Hat sonst niemand eine Idee wie ich Ambilight AUS bekomme wenn die Dreambox in Standby geschaltet wird?
Posts by Dreamoffice
Ja ist komisch.
irgendwie kommt das Ambilight von Openelec immer durch. läuft sehr stabil
leider
ja richtig. ich hatte es auskommentiert hat aber nichts gebracht
so meintest du das oder?
Display More// "xbmcVideoChecker" : { //"xbmcAddress" : "127.0.0.1", //"xbmcTcpPort" : 9090, //"grabVideo" : false, //"grabPictures" : false, //"grabAudio" : false, //"grabMenu" : false, //"grabScreensaver" : false, //"enable3DDetection" : false }, /// The configuration of the Json server which enables the json remote interface /// * port : Port at which the json server is started "jsonServer" : { "port" : 19444
Hallo
Hier mal meine Config.Code
Display More// Automatically generated configuration file for 'Hyperion daemon' // Generated by: HyperCon (The Hyperion deamon configuration file builder { /// Device configuration contains the following fields: /// * 'name' : The user friendly name of the device (only used for display purposes) /// * 'type' : The type of the device or leds (known types for now are 'ws2801', 'ldp8806', /// 'lpd6803', 'sedu', 'adalight', 'lightpack', 'test' and 'none') /// * 'output' : The output specification depends on selected device. This can for example be the /// device specifier, device serial number, or the output file name /// * 'rate' : The baudrate of the output to the device /// * 'colorOrder' : The order of the color bytes ('rgb', 'rbg', 'bgr', etc.). "device" : { "name" : "MyPi", "type" : "lpd8806", "output" : "/dev/spidev0.0", "rate" : 250000, "colorOrder" : "brg" }, /// Color manipulation configuration used to tune the output colors to specific surroundings. /// The configuration contains a list of color-transforms. Each transform contains the /// following fields: /// * 'id' : The unique identifier of the color transformation (eg 'device_1') /// * 'leds' : The indices (or index ranges) of the leds to which this color transform applies /// (eg '0-5, 9, 11, 12-17'). The indices are zero based. /// * 'hsv' : The manipulation in the Hue-Saturation-Value color domain with the following /// tuning parameters: /// - 'saturationGain' The gain adjustement of the saturation /// - 'valueGain' The gain adjustement of the value /// * 'red'/'green'/'blue' : The manipulation in the Red-Green-Blue color domain with the /// following tuning parameters for each channel: /// - 'threshold' The minimum required input value for the channel to be on /// (else zero) /// - 'gamma' The gamma-curve correction factor /// - 'blacklevel' The lowest possible value (when the channel is black) /// - 'whitelevel' The highest possible value (when the channel is white) /// /// Next to the list with color transforms there is also a smoothing option. /// * 'smoothing' : Smoothing of the colors in the time-domain with the following tuning /// parameters: /// - 'type' The type of smoothing algorithm ('linear' or 'none') /// - 'time_ms' The time constant for smoothing algorithm in milliseconds /// - 'updateFrequency' The update frequency of the leds in Hz "color" : { "transform" : [ { "id" : "default", "leds" : "*", "hsv" : { "saturationGain" : 1.0000, "valueGain" : 1.0000 }, "red" : { "threshold" : 0.0500, "gamma" : 1.2000, "blacklevel" : 0.0000, "whitelevel" : 1.0000 }, "green" : { "threshold" : 0.0000, "gamma" : 1.2000, "blacklevel" : 0.0000, "whitelevel" : 1.0000 }, "blue" : { "threshold" : 0.0000, "gamma" : 1.2000, "blacklevel" : 0.0000, "whitelevel" : 1.0000 } } ], "smoothing" : { "type" : "linear", "time_ms" : 200, "updateFrequency" : 20.0000 } }, /// The configuration for each individual led. This contains the specification of the area /// averaged of an input image for each led to determine its color. Each item in the list /// contains the following fields: /// * index: The index of the led. This determines its location in the string of leds; zero /// being the first led. /// * hscan: The fractional part of the image along the horizontal used for the averaging /// (minimum and maximum inclusive) /// * vscan: The fractional part of the image along the vertical used for the averaging /// (minimum and maximum inclusive) "leds" : [ { "index" : 0, "hscan" : { "minimum" : 0.3711, "maximum" : 0.3860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 1, "hscan" : { "minimum" : 0.3569, "maximum" : 0.3717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 2, "hscan" : { "minimum" : 0.3426, "maximum" : 0.3574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 3, "hscan" : { "minimum" : 0.3283, "maximum" : 0.3431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 4, "hscan" : { "minimum" : 0.3140, "maximum" : 0.3289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 5, "hscan" : { "minimum" : 0.2997, "maximum" : 0.3146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 6, "hscan" : { "minimum" : 0.2854, "maximum" : 0.3003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 7, "hscan" : { "minimum" : 0.2711, "maximum" : 0.2860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 8, "hscan" : { "minimum" : 0.2569, "maximum" : 0.2717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 9, "hscan" : { "minimum" : 0.2426, "maximum" : 0.2574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 10, "hscan" : { "minimum" : 0.2283, "maximum" : 0.2431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 11, "hscan" : { "minimum" : 0.2140, "maximum" : 0.2289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 12, "hscan" : { "minimum" : 0.1997, "maximum" : 0.2146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 13, "hscan" : { "minimum" : 0.1854, "maximum" : 0.2003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 14, "hscan" : { "minimum" : 0.1711, "maximum" : 0.1860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 15, "hscan" : { "minimum" : 0.1569, "maximum" : 0.1717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 16, "hscan" : { "minimum" : 0.1426, "maximum" : 0.1574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 17, "hscan" : { "minimum" : 0.1283, "maximum" : 0.1431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 18, "hscan" : { "minimum" : 0.1140, "maximum" : 0.1289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 19, "hscan" : { "minimum" : 0.0997, "maximum" : 0.1146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 20, "hscan" : { "minimum" : 0.0854, "maximum" : 0.1003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 21, "hscan" : { "minimum" : 0.0711, "maximum" : 0.0860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 22, "hscan" : { "minimum" : 0.0569, "maximum" : 0.0717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 23, "hscan" : { "minimum" : 0.0426, "maximum" : 0.0574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 24, "hscan" : { "minimum" : 0.0283, "maximum" : 0.0431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 25, "hscan" : { "minimum" : 0.0140, "maximum" : 0.0289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 26, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 27, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 28, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.9745, "maximum" : 1.0000 } }, { "index" : 29, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.9495, "maximum" : 0.9755 } }, { "index" : 30, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.9245, "maximum" : 0.9505 } }, { "index" : 31, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.8995, "maximum" : 0.9255 } }, { "index" : 32, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.8745, "maximum" : 0.9005 } }, { "index" : 33, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.8495, "maximum" : 0.8755 } }, { "index" : 34, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.8245, "maximum" : 0.8505 } }, { "index" : 35, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.7995, "maximum" : 0.8255 } }, { "index" : 36, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.7745, "maximum" : 0.8005 } }, { "index" : 37, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.7495, "maximum" : 0.7755 } }, { "index" : 38, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.7245, "maximum" : 0.7505 } }, { "index" : 39, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.6995, "maximum" : 0.7255 } }, { "index" : 40, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.6745, "maximum" : 0.7005 } }, { "index" : 41, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.6495, "maximum" : 0.6755 } }, { "index" : 42, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.6245, "maximum" : 0.6505 } }, { "index" : 43, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.5995, "maximum" : 0.6255 } }, { "index" : 44, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.5745, "maximum" : 0.6005 } }, { "index" : 45, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.5495, "maximum" : 0.5755 } }, { "index" : 46, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.5245, "maximum" : 0.5505 } }, { "index" : 47, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.4995, "maximum" : 0.5255 } }, { "index" : 48, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.4745, "maximum" : 0.5005 } }, { "index" : 49, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.4495, "maximum" : 0.4755 } }, { "index" : 50, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.4245, "maximum" : 0.4505 } }, { "index" : 51, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.3995, "maximum" : 0.4255 } }, { "index" : 52, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.3745, "maximum" : 0.4005 } }, { "index" : 53, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.3495, "maximum" : 0.3755 } }, { "index" : 54, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.3245, "maximum" : 0.3505 } }, { "index" : 55, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.2995, "maximum" : 0.3255 } }, { "index" : 56, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.2745, "maximum" : 0.3005 } }, { "index" : 57, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.2495, "maximum" : 0.2755 } }, { "index" : 58, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.2245, "maximum" : 0.2505 } }, { "index" : 59, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.1995, "maximum" : 0.2255 } }, { "index" : 60, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.1745, "maximum" : 0.2005 } }, { "index" : 61, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.1495, "maximum" : 0.1755 } }, { "index" : 62, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.1245, "maximum" : 0.1505 } }, { "index" : 63, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.0995, "maximum" : 0.1255 } }, { "index" : 64, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.0745, "maximum" : 0.1005 } }, { "index" : 65, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.0495, "maximum" : 0.0755 } }, { "index" : 66, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.0245, "maximum" : 0.0505 } }, { "index" : 67, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0255 } }, { "index" : 68, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 69, "hscan" : { "minimum" : 0.0000, "maximum" : 0.0146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 70, "hscan" : { "minimum" : 0.0140, "maximum" : 0.0289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 71, "hscan" : { "minimum" : 0.0283, "maximum" : 0.0431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 72, "hscan" : { "minimum" : 0.0426, "maximum" : 0.0574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 73, "hscan" : { "minimum" : 0.0569, "maximum" : 0.0717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 74, "hscan" : { "minimum" : 0.0711, "maximum" : 0.0860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 75, "hscan" : { "minimum" : 0.0854, "maximum" : 0.1003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 76, "hscan" : { "minimum" : 0.0997, "maximum" : 0.1146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 77, "hscan" : { "minimum" : 0.1140, "maximum" : 0.1289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 78, "hscan" : { "minimum" : 0.1283, "maximum" : 0.1431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 79, "hscan" : { "minimum" : 0.1426, "maximum" : 0.1574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 80, "hscan" : { "minimum" : 0.1569, "maximum" : 0.1717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 81, "hscan" : { "minimum" : 0.1711, "maximum" : 0.1860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 82, "hscan" : { "minimum" : 0.1854, "maximum" : 0.2003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 83, "hscan" : { "minimum" : 0.1997, "maximum" : 0.2146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 84, "hscan" : { "minimum" : 0.2140, "maximum" : 0.2289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 85, "hscan" : { "minimum" : 0.2283, "maximum" : 0.2431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 86, "hscan" : { "minimum" : 0.2426, "maximum" : 0.2574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 87, "hscan" : { "minimum" : 0.2569, "maximum" : 0.2717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 88, "hscan" : { "minimum" : 0.2711, "maximum" : 0.2860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 89, "hscan" : { "minimum" : 0.2854, "maximum" : 0.3003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 90, "hscan" : { "minimum" : 0.2997, "maximum" : 0.3146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 91, "hscan" : { "minimum" : 0.3140, "maximum" : 0.3289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 92, "hscan" : { "minimum" : 0.3283, "maximum" : 0.3431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 93, "hscan" : { "minimum" : 0.3426, "maximum" : 0.3574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 94, "hscan" : { "minimum" : 0.3569, "maximum" : 0.3717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 95, "hscan" : { "minimum" : 0.3711, "maximum" : 0.3860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 96, "hscan" : { "minimum" : 0.3854, "maximum" : 0.4003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 97, "hscan" : { "minimum" : 0.3997, "maximum" : 0.4146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 98, "hscan" : { "minimum" : 0.4140, "maximum" : 0.4289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 99, "hscan" : { "minimum" : 0.4283, "maximum" : 0.4431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 100, "hscan" : { "minimum" : 0.4426, "maximum" : 0.4574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 101, "hscan" : { "minimum" : 0.4569, "maximum" : 0.4717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 102, "hscan" : { "minimum" : 0.4711, "maximum" : 0.4860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 103, "hscan" : { "minimum" : 0.4854, "maximum" : 0.5003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 104, "hscan" : { "minimum" : 0.4997, "maximum" : 0.5146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 105, "hscan" : { "minimum" : 0.5140, "maximum" : 0.5289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 106, "hscan" : { "minimum" : 0.5283, "maximum" : 0.5431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 107, "hscan" : { "minimum" : 0.5426, "maximum" : 0.5574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 108, "hscan" : { "minimum" : 0.5569, "maximum" : 0.5717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 109, "hscan" : { "minimum" : 0.5711, "maximum" : 0.5860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 110, "hscan" : { "minimum" : 0.5854, "maximum" : 0.6003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 111, "hscan" : { "minimum" : 0.5997, "maximum" : 0.6146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 112, "hscan" : { "minimum" : 0.6140, "maximum" : 0.6289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 113, "hscan" : { "minimum" : 0.6283, "maximum" : 0.6431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 114, "hscan" : { "minimum" : 0.6426, "maximum" : 0.6574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 115, "hscan" : { "minimum" : 0.6569, "maximum" : 0.6717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 116, "hscan" : { "minimum" : 0.6711, "maximum" : 0.6860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 117, "hscan" : { "minimum" : 0.6854, "maximum" : 0.7003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 118, "hscan" : { "minimum" : 0.6997, "maximum" : 0.7146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 119, "hscan" : { "minimum" : 0.7140, "maximum" : 0.7289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 120, "hscan" : { "minimum" : 0.7283, "maximum" : 0.7431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 121, "hscan" : { "minimum" : 0.7426, "maximum" : 0.7574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 122, "hscan" : { "minimum" : 0.7569, "maximum" : 0.7717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 123, "hscan" : { "minimum" : 0.7711, "maximum" : 0.7860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 124, "hscan" : { "minimum" : 0.7854, "maximum" : 0.8003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 125, "hscan" : { "minimum" : 0.7997, "maximum" : 0.8146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 126, "hscan" : { "minimum" : 0.8140, "maximum" : 0.8289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 127, "hscan" : { "minimum" : 0.8283, "maximum" : 0.8431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 128, "hscan" : { "minimum" : 0.8426, "maximum" : 0.8574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 129, "hscan" : { "minimum" : 0.8569, "maximum" : 0.8717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 130, "hscan" : { "minimum" : 0.8711, "maximum" : 0.8860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 131, "hscan" : { "minimum" : 0.8854, "maximum" : 0.9003 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 132, "hscan" : { "minimum" : 0.8997, "maximum" : 0.9146 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 133, "hscan" : { "minimum" : 0.9140, "maximum" : 0.9289 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 134, "hscan" : { "minimum" : 0.9283, "maximum" : 0.9431 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 135, "hscan" : { "minimum" : 0.9426, "maximum" : 0.9574 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 136, "hscan" : { "minimum" : 0.9569, "maximum" : 0.9717 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 137, "hscan" : { "minimum" : 0.9711, "maximum" : 0.9860 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 138, "hscan" : { "minimum" : 0.9854, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 139, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 } }, { "index" : 140, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0000, "maximum" : 0.0255 } }, { "index" : 141, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0245, "maximum" : 0.0505 } }, { "index" : 142, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0495, "maximum" : 0.0755 } }, { "index" : 143, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0745, "maximum" : 0.1005 } }, { "index" : 144, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.0995, "maximum" : 0.1255 } }, { "index" : 145, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.1245, "maximum" : 0.1505 } }, { "index" : 146, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.1495, "maximum" : 0.1755 } }, { "index" : 147, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.1745, "maximum" : 0.2005 } }, { "index" : 148, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.1995, "maximum" : 0.2255 } }, { "index" : 149, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.2245, "maximum" : 0.2505 } }, { "index" : 150, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.2495, "maximum" : 0.2755 } }, { "index" : 151, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.2745, "maximum" : 0.3005 } }, { "index" : 152, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.2995, "maximum" : 0.3255 } }, { "index" : 153, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.3245, "maximum" : 0.3505 } }, { "index" : 154, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.3495, "maximum" : 0.3755 } }, { "index" : 155, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.3745, "maximum" : 0.4005 } }, { "index" : 156, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.3995, "maximum" : 0.4255 } }, { "index" : 157, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.4245, "maximum" : 0.4505 } }, { "index" : 158, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.4495, "maximum" : 0.4755 } }, { "index" : 159, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.4745, "maximum" : 0.5005 } }, { "index" : 160, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.4995, "maximum" : 0.5255 } }, { "index" : 161, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.5245, "maximum" : 0.5505 } }, { "index" : 162, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.5495, "maximum" : 0.5755 } }, { "index" : 163, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.5745, "maximum" : 0.6005 } }, { "index" : 164, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.5995, "maximum" : 0.6255 } }, { "index" : 165, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.6245, "maximum" : 0.6505 } }, { "index" : 166, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.6495, "maximum" : 0.6755 } }, { "index" : 167, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.6745, "maximum" : 0.7005 } }, { "index" : 168, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.6995, "maximum" : 0.7255 } }, { "index" : 169, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.7245, "maximum" : 0.7505 } }, { "index" : 170, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.7495, "maximum" : 0.7755 } }, { "index" : 171, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.7745, "maximum" : 0.8005 } }, { "index" : 172, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.7995, "maximum" : 0.8255 } }, { "index" : 173, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.8245, "maximum" : 0.8505 } }, { "index" : 174, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.8495, "maximum" : 0.8755 } }, { "index" : 175, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.8745, "maximum" : 0.9005 } }, { "index" : 176, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.8995, "maximum" : 0.9255 } }, { "index" : 177, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.9245, "maximum" : 0.9505 } }, { "index" : 178, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.9495, "maximum" : 0.9755 } }, { "index" : 179, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.9745, "maximum" : 1.0000 } }, { "index" : 180, "hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 181, "hscan" : { "minimum" : 0.9854, "maximum" : 1.0000 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 182, "hscan" : { "minimum" : 0.9711, "maximum" : 0.9860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 183, "hscan" : { "minimum" : 0.9569, "maximum" : 0.9717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 184, "hscan" : { "minimum" : 0.9426, "maximum" : 0.9574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 185, "hscan" : { "minimum" : 0.9283, "maximum" : 0.9431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 186, "hscan" : { "minimum" : 0.9140, "maximum" : 0.9289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 187, "hscan" : { "minimum" : 0.8997, "maximum" : 0.9146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 188, "hscan" : { "minimum" : 0.8854, "maximum" : 0.9003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 189, "hscan" : { "minimum" : 0.8711, "maximum" : 0.8860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 190, "hscan" : { "minimum" : 0.8569, "maximum" : 0.8717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 191, "hscan" : { "minimum" : 0.8426, "maximum" : 0.8574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 192, "hscan" : { "minimum" : 0.8283, "maximum" : 0.8431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 193, "hscan" : { "minimum" : 0.8140, "maximum" : 0.8289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 194, "hscan" : { "minimum" : 0.7997, "maximum" : 0.8146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 195, "hscan" : { "minimum" : 0.7854, "maximum" : 0.8003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 196, "hscan" : { "minimum" : 0.7711, "maximum" : 0.7860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 197, "hscan" : { "minimum" : 0.7569, "maximum" : 0.7717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 198, "hscan" : { "minimum" : 0.7426, "maximum" : 0.7574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 199, "hscan" : { "minimum" : 0.7283, "maximum" : 0.7431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 200, "hscan" : { "minimum" : 0.7140, "maximum" : 0.7289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 201, "hscan" : { "minimum" : 0.6997, "maximum" : 0.7146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 202, "hscan" : { "minimum" : 0.6854, "maximum" : 0.7003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 203, "hscan" : { "minimum" : 0.6711, "maximum" : 0.6860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 204, "hscan" : { "minimum" : 0.6569, "maximum" : 0.6717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 205, "hscan" : { "minimum" : 0.6426, "maximum" : 0.6574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 206, "hscan" : { "minimum" : 0.6283, "maximum" : 0.6431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 207, "hscan" : { "minimum" : 0.6140, "maximum" : 0.6289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 208, "hscan" : { "minimum" : 0.5997, "maximum" : 0.6146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 209, "hscan" : { "minimum" : 0.5854, "maximum" : 0.6003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 210, "hscan" : { "minimum" : 0.5711, "maximum" : 0.5860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 211, "hscan" : { "minimum" : 0.5569, "maximum" : 0.5717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 212, "hscan" : { "minimum" : 0.5426, "maximum" : 0.5574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 213, "hscan" : { "minimum" : 0.5283, "maximum" : 0.5431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 214, "hscan" : { "minimum" : 0.5140, "maximum" : 0.5289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 215, "hscan" : { "minimum" : 0.4997, "maximum" : 0.5146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 216, "hscan" : { "minimum" : 0.4854, "maximum" : 0.5003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 217, "hscan" : { "minimum" : 0.4711, "maximum" : 0.4860 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 218, "hscan" : { "minimum" : 0.4569, "maximum" : 0.4717 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 219, "hscan" : { "minimum" : 0.4426, "maximum" : 0.4574 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 220, "hscan" : { "minimum" : 0.4283, "maximum" : 0.4431 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 221, "hscan" : { "minimum" : 0.4140, "maximum" : 0.4289 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 222, "hscan" : { "minimum" : 0.3997, "maximum" : 0.4146 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } }, { "index" : 223, "hscan" : { "minimum" : 0.3854, "maximum" : 0.4003 }, "vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 } } ], /// The black border configuration, contains the following items: /// * enable : true if the detector should be activated /// * threshold : Value below which a pixel is regarded as black (value between 0.0 and 1.0) "blackborderdetector" : { "enable" : true, "threshold" : 0.01 }, /// The configuration of the effect engine, contains the following items: /// * paths : An array with absolute location(s) of directories with effects /// * bootsequence : The effect selected as 'boot sequence' "effects" : { "paths" : [ "/storage/hyperion/effects" ] }, "bootsequence" : { "effect" : "Rainbow swirl fast", "duration_ms" : 3000 }, /// The configuration for the frame-grabber, contains the following items: /// * width : The width of the grabbed frames [pixels] /// * height : The height of the grabbed frames [pixels] /// * frequency_Hz : The frequency of the frame grab [Hz] "framegrabber" : { "width" : 123, "height" : 70, "frequency_Hz" : 10.0 }, /// The configuration of the XBMC connection used to enable and disable the frame-grabber. Contains the following fields: /// * xbmcAddress : The IP address of the XBMC-host /// * xbmcTcpPort : The TCP-port of the XBMC-server /// * grabVideo : Flag indicating that the frame-grabber is on(true) during video playback /// * grabPictures : Flag indicating that the frame-grabber is on(true) during picture show /// * grabAudio : Flag indicating that the frame-grabber is on(true) during audio playback /// * grabMenu : Flag indicating that the frame-grabber is on(true) in the XBMC menu /// * grabScreensaver : Flag indicating that the frame-grabber is on(true) when XBMC is on screensaver /// * enable3DDetection : Flag indicating that the frame-grabber should switch to a 3D compatible modus if a 3D video is playing "xbmcVideoChecker" : { "xbmcAddress" : "127.0.0.1", "xbmcTcpPort" : 9090, "grabVideo" : false, "grabPictures" : false, "grabAudio" : false, "grabMenu" : false, "grabScreensaver" : false, "enable3DDetection" : false }, /// The configuration of the Json server which enables the json remote interface /// * port : Port at which the json server is started "jsonServer" : { "port" : 19444 }, /// The configuration of the Proto server which enables the protobuffer remote interface /// * port : Port at which the protobuffer server is started "protoServer" : { "port" : 19445 }, /// The configuration of the boblight server which enables the boblight remote interface /// * port : Port at which the boblight server is started "boblightServer" : { "port" : 19333 }, "endOfJson" : "endOfJson" }
Hallo
ich habe jetzt folgendes auskommentiert wie auf dem Bild zu sehen ist. Es kommt aber nach wie vor immer noch wenn ich die Dreambox in Standby schalte das Ambilight des Openelec Desktop
Hmmmmmmmm...........
wie blende ich das in der config aus?
ich vermute es liegt am raspberry. ich habe boblight 8r5 installiert. immer wenn ich die dreambox in standby schalte geht wieder das ambilight des openelec hintergrund an
Welche boblight version verwendest du?
mir geht es nur um ambilight von der Dreambox. das ist die einzige funktion die ich benötige. und wenn die Dreambox auf Standby geht sollte das Ambilight AUS sein.
ist bei mir leider auf false
Hallo
wie komme ich in die Config des XBMC?
Ich habe jetzt Boblight installiert. Nun Schaltet sich das Ambilight der Dreambox im Standby ab, dafür schaltet der Raspi auf das Ambilight des Hyperion Openelec Background um. gibt es da noch einen Trick wie ich das auch noch ausschalten kann?
Hallo
ich betreibe Hyperion auf dem Raspberry. Auf der Dreambox habe ich das Enigmalight Plugin installiert. Wenn ich die Dreambox in den Standby schalte zeigen die LED die letzten Farben an und schalten nicht aus. Was muss ich machen damit die LED mit der Ausschalten der Dreambox auch auf "SCHWARZ" schalten??
Gruss Dream
Hallo
ich bin jetzt auch auf Hyperion umgestiegen und siehe da es läuft ohne Probleme.
Danke für den Tipp:
Jetzt läuft es mit LPD8806 LED, Dreambox mit neustem Enigmalight Plugin und Raspberry tadellos. -
Hallo zusammen.
läuft denn der Pi mit der länge der LED problemlos? ich habe das problem bei meinem 55 Zoll mit LPD8806 dass der Raspberry kurz nach dem start auf 90 % CPU last geht. ist das bei euch auch so? was habt ihr denn für ein config file?
gruss dreamoffice
Hallo Maxxe88
ich habe gerade das selbe vor wie du. die installation sollte bei dir eigentlich funktionieren mit der enigma2-plugin-extensions-boblight-enigma2_0.8r5_mips32el.ipk
ich habe auch die letzte version von newnigma2 auf der dm800se und die geht bei mir.bei mir macht gerade die boblight.conf probleme.
Hallo Tode
ich habe gleiches vor wie du. hast du deine konfiguration ans laufen bekommen?
