Ich habe eine 6490 und hatte DS-Lite. Habe ich aber auf eine normale IPv4 wieder umstellen lassen. Da die VPN der FritzBox nicht mehr ging.
Entweder per Putty oder über DynDNS im Browser.
pi@raspberrypi:~ $ sudo tcpdump -c 50 -vvveni eth0 dst port 22 or dst port 9981
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
08:39:03.591046 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47098, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0xa1cc (correct), seq 1205100188, ack 330460990, win 512, length 0
08:39:03.592550 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47099, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0xa02e (correct), seq 0, ack 417, win 510, length 0
08:39:03.595560 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47100, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x9ea0 (correct), seq 0, ack 817, win 508, length 0
08:39:03.598767 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47101, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x9d0b (correct), seq 0, ack 1217, win 513, length 0
08:39:03.599956 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47102, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x9b7d (correct), seq 0, ack 1617, win 511, length 0
08:39:03.602844 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47103, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x99ee (correct), seq 0, ack 2017, win 510, length 0
08:39:03.604032 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47104, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x9860 (correct), seq 0, ack 2417, win 508, length 0
08:39:03.607010 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47105, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x96cb (correct), seq 0, ack 2817, win 513, length 0
08:39:03.608091 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47106, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x953d (correct), seq 0, ack 3217, win 511, length 0
08:39:03.611122 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47107, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x93ae (correct), seq 0, ack 3617, win 510, length 0
08:39:03.612405 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47108, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x9220 (correct), seq 0, ack 4017, win 508, length 0
08:39:03.615268 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47109, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x908b (correct), seq 0, ack 4417, win 513, length 0
08:39:03.616593 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47110, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x8efd (correct), seq 0, ack 4817, win 511, length 0
08:39:03.619656 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47111, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x8d6e (correct), seq 0, ack 5217, win 510, length 0
08:39:03.620967 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47112, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x8be0 (correct), seq 0, ack 5617, win 508, length 0
08:39:03.623789 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47113, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x8a4b (correct), seq 0, ack 6017, win 513, length 0
08:39:03.625189 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47114, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x88bd (correct), seq 0, ack 6417, win 511, length 0
08:39:03.628163 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47115, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x872e (correct), seq 0, ack 6817, win 510, length 0
08:39:03.629317 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47116, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x85a0 (correct), seq 0, ack 7217, win 508, length 0
08:39:03.632390 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47117, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x840b (correct), seq 0, ack 7617, win 513, length 0
08:39:03.636471 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47118, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x827d (correct), seq 0, ack 8017, win 511, length 0
08:39:03.636947 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 214: (tos 0x0, ttl 128, id 47119, offset 0, flags [DF], proto TCP (6), length 200)
192.168.178.57.64750 > 192.168.178.23.22: Flags [P.], cksum 0x1439 (correct), seq 0:160, ack 8017, win 511, length 160
08:39:03.638253 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47120, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x804e (correct), seq 160, ack 8417, win 510, length 0
08:39:03.638288 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47121, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x7ec0 (correct), seq 160, ack 8817, win 508, length 0
08:39:03.639408 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47122, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x7d9b (correct), seq 160, ack 9105, win 513, length 0
08:39:03.640059 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47123, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x7b9d (correct), seq 160, ack 9617, win 511, length 0
08:39:03.640845 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47124, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x7a7e (correct), seq 160, ack 9905, win 510, length 0
08:39:03.641497 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47125, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x78f0 (correct), seq 160, ack 10305, win 508, length 0
08:39:03.642111 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47126, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x775b (correct), seq 160, ack 10705, win 513, length 0
08:39:03.643013 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47127, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x75cd (correct), seq 160, ack 11105, win 511, length 0
08:39:03.643629 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47128, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x743e (correct), seq 160, ack 11505, win 510, length 0
08:39:03.644005 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47129, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x72b0 (correct), seq 160, ack 11905, win 508, length 0
08:39:03.646853 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47130, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x706b (correct), seq 160, ack 12481, win 513, length 0
08:39:03.646909 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47131, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x6edd (correct), seq 160, ack 12881, win 511, length 0
08:39:03.647823 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47132, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x6dfe (correct), seq 160, ack 13105, win 510, length 0
08:39:03.648739 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47133, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x6bf0 (correct), seq 160, ack 13633, win 508, length 0
08:39:03.649095 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47134, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x6ad1 (correct), seq 160, ack 13921, win 507, length 0
08:39:03.652108 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47135, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x693b (correct), seq 160, ack 14321, win 513, length 0
08:39:03.652142 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47136, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x67ad (correct), seq 160, ack 14721, win 511, length 0
08:39:03.653395 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47137, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x661e (correct), seq 160, ack 15121, win 510, length 0
08:39:03.656513 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47138, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x62eb (correct), seq 160, ack 15937, win 513, length 0
08:39:03.659695 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47139, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x615d (correct), seq 160, ack 16337, win 511, length 0
08:39:03.660698 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47140, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x5fce (correct), seq 160, ack 16737, win 510, length 0
08:39:03.661703 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47141, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x5e40 (correct), seq 160, ack 17137, win 508, length 0
08:39:03.664670 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47142, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x5cab (correct), seq 160, ack 17537, win 513, length 0
08:39:03.667631 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47143, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x5b1d (correct), seq 160, ack 17937, win 511, length 0
08:39:03.668646 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47144, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x58df (correct), seq 160, ack 18513, win 509, length 0
08:39:03.669611 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47145, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x5800 (correct), seq 160, ack 18737, win 508, length 0
08:39:03.670542 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47146, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x566b (correct), seq 160, ack 19137, win 513, length 0
08:39:03.673583 08:11:96:27:83:10 > dc:a6:32:05:51:81, ethertype IPv4 (0x0800), length 60: (tos 0x0, ttl 128, id 47147, offset 0, flags [DF], proto TCP (6), length 40)
192.168.178.57.64750 > 192.168.178.23.22: Flags [.], cksum 0x54dd (correct), seq 160, ack 19537, win 511, length 0
50 packets captured
51 packets received by filter
0 packets dropped by kernel
Als DynDNS Anbieter benutze ich ddnss.de und habe es auf der FritzBox eingetragen.
Auf allen anderen Geräten funktioniert die Freigabe über die FritzBox. Auf dem Pi mit privoxy ging es erst nach der Installation nicht mehr. Also muß es doch was mit dem Programm zu tun haben?!?
