So, nächste Idee, damit ich mit dem Gute-Nacht-Button das Display ausgeschaltet bekomme:
Ordner
angelegt: mkdir /home/pi/Gute_Nacht
Rechte
vergeben: chmod a+rw /home/pi/Gute_Nacht
Mittels "sudo nano /home/pi/oled_phoniebox/scripts/gpio-buttons/gpio-buttons.py" folgende Änderungen (#wg Datei ergaenzt) vorgenommen:
#!/usr/bin/python3
import os #wg Datei ergaenzt
from gpiozero import LED, Button #LED ergänzt
from signal import pause
from subprocess import check_call
from time import sleep
# This script will block any I2S DAC e.g. from Hifiberry, Justboom, ES9023, PCM5102A
# due to the assignment of GPIO 19 and 21 to a buttons
# 2018-10-31
# Added the function on holding volume + - buttons to change the volume in 0.3s interval
# 2018-10-15
# this script has the `pull_up=True` for all pins. See the following link for additional info:
# https://github.com/MiczFlor/RPi-Jukebox-RFID/issues/259#issuecomment-430007446
# 2017-12-12
# This script was copied from the following RPi forum post:
# https://forum-raspberrypi.de/forum/thread/13144-projekt-jukebox4kids-jukebox-fuer-kinder/?postID=312257#post312257
# I have not yet had the time to test is, so I placed it in the misc folder.
# If anybody has ideas or tests or experience regarding this solution, please create pull requests or contact me.
jukebox4kidsPath = "/home/pi/RPi-Jukebox-RFID"
def def_shutdown():
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=shutdown", shell=True)
def def_volU():
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=volumeup", shell=True)
def def_volD():
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=volumedown", shell=True)
def def_vol0():
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=mute", shell=True)
def def_next():
for x in range(0, 19):
if next.is_pressed == True :
sleep(0.1)
else:
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=playernext", shell=True)
break
def def_contrastup():
if prev.is_pressed == True :
check_call("/usr/bin/touch /tmp/o4p_overview.temp", shell=True)
else:
check_call("/usr/bin/python3 /home/pi/oled_phoniebox/scripts/contrast/contrast_up.py", shell=True)
def def_contrastdown():
else:
check_call("/usr/bin/python3 /home/pi/oled_phoniebox/scripts/contrast/contrast_down.py", shell=True)
def def_prev():
sleep(0.1)
else:
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=playerprev", shell=True)
break
def def_halt():
check_call(jukebox4kidsPath+"/scripts/playout_controls.sh -c=playerpause", shell=True)
#ergaenzt
def def_lichtonoff():
ledlich.toggle()
ledshut.toggle()
ledvolU.toggle()
ledvolD.toggle()
lednext.toggle()
ledprev.toggle()
ledhalt.toggle()
def_Datei_bei_Licht #wg Datei ergaenzt
#wg Datei ergaenzt
def def_Datei_bei_Licht():
if ledlich.value != 0 : #oder „if ledlich.is_lit == True :“
licht_an_Datei = open("/home/pi/Gute_Nacht/licht_an_Datei.txt","w")
licht_an_Datei.close()
else:
if os.path.exists("/home/pi/Gute_Nacht/licht_an_Datei.txt") :
os.remove("/home/pi/Gute_Nacht/licht_an_Datei.txt")
lichtschalter = Button(13,pull_up=True) #ergaenzt
ledshut = LED(25,initial_value=True) #ergaenzt
ledvolU = LED(24,initial_value=True) #ergaenzt
ledvolD = LED(23,initial_value=True) #ergaenzt
lednext = LED(5,initial_value=True) #ergaenzt
ledprev = LED(12,initial_value=True) #ergaenzt
ledhalt = LED(6,initial_value=True) #ergaenzt
#shut = Button(3, hold_time=2)
#vol0 = Button(13,pull_up=True)
volU = Button(16,pull_up=True,hold_time=0.3,hold_repeat=True)
volD = Button(19,pull_up=True,hold_time=0.3,hold_repeat=True)
next = Button(26,pull_up=True,hold_time=2.0,hold_repeat=False)
prev = Button(20,pull_up=True,hold_time=2.0,hold_repeat=False)
halt = Button(21,pull_up=True)
lichtschalter.when_pressed = def_lichtonoff #ergänzt
#shut.when_held = def_shutdown
vol0.when_pressed = def_vol0
volU.when_pressed = def_volU
#When the Volume Up button was held for more than 0.3 seconds every 0.3 seconds he will call a ra$
volU.when_held = def_volU
volD.when_pressed = def_volD
#When the Volume Down button was held for more than 0.3 seconds every 0.3 seconds he will lower t$
volD.when_held = def_volD
next.when_pressed = def_next
next.when_held = def_contrastup
prev.when_pressed = def_prev
prev.when_held = def_contrastdown
halt.when_pressed = def_halt
pause()
Alles anzeigen
Ziel soll es sein, dass eine Datei in dem Ordner existiert, wenn die LED für den Gute-Nacht-Button leuchtet, und diese gelöscht wird, wenn die LED aus ist. Da eine Änderung nur durch Betätigung des Gute-Nacht-Buttons(lichtschalter) passieren kann, sollte das eigentlich mit in "def def_lichtonoff():".
Funktioniert aber nicht: Buttons und LEDs sind nicht mehr funktionstüchtig nach Neustart.
Was jedoch funktioniert: Wenn ich nur diese beiden Zeilen (und natürlich "import os") einfüge, wird die Datei im Ordner erstellt:
Was ich damit plane:
In der Datei "oled_phoniebox.py" soll eine Abfrage innerhalb "def main(num_iterations=sys.maxsize):" gestartet werden:
while num_iterations > 0:
num_iterations = 1
if os.path.exists("/home/pi/Gute_Nacht/licht_an_Datei.txt") : #Datei vorhanden/Licht an: normaler Ablauf
device.show() #nötig?
curr_time = datetime.now()
except:
sleep(0.5)
ShowImage("music")
else: #Datei nicht vorhanden/Licht aus: Display in Energiesparmodus
device.hide() #Energiesparmodus
#if __name__ == "__main__":
initVars = Init(confFile)
Alles anzeigen
Warum funktioniert die GPIO-Datei nicht? Wie muss das korrekt aussehen?
Könnte der Plan ansonsten aufgehen?
Vielen Dank und viele Grüße,
Christina
