aus..denke ich
Es gibt ja von HdFury auch einen Splitter. Nur kann er von 4K30 auf 1080p downscalen. Leider nicht von 4K60 auf 1080p. Dabei denke ich dass dieser ohne den Integral - der ja den HDCP 2.2 umwandelt - nicht funktioniert.
Kann der andere Splitter definitiv z.B ein Signal von einem UHD Bluray Player mit dem ich eine original UHD BluRay anschaue auf 1080p herunter skalieren? Dann müsste er ja auch - wie der Integral - aus HDCP2.2 einen anderen Kopierschutz generieren.
Dann ist auch noch nicht sicher ob HDCP 2.2 Inhalte auf 1080p "downgescalt" werden oder nur 1:1 durchgeschleift werden. Dann würde ein 4k Inhalt auch 4K bleiben. Ich kann mir nicht vorstellen daß am Ende ein HDCP 2.2 1080p Signal rauskommt. Weiss gar net ob das möglich ist? Wenn es anders wäre würde das Gerät den HDCP ja aufheben!
Hm stimmt wohl. Die Integral ist nur dafür da - denke ich um die HDCP geschichte zu handeln. Von downscaling steht da nix. Das alle möglichen Videoformate unterstützt werden schon - aber in bezug auf HDCP und so.
Die Integral wirst du sowieso brauchen wegen dem HDCP , nun benötigt man noch einen Splitter der das downscaling macht. Den gibt auch von HD fury - https://www.amazon.de/HDFury-Splitter-duplizieren-Downscaling-Aufl%C3%B6sungen-Schwarz/dp/B016ZY2KRU?ie=UTF8&*Version*=1&*entries*=0 [Anzeige].
Funktionieren würde er ohne Integral - wenn man Bluray schaut auch net - vermute ich mal , gerade wegen HDCP. Oder dein AV Receiver kann einen 2. HDMI Ausgang unabhänig vom Hauptausgang, seperat ausgeben - auch was die Auflösung betrifft. Meiner (Onkyo 3010) kann das nicht.
Also für die HD Fury gibt es eine neue Firmware. Vllt behebt diese ja den einen oder anderen bug.
Ich habe mir mal die Bedienungsanleitung angesehen, und wie es dort beschrieben steht kann man ja wahllos verschiedene Auflösungen mit dem EDID Manager zu den HDMI Ports einstellen.
Es muss iwo ein Config Problem sein damit das ganze funktioniert bzw net funktioniert. :s
Es scheint ein gerät zugeben welches den HDCP iwie umgeht. Ist aber überhaupt nicht billig: -> von HDFury
Die Fa. wurde kürzlich von Warner Bros. wegen des Gerätes erfolglos verklagt :))
