Aufgrund privater Angelegenheiten, kann ich mich leider erst jetzt wieder zurück melden.
#!/usr/bin/python3
# -*- coding: utf-8 -*-
# (c) 2018 by meigrafd
import sys
import time
import multiprocessing as mp
from datetime import datetime
from RPi import GPIO
class Sonar_Ranger:
This class encapsulates a type of acoustic ranger. In particular
the type of ranger with separate trigger and echo pins.
A pulse on the trigger initiates the sonar ping and shortly
afterwards a sonar pulse is transmitted and the echo pin
goes high. The echo pins stays high until a sonar echo is
received (or the response times-out). The time between
the high and low edges indicates the sonar round trip time.
Adjusting the interval between measurements increases the speed
of the reading. Increasing the speed will also increase CPU usage.
Setting it too low will cause errors.
def __init__(self, trigger_pin, echo_pin, telemetry, status, settings, unit='cm', average=False, range_min=2, range_max=400):
self.trig = trigger_pin
self.echo = echo_pin
self.telemetry = telemetry
self.status = status
self.settings = settings
self.unit = unit
self.average = average
self.range_min = range_min
self.range_max = range_max
self.average_count = 3
self.last_announce_time = int(time.time())
GPIO.setup(self.trig, GPIO.OUT)
GPIO.setup(self.echo, GPIO.IN)
self.start_time = datetime.now()
self.distance=None
GPIO.add_event_detect(self.echo, GPIO.BOTH, self.callback)
def callback(self, channel):
if GPIO.input(self.echo) == 1:
else:
self.end_time = datetime.now()
self.delta = self.end_time - self.start_time
self.time_elapsed = self.delta.seconds + self.delta.microseconds / 1E6 # ultra-hacker-style. 1E6 is 1000000.
if self.unit == 'cm':
metric = 0.000058
else:
metric = 0.000148
self.distance = self.time_elapsed / metric
self.telemetry['distance'] = self.distance
def measure_average(self, count=3):
c=1
distance=0
while (c <= count):
self.ping()
time.sleep(0.040)
if self.distance:
distance = distance + self.distance
time.sleep(0.05)
c+=1
self.distance = distance/count
def ping(self, pulse=0.00005):
self.start_time=datetime.now()
self.end_time=datetime.now()
self.distance=None
GPIO.output(self.trig, GPIO.HIGH)
time.sleep(pulse)
GPIO.output(self.trig, GPIO.LOW)
def print_distance(self):
if self.distance:
if (int(time.time()) - self.last_announce_time) >= self.settings['distance_announce_time']:
if self.distance > self.range_max or self.distance < self.range_min:
print('Distance: out of range %.2f' % self.distance)
else:
print('Distance: %.2f %s' % (self.distance, self.unit))
def run(self):
while True:
time.sleep(self.settings['distance_measure_time'])
if not self.status['stop_ping']:
if self.average:
self.measure_average(self.average_count)
else:
self.ping()
class Motor_Control:
http://www.14core.com/wiring-driving-the-l298n-h-bridge-on-2-to-4-dc-motors/
def __init__(self, status, motor_a_in1, motor_a_in2, motor_b_in3, motor_b_in4):
self.motor_a_in1 = motor_a_in1
self.motor_a_in2 = motor_a_in2
self.motor_b_in3 = motor_b_in3
self.motor_b_in4 = motor_b_in4
self.status['steerTo']=0
GPIO.setup(self.motor_a_in1, GPIO.OUT)
GPIO.setup(self.motor_a_in2, GPIO.OUT)
GPIO.setup(self.motor_b_in3, GPIO.OUT)
GPIO.setup(self.motor_b_in4, GPIO.OUT)
def stop(self):
GPIO.output(self.motor_a_in1, False)
GPIO.output(self.motor_a_in2, False)
GPIO.output(self.motor_b_in3, False)
GPIO.output(self.motor_b_in4, False)
self.status['steerTo'] = 'stop'
print('Motor: {}'.format(self.status['steerTo']))
def forward(self):
GPIO.output(self.motor_a_in1, True)
GPIO.output(self.motor_b_in3, True)
self.status['steerTo'] = 'forward'
def reverse(self):
GPIO.output(self.motor_a_in2, True)
GPIO.output(self.motor_b_in4, True)
self.status['steerTo'] = 'reverse'
def turn_left(self):
self.status['steerTo'] = 'left'
def turn_right(self):
self.status['steerTo'] = 'right'
def pivot_left(self):
self.status['steerTo'] = 'pivot_left'
def pivot_right(self):
self.status['steerTo'] = 'pivot_right'
def main(gpio_mode=GPIO.BCM):
motor_a_in1 = 11
motor_a_in2 = 7
motor_b_in3 = 13
motor_b_in4 = 15
sonar_trigger_left = 38
sonar_trigger_right = 35
sonar_echo_left = 40
sonar_echo_right = 37
GPIO.setmode(gpio_mode)
status = mp.Manager().dict() # shared dictionary
telemetry_left = mp.Manager().dict()
telemetry_right = mp.Manager().dict()
settings=dict() # static dictionary
settings['distance_measure_time'] = 0.5 # sec. you should wait 50ms before the next trigger.
settings['distance_announce_time'] = 1 # sec
status['stop_ping']=False
telemetry_left['distance']=None
telemetry_right['distance']=None
try:
motor = Motor_Control(status, motor_a_in1, motor_a_in2, motor_b_in3, motor_b_in4)
radar_left = Sonar_Ranger(sonar_trigger_left, sonar_echo_left, telemetry_left, status, settings)
radar_right = Sonar_Ranger(sonar_trigger_right, sonar_echo_right, telemetry_right, status, settings)
# Spawn child process for running measurement
radarProcess_left = mp.Process(target=radar_left.run)
radarProcess_left.daemon = True
radarProcess_left.start()
radarProcess_right = mp.Process(target=radar_right.run)
radarProcess_right.daemon = True
radarProcess_right.start()
time.sleep(1)
while True:
radar_left.print_distance()
radar_right.print_distance()
## ..robots brain..
if telemetry_left['distance'] < 15:
if not status['steerTo'] == 'pivot_right':
motor.pivot_right()
elif telemetry_right['distance'] < 15:
if not status['steerTo'] == 'pivot_left':
motor.pivot_left()
else:
if not status['steerTo'] == 'forward':
motor.forward()
time.sleep(0.01) # lowers CPU usage
except (KeyboardInterrupt, SystemExit):
if radarProcess_left.is_alive(): radarProcess_left.terminate()
elif radarProcess_right.is_alive(): radarProcess_right.terminate()
GPIO.cleanup()
if __name__ == '__main__':
main(gpio_mode=GPIO.BOARD)
