#For more options and information see
# http://rpf.io/configtxt
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
dtparam=i2c1=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on # <-------------------------------
dtparam=i2c1=on # <-------------------------------
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
