Über das Wochenende konnte ich einige Tests machen und nach etlichen Neuinstallationen konnte ich folgendes für mein Setup herausfinden:
Sobald ich das Startup-Script phoniebox-gpio-buttons deaktiviere, funktioniert die Audioausgabe problemlos.
Jetzt bin ich daran RPi-Jukebox-RFID/scripts/gpio-buttons.py auszuwerten, wieso dies zu Problemen mit I2S führen könnte...
Falls das jemand schon mal durchgemacht hat, freue ich mich über Tipps : )
Ich vermute ein Problem in den Zeilen ab 161 ; )
Werde die GPIO's mal auf das flexible Layout ändern.
Hier das Script RPi-Jukebox-RFID/scripts/gpio-buttons.py:
#!/usr/bin/env python3
import RPi.GPIO as GPIO
from signal import pause
from subprocess import check_call
import time
from time import sleep
# This script will block any I2S DAC e.g. from Hifiberry, Justboom, ES9023, PCM5102A
# due to the assignment of GPIO 19 and 21 to a buttons
# 2019-12-17
# Added support to detect RFID tag removal. Requires an appropriate switch
# makes no difference which hardware implementation you choose, could be a simple switch,
# or hidden magnetic switch or hacking the rfid reader as suggested here:
# https://github.com/MiczFlor/RPi-Jukebox-RFID/issues/62
# 2019-05-14
# * Rewrite using RPi.GPIO for Raspberry pi zero compatibility.
# * Added power LED functionality
# 2018-10-31
# Added the function on holding volume + - buttons to change the volume in 0.3s interval
# 2018-10-15
# this script has the `pull_up=True` for all pins. See the following link for additional info:
# https://github.com/MiczFlor/RPi-Jukebox-RFID/issues/259#issuecomment-430007446
# 2017-12-12
# This script was copied from the following RPi forum post:
# https://forum-raspberrypi.de/forum/thread/13144-projekt-jukebox4kids-jukebox-fuer-kinder/?postID=312257#post312257
# I have not yet had the time to test is, so I placed it in the misc folder.
# If anybody has ideas or tests or experience regarding this solution, please create pull requests or contact me.
# This function takes a holding time (fractional seconds), a channel, a GPIO state and an action reference (function).
# It checks if the GPIO is in the state since the function was called. If the state
# changes it return False. If the time is over the function returns True.
def checkGpioStaysInState(holdingTime, gpioChannel, gpioHoldingState):
# Get a reference start time (https://docs.python.org/3/library/time.html#time.perf_counter)
startTime = time.perf_counter()
# Continously check if time is not over
while(holdingTime >= (time.perf_counter() - startTime)):
# Return if state does not match holding state
if(gpioHoldingState != GPIO.input(gpioChannel)):
return False
# Else: Wait
return True
# Actions that call other processes of the phoniebox (Channel Parameter needed by RPi.GPIO)
def shutdown_action(channel):
check_call("./scripts/playout_controls.sh -c=shutdown", shell=True)
def vol0_action(channel):
check_call("./scripts/playout_controls.sh -c=mute", shell=True)
def volD_action(channel):
check_call("./scripts/playout_controls.sh -c=volumedown", shell=True)
def volU_action(channel):
check_call("./scripts/playout_controls.sh -c=volumeup", shell=True)
def next_action(channel):
check_call("./scripts/playout_controls.sh -c=playernext", shell=True)
def prev_action(channel):
check_call("./scripts/playout_controls.sh -c=playerprev", shell=True)
def halt_action(channel):
check_call("./scripts/playout_controls.sh -c=playerpause", shell=True)
def recordstart_action(channel):
check_call("./scripts/playout_controls.sh -c=recordstart", shell=True)
def recordstop_action(channel):
check_call("./scripts/playout_controls.sh -c=recordstop", shell=True)
def recordplaylatest_action(channel):
check_call("./scripts/playout_controls.sh -c=recordplaylatest", shell=True)
def rfidoff_action(channel):
check_call("./scripts/playout_controls.sh -c=playerpauseforce -v=0.5", shell=True)
# Handlers that handle special behavior of the push of a button
# When the shutdown button was held for more than 2 seconds LED flashed and afterwards
def shutdown_handler(channel):
# Detect holding of button
if checkGpioStaysInState(shutdownHoldTime, btn_shut, GPIO.LOW) is True:
# Blink LED
for x in range(0, 10):
GPIO.output(led_power, x & 1)
sleep(PledBlinkTime)
# Keep LED on until power off
GPIO.output(led_power, GPIO.HIGH)
# Shutdown afterwards
# When the Volume Down button was held for more than 0.3 seconds every 0.3 seconds he will lower t$
def volU_handler(channel):
# Rise volume as requested
while checkGpioStaysInState(volumeHoldTime, btn_volU, GPIO.LOW):
# When the Volume Up button was held for more than 0.3 seconds every 0.3 seconds he will call a ra$
def volD_handler(channel):
while checkGpioStaysInState(volumeHoldTime, btn_volD, GPIO.LOW):
# Define the used pins of the raspberry board
btn_shut = 3
btn_vol0 = 13
btn_volU = 16
btn_volD = 19
btn_next = 26
btn_prev = 20
btn_halt = 21
led_power = 12
# btn_rfidoff =
# reco =
# play =
# Set GPIO numbering to BCM instead of board numbering
GPIO.setmode(GPIO.BCM)
# Bounce tolerance time for buttons
bouncetime = 500
volumeHoldTime = 0.3 # Seconds
shutdownHoldTime = 2 # Seconds
PledBlinkTime = 0.3 # Seconds
# Set up GPIO pins and the power led
GPIO.setup(btn_shut, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(btn_vol0, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(btn_volU, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(btn_volD, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(btn_next, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(btn_prev, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(btn_halt, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# GPIO.setup(btn_rfidoff, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(led_power, GPIO.OUT)
# Set standard events for the buttons. Callback functions define the actions of the events (THey are defined above)
GPIO.add_event_detect(btn_shut, GPIO.FALLING, callback=shutdown_handler, bouncetime=bouncetime)
GPIO.add_event_detect(btn_vol0, GPIO.FALLING, callback=vol0_action, bouncetime=bouncetime)
GPIO.add_event_detect(btn_volU, GPIO.FALLING, callback=volU_handler, bouncetime=bouncetime)
GPIO.add_event_detect(btn_volD, GPIO.FALLING, callback=volD_handler, bouncetime=bouncetime)
GPIO.add_event_detect(btn_next, GPIO.FALLING, callback=next_action, bouncetime=bouncetime)
GPIO.add_event_detect(btn_prev, GPIO.FALLING, callback=prev_action, bouncetime=bouncetime)
GPIO.add_event_detect(btn_halt, GPIO.FALLING, callback=halt_action, bouncetime=bouncetime)
# GPIO.add_event_detect(btn_rfidoff, GPIO.FALLING, callback=rfidoff_action, bouncetime=bouncetime)
# reco.when_pressed = recordstart_action
# reco.when_released = recordstop_action
# play.when_pressed = recordplaylatest_action
# Switch on power led after boot to indicate state "on" for phoniebox
pause()
