Posts by Schecher
    Wie sind z. Zt. auf deinem PI, die Ausgaben von:
    pi@RaspbianServer-06022019:~ $ cat /etc/os-release
    PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="9"
    VERSION="9 (stretch)"
    ID=raspbian
    ID_LIKE=debian
    pi@RaspbianServer-06022019:~ $ uname -a
    Linux RaspbianServer-06022019 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
    Hallo liebes Raspberry PI Forum,
    Ich habe ein Problem und das wäre das ich keine apt mehr entfernen
    kann, und ich bin schon ratlos. Ich freue mich über eine Antwort.
    Hier ist einfach mal so ein "Log" (mit den wichtigsten Informationen)
    $exagear
    Starting /bin/bash in the guest image /opt/exagear/images/ubuntu-1404lts
    $sudo apt-get remove wine
    E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
    $sudo apt-get -f install
    Do you want to continue? [Y/n] y
    debconf: Perl may be unconfigured (Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: /etc/perl /usr/local/lib/perl/5.18.2 /usr/local/share/perl/5.18.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.18 /usr/share/perl/5.18 /usr/local/lib/site_perl .) at (eval 1) line 2.
    BEGIN failed--compilation aborted at (eval 1) line 2.
    ) -- aborting
    (Reading database ... 29312 files and directories currently installed.)
    Preparing to unpack .../x11-common_1%3a7.7+1ubuntu8.1_all.deb ...
    Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: /etc/perl /usr/local/lib/perl/5.18.2 /usr/local/share/perl/5.18.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.18 /usr/share/perl/5.18 /usr/local/lib/site_perl .) at /usr/share/debconf/frontend line 5.
    BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 5.
    dpkg: error processing archive /var/cache/apt/archives/x11-common_1%3a7.7+1ubuntu8.1_all.deb (--unpack):
    subprocess new pre-installation script returned error exit status 2
    /var/lib/dpkg/tmp.ci/postrm: 679: /var/lib/dpkg/tmp.ci/postrm: systemctl: not found
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
