Hartnäckigkeit zahlt sich aus. Es ist notwendig, "evdev" zu verwenden:
http://blog.damnsoft.org/making-a-dedic…nalyzer-part-2/
I also learned that depending on the LCD you are using, a few things from the process will be quite different. For instance the touchscreen on this KeDei LCD uses libinput instead of evdev. Because of this, the input config file is called 40-libinput.confinstead of 10-evdev.conf. If you want to have right click emulation you need to install evdev (sudo apt-get install xserver-xorg-input-evdev
) and change the driver the touchscreen uses to evdev, like this:
40-libinput.con ergänzen:
Section "InputClass"
Identifier "libinput touchscreen catchall"
MatchIsTouchscreen "on"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
Option "EmulateThirdButton" "1"
Option "EmulateThirdButtonTimeout" "500"
Option "EmulateThirdButtonMoveThreshold" "30"
EndSection
Funktioniert.
Alles anzeigen
