Repeater noch an. Das sind die Ergebnisse:
pi@solaranzeige:~ $ lsusb
Bus 001 Device 005: ID 2357:0108 TP-Link TL-WN822N Version 4 RTL8192EU
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
pi@solaranzeige:~ $ lsmod
Module Size Used by
fuse 126976 3
joydev 20480 0
sg 28672 0
st 65536 0
sr_mod 24576 0
cdrom 40960 1 sr_mod
8021q 32768 0
garp 16384 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
ch341 16384 1
usbserial 36864 3 ch341
brcmfmac 327680 0
brcmutil 20480 1 brcmfmac
sha256_generic 16384 0
cfg80211 761856 1 brcmfmac
rfkill 32768 4 cfg80211
raspberrypi_hwmon 16384 0
bcm2835_codec 40960 0
bcm2835_v4l2 40960 0
bcm2835_isp 32768 0
v4l2_mem2mem 36864 1 bcm2835_codec
snd_bcm2835 24576 2
bcm2835_mmal_vchiq 32768 3 bcm2835_isp,bcm2835_codec,bcm2835_v4l2
videobuf2_dma_contig 20480 2 bcm2835_isp,bcm2835_codec
videobuf2_vmalloc 16384 1 bcm2835_v4l2
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
videobuf2_v4l2 32768 4 bcm2835_isp,bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
videobuf2_common 61440 5 bcm2835_isp,bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
snd_pcm 110592 1 snd_bcm2835
snd_timer 32768 1 snd_pcm
videodev 249856 6 bcm2835_isp,bcm2835_codec,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
snd 77824 7 snd_timer,snd_bcm2835,snd_pcm
vc_sm_cma 32768 6 bcm2835_isp,bcm2835_mmal_vchiq
mc 45056 6 bcm2835_isp,bcm2835_codec,videobuf2_common,videodev,v4l2_mem2mem,videobuf2_v4l2
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
fixed 16384 0
i2c_dev 20480 0
ip_tables 28672 0
x_tables 32768 1 ip_tables
ipv6 495616 73
pi@solaranzeige:~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:"MOVISTAR_0EB0"
Mode:Managed Frequency:2.462 GHz Access Point: 94:91:7F:90:0E:BF
Bit Rate=1 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=19/70 Signal level=-91 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1685 Invalid misc:0 Missed beacon:0
pi@solaranzeige:~ $ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:3f:06:cb brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:6a:53:9e brd ff:ff:ff:ff:ff:ff
inet 192.168.1.37/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
valid_lft 40475sec preferred_lft 35075sec
inet6 fe80::8bca:da46:c7e3:eb0a/64 scope link
pi@solaranzeige:~ $ ip r
default via 192.168.1.1 dev wlan0 proto dhcp src 192.168.1.37 metric 303
192.168.1.0/24 dev wlan0 proto dhcp scope link src 192.168.1.37 metric 303
pi@solaranzeige:~ $ ip n s
80.58.61.254 dev wlan0 FAILED
80.58.61.250 dev wlan0 FAILED
192.168.1.33 dev wlan0 lladdr 10:bf:48:14:d1:97 REACHABLE
192.168.1.1 dev wlan0 lladdr 94:91:7f:90:0e:b0 STALE
192.168.1.36 dev wlan0 lladdr 32:70:f9:b0:66:b0 STALE
fe80::9691:7fff:fe90:eb0 dev wlan0 lladdr 94:91:7f:90:0e:b0 router REACHABLE
