Posts by esteban69
    ich bin ein Raspi Einsteiger, und versuche verzweifelt, den Automaten zum Laufen zu bringen. Bei mir bleibt das Fenster in dem der QR-Code auftauchen soll immer weiss.
    Hier die Meldungen
    [font="Courier New"]root@raspberrypi:/usr/local/bin# python guestwlan.py
    [INFO ] Kivy v1.8.0
    [WARNING] [Config ] Older configuration version detected (0 instead of 10)
    [WARNING] [Config ] Upgrading configuration in progress.
    [INFO ] [Logger ] Record log in /root/.kivy/logs/kivy_17-08-20_0.txt
    [INFO ] [Factory ] 157 symbols loaded
    [DEBUG ] [Cache ] register <kv.lang> with limit=None, timeout=Nones
    [DEBUG ] [Cache ] register <kv.image> with limit=None, timeout=60s
    [DEBUG ] [Cache ] register <kv.atlas> with limit=None, timeout=Nones
    [INFO ] [Image ] Providers: img_tex, img_dds, img_pygame, img_pil, img_gif
    [DEBUG ] [Cache ] register <kv.texture> with limit=1000, timeout=60s
    [DEBUG ] [Cache ] register <kv.shader> with limit=1000, timeout=3600s
    [DEBUG ] [Window ] Ignored <egl_rpi> (import error)
    [INFO ] [Window ] Provider: pygame(['window_egl_rpi'] ignored)
    [WARNING] [WinPygame ] Video: failed (multisamples=2)
    [WARNING] [WinPygame ] trying without antialiasing
    [DEBUG ] [Window ] Display driver x11
    [DEBUG ] [Window ] Actual window size: 800x600
    [DEBUG ] [Window ] Actual color bits r8 g8 b8 a0
    [DEBUG ] [Window ] Actual depth bits: 24
    [DEBUG ] [Window ] Actual stencil bits: 8
    [DEBUG ] [Window ] Actual multisampling samples: 0
    [INFO ] [GL ] OpenGL version <3.0 Mesa 13.0.0>
    [INFO ] [GL ] OpenGL vendor <VMware, Inc.>
    [INFO ] [GL ] OpenGL renderer <Gallium 0.4 on llvmpipe (LLVM 3.9, 128 bits)>
    [INFO ] [GL ] OpenGL parsed version: 3, 0
    [INFO ] [GL ] Shading version <1.30>
    [INFO ] [GL ] Texture max size <8192>
    [INFO ] [GL ] Texture max units <32>
    [DEBUG ] [Shader ] Fragment compiled successfully
    [DEBUG ] [Shader ] Vertex compiled successfully
    [DEBUG ] [ImagePygame ] Load </usr/lib/python2.7/dist-packages/kivy/data/glsl/default.png>
    [INFO ] [Window ] virtual keyboard not allowed, single mode, not docked
    [DEBUG ] [Cache ] register <kv.loader> with limit=500, timeout=60s
    [INFO ] [Loader ] using a thread pool of 2 workers
    [DEBUG ] [App ] Loading kv <./guestwlan.kv>
    [INFO ] [Text ] Provider: pygame
    [ERROR ] [Image ] Error reading file /var/guestwlan/windows.jpg
    [ERROR ] [Image ] Error reading file /var/guestwlan/android.jpg
    [INFO ] [OSC ] using <multiprocessing> for socket
    [DEBUG ] [Base ] Create provider from mouse
    [DEBUG ] [Base ] Create provider from probesysfs,provider=hidinput
    [DEBUG ] [ProbeSysfs ] using probsysfs!
    [DEBUG ] [ProbeSysfs ] found device: FT5406 memory based driver at /dev/input/event3
    [INFO ] [ProbeSysfs ] device match: /dev/input/event3
    [INFO ] [HIDInput ] Read event from </dev/input/event3>
    [DEBUG ] [ProbeSysfs ] found device: USB Keyboard at /dev/input/event1
    [INFO ] [ProbeSysfs ] device match: /dev/input/event1
    [INFO ] [HIDInput ] Read event from </dev/input/event1>
    [DEBUG ] [ProbeSysfs ] found device: USB Keyboard at /dev/input/event2
    [INFO ] [ProbeSysfs ] device match: /dev/input/event2
    [INFO ] [HIDInput ] Read event from </dev/input/event2>
    [DEBUG ] [ProbeSysfs ] found device: Logitech USB Optical Mouse at /dev/input/event0
    [INFO ] [ProbeSysfs ] device match: /dev/input/event0
    [INFO ] [HIDInput ] Read event from </dev/input/event0>
    [INFO ] [Base ] Start application main loop
    [INFO ] [HIDMotionEvent] using <FT5406 memory based driver>
    [INFO ] [HIDMotionEvent] <FT5406 memory based driver> range position X is 0 - 800
    [INFO ] [HIDMotionEvent] <FT5406 memory based driver> range position Y is 0 - 480
    [INFO ] [HIDMotionEvent] using < USB Keyboard>
    [INFO ] [HIDMotionEvent] using <Logitech USB Optical Mouse>
    [INFO ] [GL ] NPOT texture support is available
    [DEBUG ] [Atlas ] Load </usr/lib/python2.7/dist-packages/kivy/data/../data/images/defaulttheme.atlas>
    [DEBUG ] [Atlas ] Need to load 1 images
    [DEBUG ] [Atlas ] Load </usr/lib/python2.7/dist-packages/kivy/data/../data/images/defaulttheme-0.png>
    [DEBUG ] [ImagePygame ] Load </usr/lib/python2.7/dist-packages/kivy/data/../data/images/defaulttheme-0.png>
    [INFO ] [Base ] Leaving application in progress...
    File "guestwlan.py", line 91, in <module>
    GuestWLANApp().run()
    File "/usr/lib/python2.7/dist-packages/kivy/app.py", line 792, in run
    runTouchApp()
    File "/usr/lib/python2.7/dist-packages/kivy/base.py", line 481, in runTouchApp
    EventLoop.window.mainloop()
    File "/usr/lib/python2.7/dist-packages/kivy/core/window/window_pygame.py", line 381, in mainloop
    self._mainloop()
    File "/usr/lib/python2.7/dist-packages/kivy/core/window/window_pygame.py", line 287, in _mainloop
    EventLoop.idle()
    File "/usr/lib/python2.7/dist-packages/kivy/base.py", line 324, in idle
    self.dispatch_input()
    File "/usr/lib/python2.7/dist-packages/kivy/base.py", line 309, in dispatch_input
    post_dispatch_input(*pop(0))
    File "/usr/lib/python2.7/dist-packages/kivy/base.py", line 220, in post_dispatch_input
    listener.dispatch('on_motion', etype, me)
    File "kivy/_event.pyx", line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690)
    File "/usr/lib/python2.7/dist-packages/kivy/core/window/__init__.py", line 645, in on_motion
    self.dispatch('on_touch_down', me)
    File "/usr/lib/python2.7/dist-packages/kivy/core/window/__init__.py", line 657, in on_touch_down
    if w.dispatch('on_touch_down', touch):
    File "/usr/lib/python2.7/dist-packages/kivy/uix/screenmanager.py", line 992, in on_touch_down
    return super(ScreenManager, self).on_touch_down(touch)
    File "/usr/lib/python2.7/dist-packages/kivy/uix/widget.py", line 284, in on_touch_down
    if child.dispatch('on_touch_down', touch):
    File "guestwlan.py", line 43, in on_touch_down
    SM.get_screen('wlan').updatesettings()
    File "guestwlan.py", line 66, in updatesettings
    self.wlanssid = wlancfg.get('WLAN', 'wlanssid')
    File "/usr/lib/python2.7/ConfigParser.py", line 330, in get
    raise NoSectionError(section)
    ConfigParser.NoSectionError: No section: 'WLAN'
    [/font]
    :helpnew: :helpnew: :helpnew: :helpnew: :helpnew: :helpnew: :helpnew: :helpnew:
    LG
    Stephan
    Fehler gefunden. Die Datei wlankeygen war in DOS Format und nicht UNIX
