gelöst:
Hello,
I found a solution thanks to Uranus Nucleus (search the Vellemann forum for VM110N and linux)
Just
add one line to k8055.c (see below the one with +10), make, make
install and the N-2 board is running (assuming that you have installed
libusb etc.)
/* Actual read of data from the device endpoint, retry 3 times if not responding ok */
static int ReadK8055Data(void)
int read_status = 0, i = 0;
if (CurrDev->DevNo == 0) return K8055_ERROR;
for(i=0; i < 3; i++)
read_status = usb_interrupt_read(CurrDev->device_handle,
USB_INP_EP, (char *)CurrDev->data_in, PACKET_LEN, USB_TIMEOUT);
if ((read_status == PACKET_LEN) && (CurrDev->data_in[1]
== CurrDev->DevNo )) return 0; /* works with K8055 / VM110 */
== CurrDev->DevNo +10)) return 0; /* works with K8055N / VM110N */
if (DEBUG)
fprintf(stderr, "Read retry\n");
return K8055_ERROR;
I had to perform a sudo ldconfig to run domotiga (lib not found issue)
Regards,
