Posts by Saharaharry
    Das bekomme ich, wenn ich thonny im Terminalfenster starte : (Das war schon mal einen gute Idee)
    pi@raspberrypi:/usr/share/applications $ thonny
    ERROR:root:Internal launch or mainloop error
    File "/usr/lib/python3/dist-packages/thonny/__init__.py", line 165, in launch
    bench = workbench.Workbench()
    File "/usr/lib/python3/dist-packages/thonny/workbench.py", line 130, in __init__
    self._init_configuration()
    File "/usr/lib/python3/dist-packages/thonny/workbench.py", line 231, in _init_configuration
    self._configuration_manager = try_load_configuration(thonny.CONFIGURATION_FILE)
    File "/usr/lib/python3/dist-packages/thonny/config.py", line 25, in try_load_configuration
    mgr = ConfigurationManager(filename)
    File "/usr/lib/python3/dist-packages/thonny/config.py", line 53, in __init__
    self._ini.read_file(fp)
    File "/usr/lib/python3.7/configparser.py", line 717, in read_file
    self._read(f, source)
    File "/usr/lib/python3.7/configparser.py", line 1014, in _read
    for lineno, line in enumerate(fp, start=1):
    File "/usr/lib/python3.7/codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
    UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa6 in position 28: invalid start byte
    During handling of the above exception, another exception occurred:
    File "/usr/bin/thonny", line 11, in <module>
    load_entry_point('thonny==3.2.6', 'gui_scripts', 'thonny')()
    File "/usr/lib/python3/dist-packages/thonny/__init__.py", line 185, in launch
    ui_utils.show_dialog(dlg, get_workbench())
    File "/usr/lib/python3/dist-packages/thonny/ui_utils.py", line 2087, in show_dialog
    get_workbench().event_generate("WindowFocusOut")
    File "/usr/lib/python3/dist-packages/thonny/workbench.py", line 1587, in event_generate
    if sequence in self._event_handlers:
    File "/usr/lib/python3.7/tkinter/__init__.py", line 2101, in __getattr__
    return getattr(self.tk, attr)
    [Previous line repeated 495 more times]
    RecursionError: maximum recursion depth exceeded while calling a Python object
    Beim Starten von Thonny erscheint die Sanduhr und verschwindet nach einigen Sekunden. Das Fenster geht nicht auf. Es gibt keine Fehlermeldung. Auch in log-Files nichts gefunden.
    Wer kann mir weiterhelfen oder hat eine Idee ? Ich bin ratlos.
