ich habe leider auf den akt. Raspi 4b( raspberrypi 5.4.79-v7l+) das gleiche Problem (Server läuft nicht, HTTP geht nicht).
Angeblich started owserver, aber ich kann nicht via http://raspi:2121 die Testseite öffnen.
Ich sehe zwar eine Warning - aber keinen Fehler...
Ideen?
pi@raspberrypi:~ $ sudo systemctl status owserver.service
● owserver.service - Backend server for 1-wire control
Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2020-12-23 09:27:42 GMT; 3min 17s ago
Docs: man:owserver(1)
Main PID: 7226 (owserver)
Tasks: 4 (limit: 3861)
CGroup: /system.slice/owserver.service
└─7226 /usr/bin/owserver -c /etc/owfs.conf
Dec 23 09:27:42 raspberrypi systemd[1]: Starting Backend server for 1-wire control...
Dec 23 09:27:42 raspberrypi OWFS[7226]: DEFAULT: ow_daemon.c:(144) Entered background mode, quitting.
Dec 23 09:27:42 raspberrypi owserver[7226]: *** WARNING *** The program 'owserver' uses the Apple Bonjour compatibility layer of Avahi.
Dec 23 09:27:42 raspberrypi systemd[1]: Started Backend server for 1-wire control.
Dec 23 09:27:42 raspberrypi owserver[7226]: *** WARNING *** Please fix your application to use the native API of Avahi!
Dec 23 09:27:42 raspberrypi owserver[7226]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
Alles anzeigen
