Was meinst du mit Quelle?
Kodi mit MKV´s
Extern Playstation 4
Oder was meinst du????
Kodi mit MKV´s
SSH Traffic:
ssh connected
ssh out: cat /storage/logfiles/hyperion.log
ssh in: Hyperion Ambilight Deamon (394)
ssh in: Version : V1.03.2 (brindosch-99d9396/d3713a8-1469452981
ssh in: Build Time: Jul 25 2016 06:54:40
ssh in: INFO: Selected configuration file: /storage/.config/hyperion.config.json
ssh in: HYPERION INFO: ColorTransform 'default' => [0; 89]
ssh in: HYPERION INFO: ColorCorrection 'default' => [0; 89]
ssh in: HYPERION INFO: ColorAdjustment 'default' => [0; 89]
ssh in: LEDDEVICE INFO: configuration:
ssh in: {
ssh in: "colorOrder" : "bgr",
ssh in: "name" : "MyHyperionConfig",
ssh in: "output" : "/dev/spidev0.0",
ssh in: "rate" : 1000000,
ssh in: "type" : "apa102"
ssh in: }
ssh in: INFO: Creating linear smoothing
ssh in: HYPERION (CS) INFO: Created linear-smoothing(interval_ms=40;settlingTime_ms=100;updateDelay=0
ssh in: EFFECTENGINE INFO: 27 effects loaded from directory /storage/hyperion/effects
ssh in: EFFECTENGINE INFO: Initializing Python interpreter
ssh in: INFO: Hyperion started and initialised
ssh in: INFO: Boot sequence 'Rainbow swirl' EFFECTENGINE INFO: run effect Rainbow swirl on channel 0
ssh in: BLACKBORDER INFO: threshold set to 0 (0)
ssh in: BLACKBORDER INFO: mode:default
ssh in: started
ssh in: INFO: Kodi checker created and started
ssh in: INFO: Json server created and started on port 19444
ssh in: INFO: Proto server created and started on port 19445
ssh in: DISPMANXGRABBER INFO: Display opened with resolution: 1920x1080
ssh in: INFO: Frame grabber created and started
ssh in: V4L2GRABBER INFO: width=720 height=576
ssh in: V4L2GRABBER INFO: pixel format=YUYV
ssh in: V4L2GRABBER INFO: signal threshold set to: {0,0,0}
ssh in: V4L2GRABBER INFO: started
ssh in: INFO: V4L2 grabber created and started
ssh in: KODICHECK ERROR: Kodi Connection error (0)
ssh in: BORDER SWITCH REQUIRED!!
ssh in: CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=0
ssh in: V4L2GRABBER INFO: stopped
ssh in: EFFECTENGINE INFO: effect finished
ssh in: KODICHECK INFO: Kodi Connected
ssh in: KODICHECK INFO: switching to MENU mode
ssh in: JSONSERVER INFO: New connection
ssh in: JSONSERVER INFO: Connection closed
Wie wäre es wenn du mal den Log von Hyperion postest? Siehe Reiter SSH!Dann sehen wir weiter!
Und überhaupt was geht denn nicht?!? -> Es leuchtet gar nichts mehr, bis gestern ging noch alles sowohl Kodi und auch der exteren Grabber. Schalte es immer um...
Kannst du dich mit der App verbinden? -> Ja mit der App kann ich mich verbinden aber es leuchtet nichts
Funktionieren die Effekte?!? -> Nein gar nichts
Du siehst fragen über Fragen!Mfg
Automatisch zusammengefügt:
Fotos vom Aufbau?
Vorallem was nutzt du als Quelle?!
habe überall 4,6-5,5V anliegen.
mein Ambilight läuft seit Monaten gut.
Seit gestern geht gar nichts mehr.
Strom, HyperCon usw. alles gecheckt.
Habe jetzt Openelec neu installiert und alles neu gemacht.
Hier mal die config.
Fällt euch etwas auf????
Kann es sein das die APA 102 defekt sind?
Wie bekommt man das raus?
Danke für eure Unterstützung...
// Automatically generated configuration file for Hyperion ambilight daemon
// Notice: All values are explained with comments at our wiki: wiki.hyperion-project.org (config area)
// Generated by: HyperCon (The Hyperion deamon configuration file builder)
// Created with HyperCon V1.03.1 (11.06.2016)
// DEVICE CONFIGURATION
"device" :
"type" : "apa102",
"rate" : 1000000,
// COLOR CALIBRATION CONFIG
"color" :
"channelAdjustment" :
"id" : "default",
"leds" : "*",
"pureRed" :
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"pureGreen" :
"redChannel" : 0,
"greenChannel" : 255,
"blueChannel" : 0
"pureBlue" :
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 255
"temperature" :
"id" : "default",
"leds" : "*",
"correctionValues" :
"red" : 255,
"green" : 255,
"blue" : 255
"transform" :
"id" : "default",
"leds" : "*",
"hsl" :
"saturationGain" : 1.0000,
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"red" :
"threshold" : 0.0000,
"gamma" : 2.5000
"green" :
"gamma" : 2.5000
"blue" :
"gamma" : 2.5000
// SMOOTHING CONFIG
"smoothing" :
"type" : "linear",
"time_ms" : 100,
"updateFrequency" : 25.0000,
"updateDelay" : 0
// V4L2 GRABBER CONFIG
"grabber-v4l2" :
"device" : "/dev/video0",
"input" : 0,
"standard" : "PAL",
"width" : -1,
"height" : -1,
"frameDecimation" : 2,
"sizeDecimation" : 4,
"priority" : 800,
"mode" : "2D",
"cropLeft" : 6,
"cropRight" : 6,
"cropTop" : 2,
"cropBottom" : 2,
"redSignalThreshold" : 0.1,
"greenSignalThreshold" : 0.1,
"blueSignalThreshold" : 0.1
// FRAME GRABBER CONFIG
"framegrabber" :
"width" : 64,
"height" : 64,
"frequency_Hz" : 10.0,
"priority" : 890
// BLACKBORDER CONFIG
"blackborderdetector" :
"enable" : true,
"threshold" : 0.0,
"unknownFrameCnt" : 600,
"borderFrameCnt" : 50,
"maxInconsistentCnt" : 10,
"blurRemoveCnt" : 1,
"mode" : "default"
// KODI CHECK CONFIG
"xbmcVideoChecker" :
"xbmcAddress" : "127.0.0.1",
"xbmcTcpPort" : 9090,
"grabVideo" : true,
"grabPictures" : true,
"grabAudio" : false,
"grabMenu" : true,
"grabPause" : true,
"grabScreensaver" : true,
"enable3DDetection" : true
// BOOTEFFECT CONFIG
"bootsequence" :
"color" : [0,0,0],
"effect" : "Rainbow swirl",
"duration_ms" : 30000,
"priority" : 800
// JSON SERVER CONFIG
"jsonServer" :
"port" : 19444
// PROTO SERVER CONFIG
"protoServer" :
"port" : 19445
// EFFECT PATH
"effects" :
"paths" :
"/storage/hyperion/effects",
"/usr/share/hyperion/effects"
// NO BOBLIGHT SERVER CONFIG
// NO JSON/PROTO FORWARD CONFIG
// LED CONFIGURATION
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.6129, "maximum" : 0.6452 },
"vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
"index" : 1,
"hscan" : { "minimum" : 0.6452, "maximum" : 0.6774 },
"index" : 2,
"hscan" : { "minimum" : 0.6774, "maximum" : 0.7097 },
"index" : 3,
"hscan" : { "minimum" : 0.7097, "maximum" : 0.7419 },
"index" : 4,
"hscan" : { "minimum" : 0.7419, "maximum" : 0.7742 },
"index" : 5,
"hscan" : { "minimum" : 0.7742, "maximum" : 0.8065 },
"index" : 6,
"hscan" : { "minimum" : 0.8065, "maximum" : 0.8387 },
"index" : 7,
"hscan" : { "minimum" : 0.8387, "maximum" : 0.8710 },
"index" : 8,
"hscan" : { "minimum" : 0.8710, "maximum" : 0.9032 },
"index" : 9,
"hscan" : { "minimum" : 0.9032, "maximum" : 0.9355 },
"index" : 10,
"hscan" : { "minimum" : 0.9355, "maximum" : 0.9677 },
"index" : 11,
"hscan" : { "minimum" : 0.9677, "maximum" : 1.0000 },
"index" : 12,
"hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.9412, "maximum" : 1.0000 }
"index" : 13,
"vscan" : { "minimum" : 0.8824, "maximum" : 0.9412 }
"index" : 14,
"vscan" : { "minimum" : 0.8235, "maximum" : 0.8824 }
"index" : 15,
"vscan" : { "minimum" : 0.7647, "maximum" : 0.8235 }
"index" : 16,
"vscan" : { "minimum" : 0.7059, "maximum" : 0.7647 }
"index" : 17,
"vscan" : { "minimum" : 0.6471, "maximum" : 0.7059 }
"index" : 18,
"vscan" : { "minimum" : 0.5882, "maximum" : 0.6471 }
"index" : 19,
"vscan" : { "minimum" : 0.5294, "maximum" : 0.5882 }
"index" : 20,
"vscan" : { "minimum" : 0.4706, "maximum" : 0.5294 }
"index" : 21,
"vscan" : { "minimum" : 0.4118, "maximum" : 0.4706 }
"index" : 22,
"vscan" : { "minimum" : 0.3529, "maximum" : 0.4118 }
"index" : 23,
"vscan" : { "minimum" : 0.2941, "maximum" : 0.3529 }
"index" : 24,
"vscan" : { "minimum" : 0.2353, "maximum" : 0.2941 }
"index" : 25,
"vscan" : { "minimum" : 0.1765, "maximum" : 0.2353 }
"index" : 26,
"vscan" : { "minimum" : 0.1176, "maximum" : 0.1765 }
"index" : 27,
"vscan" : { "minimum" : 0.0588, "maximum" : 0.1176 }
"index" : 28,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0588 }
"index" : 29,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
"index" : 30,
"index" : 31,
"index" : 32,
"index" : 33,
"index" : 34,
"index" : 35,
"index" : 36,
"index" : 37,
"index" : 38,
"index" : 39,
"index" : 40,
"index" : 41,
"hscan" : { "minimum" : 0.5806, "maximum" : 0.6129 },
"index" : 42,
"hscan" : { "minimum" : 0.5484, "maximum" : 0.5806 },
"index" : 43,
"hscan" : { "minimum" : 0.5161, "maximum" : 0.5484 },
"index" : 44,
"hscan" : { "minimum" : 0.4839, "maximum" : 0.5161 },
"index" : 45,
"hscan" : { "minimum" : 0.4516, "maximum" : 0.4839 },
"index" : 46,
"hscan" : { "minimum" : 0.4194, "maximum" : 0.4516 },
"index" : 47,
"hscan" : { "minimum" : 0.3871, "maximum" : 0.4194 },
"index" : 48,
"hscan" : { "minimum" : 0.3548, "maximum" : 0.3871 },
"index" : 49,
"hscan" : { "minimum" : 0.3226, "maximum" : 0.3548 },
"index" : 50,
"hscan" : { "minimum" : 0.2903, "maximum" : 0.3226 },
"index" : 51,
"hscan" : { "minimum" : 0.2581, "maximum" : 0.2903 },
"index" : 52,
"hscan" : { "minimum" : 0.2258, "maximum" : 0.2581 },
"index" : 53,
"hscan" : { "minimum" : 0.1935, "maximum" : 0.2258 },
"index" : 54,
"hscan" : { "minimum" : 0.1613, "maximum" : 0.1935 },
"index" : 55,
"hscan" : { "minimum" : 0.1290, "maximum" : 0.1613 },
"index" : 56,
"hscan" : { "minimum" : 0.0968, "maximum" : 0.1290 },
"index" : 57,
"hscan" : { "minimum" : 0.0645, "maximum" : 0.0968 },
"index" : 58,
"hscan" : { "minimum" : 0.0323, "maximum" : 0.0645 },
"index" : 59,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0323 },
"index" : 60,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
"index" : 61,
"index" : 62,
"index" : 63,
"index" : 64,
"index" : 65,
"index" : 66,
"index" : 67,
"index" : 68,
"index" : 69,
"index" : 70,
"index" : 71,
"index" : 72,
"index" : 73,
"index" : 74,
"index" : 75,
"index" : 76,
"index" : 77,
"index" : 78,
"index" : 79,
"index" : 80,
"index" : 81,
"index" : 82,
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
"index" : 88,
"index" : 89,
"endOfJson" : "endOfJson"
Sorry ist noch ein alter Screenshot vom Hyperion.
Ist alles auf 255,255,255.
Hab auch schon probiert den Weißwert einzustellen über die Reiter.
Problem ist eher das ich kein grün hinbekomme.
Meinst du die Spannung reicht nicht aus?
Was bedeutet Treiberproblem? Vom Pi oder von den WS2802 aus?
Hab alle 6 Profile schon durch probiert.
Die Farben passen bei keinem Profil
Hi zusammen,
habe noch mal alles gecheckt. Am Netzteil habe ich eine weitere Einspeisung vorgenommen. Jetzt sind unten 5,2V und oben 4,8V.
Sollte reichen, oder.
Habe auch mal ein anderes System OSMC probiert.
Immer wieder das gleiche Problem:
Hyperion auf RGB, Grün und Blau vertauscht.
Stelle ich auf RBG um passen rot und blau, grün wird aber überhaupt nicht dargestellt ( sieht alles nach blau aus).
und weiß ist ziemlich rosa/pink.
Bin langsam am verzweifeln.
Jemand noch ein guten Tipp????
Ich würde die Eckverbinder immer verlöten. Am Bildschirm würde ich die LEDs nicht ankleben, da diese einiges an Wärme abgeben. Immer besser auf alu Profile kleben zur Kühlung optimal.
Das Netzteil muss noch in eine Verteilerdose. Ansonsten hast du offen 230V...
Danke, werde ich mal beherzigen mit dem Netzteil.
Ist das mit dem Aluprofil dringend notwendig?
Was passiert sonst?
Hi, danke für die Antworten.
Habe mal am Anfang gemessen 4,7V und dann wird es nach dem ersten Eckverbinder schon weniger 3,7.... Am Ende habe ich wieder 4,7 da ich dort noch mal Strom angeschlossen habe.
Sollte ich die Eckverbinder lieber rausnehmen und alles verlöten?
Das überprüft man wie???
ich bin Neuling und habe das Ambilight Projekt mal umgesetzt. Alles nach einer Anleitung verbaut.
WS2801 LED, Netzteil, Pi 3 etc.
Es läuft nur ich bekomme die Farben nicht richtig dargestellt. Habe schon alle Einstellungen bzgl. RGB etc. im Hyperion probiert.
Ich hoffe das einer von euch mir weiterhelfen kann.
Anbei ein paar Bilder..
DANKE im Voraus.
"device" :
"type" : "ws2801",
"rate" : 1000000,
"colorOrder" : "rbg"
"color" :
"id" : "default",
"leds" : "*",
"pureRed" :
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"pureGreen" :
"redChannel" : 0,
"blueChannel" : 255
"pureBlue" :
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 255
"temperature" :
"id" : "default",
"leds" : "*",
"red" : 255,
"green" : 255,
"blue" : 255
"transform" :
"id" : "default",
"leds" : "*",
"hsl" :
"red" :
"gamma" : 2.5000
"green" :
"gamma" : 2.5000
"blue" :
"gamma" : 2.5000
// SMOOTHING CONFIG
"smoothing" :
"type" : "linear",
"time_ms" : 100,
"updateDelay" : 0
// NO V4L2 GRABBER CONFIG
"framegrabber" :
"width" : 64,
"height" : 64,
"priority" : 890
"enable" : true,
"threshold" : 0.0,
"mode" : "default"
"grabVideo" : true,
"grabMenu" : true,
"grabPause" : true,
"grabScreensaver" : false,
"bootsequence" :
"color" : [0,0,0],
"effect" : "Cinema brighten lights",
"duration_ms" : 3000,
"priority" : 700
"jsonServer" :
"port" : 19444
"protoServer" :
"port" : 19445
// JSON/PROTO FORWARD CONFIG
"forwarder" :
"json" : ["127.0.0.1:19446"],
"proto" : ["127.0.0.1:19447"]
// EFFECT PATH
"effects" :
"paths" :
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.6563, "maximum" : 0.6875 },
"index" : 1,
"hscan" : { "minimum" : 0.6875, "maximum" : 0.7188 },
"index" : 2,
"hscan" : { "minimum" : 0.7188, "maximum" : 0.7500 },
"index" : 3,
"hscan" : { "minimum" : 0.7500, "maximum" : 0.7813 },
"index" : 4,
"hscan" : { "minimum" : 0.7813, "maximum" : 0.8125 },
"index" : 5,
"hscan" : { "minimum" : 0.8125, "maximum" : 0.8438 },
"index" : 6,
"hscan" : { "minimum" : 0.8438, "maximum" : 0.8750 },
"index" : 7,
"hscan" : { "minimum" : 0.8750, "maximum" : 0.9063 },
"index" : 8,
"hscan" : { "minimum" : 0.9063, "maximum" : 0.9375 },
"index" : 9,
"hscan" : { "minimum" : 0.9375, "maximum" : 0.9688 },
"index" : 10,
"hscan" : { "minimum" : 0.9688, "maximum" : 1.0000 },
"index" : 11,
"index" : 12,
"index" : 13,
"index" : 14,
"index" : 15,
"index" : 16,
"index" : 17,
"index" : 18,
"index" : 19,
"index" : 20,
"index" : 21,
"index" : 22,
"index" : 23,
"index" : 24,
"index" : 25,
"index" : 26,
"index" : 27,
"index" : 28,
"index" : 29,
"index" : 30,
"index" : 31,
"index" : 32,
"index" : 33,
"index" : 34,
"index" : 35,
"index" : 36,
"index" : 37,
"index" : 38,
"index" : 39,
"hscan" : { "minimum" : 0.6250, "maximum" : 0.6563 },
"index" : 40,
"hscan" : { "minimum" : 0.5938, "maximum" : 0.6250 },
"index" : 41,
"hscan" : { "minimum" : 0.5625, "maximum" : 0.5938 },
"index" : 42,
"hscan" : { "minimum" : 0.5313, "maximum" : 0.5625 },
"index" : 43,
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5313 },
"index" : 44,
"hscan" : { "minimum" : 0.4688, "maximum" : 0.5000 },
"index" : 45,
"hscan" : { "minimum" : 0.4375, "maximum" : 0.4688 },
"index" : 46,
"hscan" : { "minimum" : 0.4063, "maximum" : 0.4375 },
"index" : 47,
"hscan" : { "minimum" : 0.3750, "maximum" : 0.4063 },
"index" : 48,
"hscan" : { "minimum" : 0.3438, "maximum" : 0.3750 },
"index" : 49,
"hscan" : { "minimum" : 0.3125, "maximum" : 0.3438 },
"index" : 50,
"hscan" : { "minimum" : 0.2813, "maximum" : 0.3125 },
"index" : 51,
"hscan" : { "minimum" : 0.2500, "maximum" : 0.2813 },
"index" : 52,
"hscan" : { "minimum" : 0.2188, "maximum" : 0.2500 },
"index" : 53,
"hscan" : { "minimum" : 0.1875, "maximum" : 0.2188 },
"index" : 54,
"hscan" : { "minimum" : 0.1563, "maximum" : 0.1875 },
"index" : 55,
"hscan" : { "minimum" : 0.1250, "maximum" : 0.1563 },
"index" : 56,
"hscan" : { "minimum" : 0.0938, "maximum" : 0.1250 },
"index" : 57,
"hscan" : { "minimum" : 0.0625, "maximum" : 0.0938 },
"index" : 58,
"hscan" : { "minimum" : 0.0313, "maximum" : 0.0625 },
"index" : 59,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0313 },
"index" : 60,
"index" : 61,
"index" : 62,
"index" : 63,
"index" : 64,
"index" : 65,
"index" : 66,
"index" : 67,
"index" : 68,
"index" : 69,
"index" : 70,
"index" : 71,
"index" : 72,
"index" : 73,
"index" : 74,
"index" : 75,
"index" : 76,
"index" : 77,
"index" : 78,
"index" : 79,
"index" : 80,
"index" : 81,
"index" : 82,
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
