Beiträge von Buretuzap
host -T heise.de 192.168.178.1
Using domain server:
Address: 192.168.178.1#53
Aliases:
Host heise.de not found: 2(SERVFAIL)
127.0.0.1 habe ich auch probiert mit der 192.168.178.2 auszutauschen, aber ist kein Unterschied.
/etc/network/interfaces
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
dns-nameservers 127.0.0.1
/etc/dhcpcd.conf
# Ethernet
auto eth0
allow-hotplug eth0
iface eth0 inet static
address 192.168.178.2
netmask 255.255.255.0
gateway 192.168.178.1
/etc/dhcpcd.conf
interface eth0
static ip_address=192.168.178.2/24
static routers=192.168.178.1
static domain_name_servers=127.0.0.1
auto eth0
allow-hotplug eth0
up sysctl -qw net.ipv6.conf.eth0.disable_ipv6=1
/etc/hosts
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 raspberrypi
wget 127.0.0.1
--2023-04-08 16:07:06-- http://127.0.0.1/
Connecting to 127.0.0.1:80... failed: Connection refused.
sudo service dhcpcd status
● dhcpcd.service - DHCP Client Daemon
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/dhcpcd.service.d
└─wait.conf
Active: inactive (dead) since Sat 2023-04-08 16:14:32 CEST; 6min ago
Docs: man:dhcpcd(8)
Process: 442 ExecStart=/usr/sbin/dhcpcd -w -q (code=exited, status=0/SUCCESS)
CPU: 490ms
Apr 08 15:13:32 raspberrypi dhcpcd[588]: eth0: soliciting an IPv6 router
Apr 08 15:13:32 raspberrypi dhcpcd[588]: eth0: pid -1376494228 deleted route to 192.168.178.0/24
Apr 08 15:13:32 raspberrypi dhcpcd[588]: eth0: pid -70909129 deleted default route via 192.168.178.1
Apr 08 16:14:31 raspberrypi dhcpcd[588]: received SIGTERM, stopping
Apr 08 16:14:31 raspberrypi systemd[1]: Stopping DHCP Client Daemon...
Apr 08 16:14:31 raspberrypi dhcpcd[588]: wlan0: removing interface
Apr 08 16:14:31 raspberrypi dhcpcd[588]: eth0: removing interface
Apr 08 16:14:31 raspberrypi dhcpcd[588]: dhcpcd exited
Apr 08 16:14:32 raspberrypi systemd[1]: dhcpcd.service: Succeeded.
Apr 08 16:14:32 raspberrypi systemd[1]: Stopped DHCP Client Daemon.
ping -c 3 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=60 time=8.65 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=60 time=8.34 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=60 time=8.62 ms
--- 1.1.1.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 8.339/8.535/8.649/0.139 ms
ip r
default via 192.168.178.1 dev eth0 src 192.168.178.2 metric 202
192.168.178.0/24 dev eth0 proto dhcp scope link src 192.168.178.2 metric 202
/etc/resolv.conf
# Generated by resolvconf
nameserver 127.0.0.1
host heise.de 192.168.178.1
;; connection timed out; no servers could be reached
nc -zv 192.168.178.1 53
Connection to 192.168.178.1 53 port [tcp/domain] succeeded!
host heise.de 127.0.0.1 -> Internet funktioniert nicht, da DNS-Auflösung nicht an die Fritzbox weitergeleitet wird
sudo netstat -tulpena | grep -i 53
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13526 538/sshd: /usr/sbin
tcp6 0 0 :::22 :::* LISTEN 0 13528 538/sshd: /usr/sbin
udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 10215 430/avahi-daemon: r
udp6 0 0 :::5353 :::* 108 10216 430/avahi-daemon: r
Liebes Forum,
ich versuche einen Pi3B mit einem aktuellen Image (Bullseye + aktuell geupdated) als DNS-Server (ohne Pihole) mit einer Fritzbox (mit aktueller Firmware) einzurichten.
Das Einrichten hat alles gut geklappt, leider bekomme ich keine Internetverbindung, wenn ich alles in der Fritzbox und am PC auf die IP des lokalen Pi Dns-Servers umstelle.
Das muss an den Netzwerk-Settings beim Pi liegen und ich weiß jetzt nicht mehr weiter.
Das System läuft nur über IPv4 mit statischen Adressen ohne dnsmasq
FB ist der DHCP-Server und hat 192.168.178.001
Der Pi als DNS-Server 192.178.178.002
meine manuellen Konfigurationen sind folgendermaßen
Bei der FB ist die statische IP des Pi eingetragen 192.178.178.002
Heimnetz > Netzwerk > Netzwerkeinstellungen > IPv4-Konfiguration > Lokaler DNS-Server
Internet > Zugangsdaten > DNS-Server
Bei dem Pi
auto lo
sudo nano /etc/dhcpcd.conf
->am Ende sollte stehen
interface eth0
static ip_address=192.168.178.002/24
static routers=192.168.178.001
/etc/resolv.conf
/etc/resolv.conf.override
Kann Jemand bitte einen Hinweis geben wie man hinbekommt [emoji1]
Du kannst ihn beschleunigen, um einige ms :), wenn du die leere ySD entfernst. Dann wird der Versuch von der SD zu booten übergangen.p.s.: habe 2 Raspi's die ich nur mit USB (ohne leere SD) boote, ist etwas (10s) langsamer als von SD, aber im Betrieb fast doppelt so schnell.
So mach ich das auch: Booten von der SD-Karte und System auf USB-Stick (16 GB Stick für / und 128 GB Stick für /home). Damit bootet der Pi in wenigen Sekunden und das System läuft wieselflink.Habe eine microsd mit 3 Partitionen (Boot, Raspi-System, Raspi-Data) und will die 2 anderen Partitionen auf die USB-Festplatte auslagern. Habe die USB-HD bereits vorbereitet und eine Image-Kopie der beiden Partitionen der microsd raufgespielt. Jetzt habe ich leider erfolglos versucht den Zugriff auf die USB-HD umzuleiten.
Könnt Ihr so nett sein und Eure Vorgehensweise ein bißchen weiter ausführen?
Folgende Hardware:
Usb Hd an Pi 3 mit HifiBerry Digi per Spdif koaxial an Aktivlautsprecher.Frage:
Wie kann man es realisieren, dass man ohne Netzwerkverbindung mit Router die Musik (auch 24bit 192khz Flac) direkt an den Lautsprechern ausgibt und die Steuerung zb über Smartphone vornimmt?
