Posts by Schnullifatz
    Nachtrag: Bin exakt nach dem Tutorial hier bei der Installation vorgegangen. Mit putty auf Raspi, Editor "nano", copy und paste aus dem Tutorial....
    keine Extrakonfiguration....
    Es geht da wohl eher um die OpenGL-Python bindings als um den OpenGL-Modus in raspi-config. Aber kein Traceback, keine Hilfe ;)
    LG
    Danke, daran habe ich nicht gedacht. Habe hier das logfile....
    [INFO ] Logger: Record log in /home/pi/.kivy/logs/kivy_17-04-07_0.txt
    [WARNING ] [Config ] Upgrading configuration in progress.
    [WARNING ] [Config ] Older configuration version detected (0 instead of 10)
    [INFO ] Kivy v1.8.0
    [INFO ] Factory: 157 symbols loaded
    [DEBUG ] Cache: register <kv.lang> with limit=None, timeout=Nones
    [DEBUG ] Cache: register <kv.image> with limit=None, timeout=60s
    [DEBUG ] Cache: register <kv.atlas> with limit=None, timeout=Nones
    [INFO ] Image: Providers: img_tex, img_dds, img_pygame, img_pil, img_gif
    [DEBUG ] Cache: register <kv.texture> with limit=1000, timeout=60s
    [DEBUG ] Cache: register <kv.shader> with limit=1000, timeout=3600s
    [DEBUG ] Window: Ignored <egl_rpi> (import error)
    [INFO ] Window: Provider: pygame(['window_egl_rpi'] ignored)
    [WARNING ] WinPygame: Video: failed (multisamples=2)
    [WARNING ] WinPygame: trying without antialiasing
    [ERROR ] Window: Unable to use pygame
    [ERROR ] Window: The module raised an important error: 'OpenGL not available'
    [WARNING ] stderr: Traceback (most recent call last):
    [WARNING ] stderr: File "/usr/local/bin/guestwlan.py", line 7, in <module>
    [WARNING ] stderr: from kivy.core.window import Window
    [WARNING ] stderr: File "/usr/lib/python2.7/dist-packages/kivy/core/window/__init__.py", line 1041, in <module>
    [WARNING ] stderr: ), True)
    [WARNING ] stderr: File "/usr/lib/python2.7/dist-packages/kivy/core/__init__.py", line 62, in core_select_lib
    [WARNING ] stderr: cls = cls()
    [WARNING ] stderr: File "/usr/lib/python2.7/dist-packages/kivy/core/window/__init__.py", line 479, in __init__
    [WARNING ] stderr: self.create_window()
    [WARNING ] stderr: File "/usr/lib/python2.7/dist-packages/kivy/core/window/window_pygame.py", line 140, in create_window
    [WARNING ] stderr: raise CoreCriticalException(e.message)
    [WARNING ] stderr: kivy.core.CoreCriticalException: OpenGL not available
    :helpnew: schon mal Danke!
