Posts by praveendeshmane
    [Blocked Image: https://i.pinimg.com/originals/52/01/d5/5201d56464cdce31c7e5daf00d94f6b8.png]
    ---Set up---
    1) We are evaluating using Raspberry Pi Compute Module CM3.
    2) USB HUB and USB UART are boarded on the IO board.
    3) USB HUB is working in self-power mode.
    4) VBUS detect USB HUB uses the same 3.3V power supply as CM3.
    5) Two LTE modules are connected to USB-HUB via USB-SERIAL and each LTE module takes 2A --- Protocol --- AT commands
    ---Problem----
    The LTE modules which are connected to USB-HUB are disconnecting. This problem occurs only sometimes not always
    Following are kernel logs.
    Kerenl log:
    19:47:58 raspberrypi kernel: [9301.001438] usb1-port1: disabled by hub (EMI?), Re-enabling ...
    19:47:58 raspberrypi kernel: [9301.001457] usb 1-1: USB disconnect, device number 11
    19:47:58 raspberrypi kernel: [9301.001463] usb 1-1.1: USB disconnect, device number 12
    19:47:58 raspberrypi kernel: [9301.001668] ftdi_sio ttyUSB2: error from flowcontrol urb
    19:47:58 raspberrypi kernel: [9301.001872] ftdi_sio ttyUSB2: FTDI USB Serial Device converter now disconnected from ttyUSB2
    19:47:58 raspberrypi kernel: [9301.001906] ftdi_sio 1-1.1: 1.0: device disconnected
    19:47:58 raspberrypi kernel: [9301.002107] ftdi_sio ttyUSB3: error from flowcontrol urb
    19:47:58 raspberrypi kernel: [9301.003371] ftdi_sio ttyUSB3: FTDI USB Serial Device converter now disconnected from ttyUSB3
    19:47:58 raspberrypi kernel: [9301.003429] ftdi_sio 1-1.1: 1.1: device disconnected
    19:47:58 raspberrypi kernel: [9301.010150] ftdi_sio ttyUSB4: FTDI USB Serial Device converter now disconnected from ttyUSB4
    19:47:58 raspberrypi kernel: [9301.010212] ftdi_sio 1-1.1: 1.2: device disconnected
    19:47:58 raspberrypi kernel: [9301.010430] ftdi_sio ttyUSB5: error from flowcontrol urb
    19:47:58 raspberrypi kernel: [9301.018012] ftdi_sio ttyUSB5: FTDI USB Serial Device converter now disconnected from ttyUSB5
    --- --- Question
    Any investigation method and solution?
