Ok, ich werde es mal versuchen.
Danke für die Hilfe !
Es wird aus den beiden "||" ein Smiley gemacht ! Warum auch immer ?
hallo, danke für die schnelle Antwort.
Ich habe mich an die übliche Vorgehensweise gehalten.
Eine neue splash.png in das Verzeichnis "/usr/share/plymouth/themes/pix/splash.png" geladen. Das pix.script modifiziert, in dem ich 4 Einträge auskommentiert habe. Auch eine andere .png Datei hochgeladen und die pix.script angepasst.
screen_width = Window.GetWidth();
screen_height = Window.GetHeight();
#theme_image = Image("splash.png");
theme_image = Image("t.png");
image_width = theme_image.GetWidth();
image_height = theme_image.GetHeight();
scale_x = image_width / screen_width;
scale_y = image_height / screen_height;
flag = 1;
if (scale_x > 1 scale_y > 1)
if (scale_x > scale_y)
resized_image = theme_image.Scale (screen_width, image_height / scale_x);
image_x = 0;
image_y = (screen_height - ((image_height * screen_width) / image_width)) / 2;
else
resized_image = theme_image.Scale (image_width / scale_y, screen_height);
image_x = (screen_width - ((image_width * screen_height) / image_height)) / 2;
image_y = 0;
else
resized_image = theme_image.Scale (image_width, image_height);
image_x = (screen_width - image_width) / 2;
image_y = (screen_height - image_height) / 2;
if (Plymouth.GetMode() != "shutdown")
sprite = Sprite (resized_image);
sprite.SetPosition (image_x, image_y, -100);
#message_sprite = Sprite();
#mssage_sprite.SetPosition(screen_width * 0.1, screen_height * 0.9, 10000);
fun message_callback (text) {
# my_image = Image.Text(text, 1, 1, 1);
# message_sprite.SetImage(my_image);
sprite.SetImage (resized_image);
Plymouth.SetUpdateStatusFunction(message_callback);
Außerdem die cmdline.txt angepasst
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty3 root=PARTUUID=60ac9f24-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles logo.nologo vt.global_cursor_default=0
sowie die config.txt
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Splash einschalten
disable_splash=1
# Blitz abschalten
avoid_warnings=1
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
Das System soll beim Start ein Video in einer Endlosschleife abspielen. Im optimale Fall kommt kurz vor dem Video der "splashscreen".
Auf dem Raspi 3 mit Raspbian Pixel oder Stretch funktioniert das, bei Raspbian Buster bekomme ich es nicht hin.
Der Raspi startet, es erscheint nichts bis kurz vor dem Start des Videos. Da erscheint kurz ein Textblock für max 1 Sekunde und das Video startet.
hallo
ich möchte an meinem Raspi 4b welcher im Kiosk Mode mit Raspbian Buster läuft den Splash Screen austauschen. auf den alten Raspbian Versionen hat das auch problemlos geklappt. Mit dem neuen Raspi 4 und Raspbian Buster bekomme ich das nicht hin. Weder mit Plymouth noch mit FBI.
Hat jemand einen Tipp ?
Danke Tell
Ich werde mich morgen mal daran setzen und es ausprobieren. Natürlich gebe ich dann auch eine Rückmeldung!
Das hört sich gut an, nur leider bin ich in bzgl. des Programmieren ein Neuling. Das hört sich irgendwie nach einem Python Skript an ?!
Ich werde mal in diese Richtung weiter recherchieren.
Ich danke euch beiden !
P.S. sollte ich nicht weiterkommen ....melde ich mich hier einfach noch mal
Ich hab da mal ne Frage, wahrscheinlich ist es hier falsch, aber ich versuche es trotzdem mal.
Auf meinem Raspberry läuft Raspbian/Pixel, direkt nach dem starten spielt der Raspberry eine Videodatei vom USB Stick in einer Endlosschleife ab. Das geschieht ohne das etwas vom Boot Vorgang zusehen ist, oder eine Eingabe per Tastatur notwendig ist.
Meine Idee wäre, das vom USB Stick nur eine bestimmte (signierte?) Videodatei abgespielt wird. Damit möchte ich vermeiden das der USB Stick oder das Video gegen "ungeeignetes" Material ausgetauscht wird.
Ist das möglich ?
Im Internet habe ich bis jetzt nichts dem entsprechendes Gefunden. Meine Programierkentnisse sind max. gering !
Ich hab da mal ne frage, wahrscheinlich ist es hier falsch, aber ich versuche es trotzdem mal.
Ich möchte das das oben von mir genannte System, vom USB Stick nur eine bestimmte (signierte?) Videodatei abspielt. Damit möchte ich vermeiden das der USB Stick oder das Video gegen ungeeignetes Material ausgetauscht wird.
Ist das möglich ?
