dev tun
proto udp
port 1194
ca /etc/openvpn/easy-rsa/pki/ca.crt
cert /etc/openvpn/easy-rsa/pki/issued/server_h54DxIMsRGv5OnoP.crt
key /etc/openvpn/easy-rsa/pki/private/server_h54DxIMsRGv5OnoP.key
dh /etc/openvpn/easy-rsa/pki/dh2048.pem
topology subnet
server 10.8.0.0 255.255.255.0
# server and remote endpoints
ifconfig 10.8.0.1 10.8.0.2
# Add route to Client routing table for the OpenVPN Server
push "route 10.8.0.1 255.255.255.255"
# Add route to Client routing table for the OPenVPN Subnet
push "route 10.8.0.0 255.255.255.0"
# your local subnet
push "route 0.0.0.0 "
# Set your primary domain name server address for clients
push "dhcp-option DNS 8.8.8.8"
push "dhcp-option DNS 8.8.4.4"
# Override the Client default gateway by using 0.0.0.0/1 and
# 128.0.0.0/1 rather than 0.0.0.0/0. This has the benefit of
# overriding but not wiping out the original default gateway.
push "redirect-gateway def1"
client-to-client
keepalive 10 120
remote-cert-tls client
tls-version-min 1.2
tls-auth /etc/openvpn/easy-rsa/pki/ta.key 0
cipher AES-256-CBC
auth SHA256
comp-lzo
user nobody
group nogroup
persist-key
persist-tun
crl-verify /etc/openvpn/crl.pem
status /var/log/openvpn-status.log 20
status-version 3
log /var/log/openvpn.log
verb 1
# Generated for use by PiVPN.io
