Posts by Hobbi
    Hallo, dies ist mein Python script. Ich habe die Zeile
    def __init__(self, bus=1, device=2, spd=1000000, pin_mode=10, pin_rst=-1, debugLevel='WARNING'):
    so angepasst das sie auf bus 1 und device 2 hört und passen die Kabel verbunden.
    In der boot/config.txt ist alles was den Reader betrifft auskommentiert. Der Display funktioniert.
    Sobald ich in der /boot/config.txt die Zeile: dtoverlay=spi1-3cs aktiviert. Funktioniert der Reader aber das Display nicht mehr
    #!/usr/bin/env python
    # -*- coding: utf8 -*-
    # Copyright 2014,2018 Mario Gomez <mario.gomez@teubi.co>
    # This file is part of MFRC522-Python
    # MFRC522-Python is a simple Python implementation for
    # the MFRC522 NFC Card Reader for the Raspberry Pi.
    # MFRC522-Python is free software: you can redistribute it and/or modify
    # it under the terms of the GNU Lesser General Public License as published by
    # the Free Software Foundation, either version 3 of the License, or
    # (at your option) any later version.
    # MFRC522-Python is distributed in the hope that it will be useful,
    # but WITHOUT ANY WARRANTY; without even the implied warranty of
    # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    # GNU Lesser General Public License for more details.
    # You should have received a copy of the GNU Lesser General Public License
    # along with MFRC522-Python. If not, see <http://www.gnu.org/licenses/>.
    import RPi.GPIO as GPIO
    import spidev
    import signal
    import time
    import logging
    class MFRC522:
    MAX_LEN = 16
    PCD_IDLE = 0x00
    PCD_AUTHENT = 0x0E
    PCD_RECEIVE = 0x08
    PCD_TRANSMIT = 0x04
    PCD_TRANSCEIVE = 0x0C
    PCD_RESETPHASE = 0x0F
    PCD_CALCCRC = 0x03
    PICC_REQIDL = 0x26
    PICC_REQALL = 0x52
    PICC_ANTICOLL = 0x93
    PICC_SElECTTAG = 0x93
    PICC_AUTHENT1A = 0x60
    PICC_AUTHENT1B = 0x61
    PICC_READ = 0x30
    PICC_WRITE = 0xA0
    PICC_DECREMENT = 0xC0
    PICC_INCREMENT = 0xC1
    PICC_RESTORE = 0xC2
    PICC_TRANSFER = 0xB0
    PICC_HALT = 0x50
    MI_OK = 0
    MI_NOTAGERR = 1
    MI_ERR = 2
    Reserved00 = 0x00
    CommandReg = 0x01
    CommIEnReg = 0x02
    DivlEnReg = 0x03
    CommIrqReg = 0x04
    DivIrqReg = 0x05
    ErrorReg = 0x06
    Status1Reg = 0x07
    Status2Reg = 0x08
    FIFODataReg = 0x09
    FIFOLevelReg = 0x0A
    WaterLevelReg = 0x0B
    ControlReg = 0x0C
    BitFramingReg = 0x0D
    CollReg = 0x0E
    Reserved01 = 0x0F
    Reserved10 = 0x10
    ModeReg = 0x11
    TxModeReg = 0x12
    RxModeReg = 0x13
    TxControlReg = 0x14
    TxAutoReg = 0x15
    TxSelReg = 0x16
    RxSelReg = 0x17
    RxThresholdReg = 0x18
    DemodReg = 0x19
    Reserved11 = 0x1A
    Reserved12 = 0x1B
    MifareReg = 0x1C
    Reserved13 = 0x1D
    Reserved14 = 0x1E
    SerialSpeedReg = 0x1F
    Reserved20 = 0x20
    CRCResultRegM = 0x21
    CRCResultRegL = 0x22
    Reserved21 = 0x23
    ModWidthReg = 0x24
    Reserved22 = 0x25
    RFCfgReg = 0x26
    GsNReg = 0x27
    CWGsPReg = 0x28
    ModGsPReg = 0x29
    TModeReg = 0x2A
    TPrescalerReg = 0x2B
    TReloadRegH = 0x2C
    TReloadRegL = 0x2D
    TCounterValueRegH = 0x2E
    TCounterValueRegL = 0x2F
    Reserved30 = 0x30
    TestSel1Reg = 0x31
    TestSel2Reg = 0x32
    TestPinEnReg = 0x33
    TestPinValueReg = 0x34
    TestBusReg = 0x35
    AutoTestReg = 0x36
    VersionReg = 0x37
    AnalogTestReg = 0x38
    TestDAC1Reg = 0x39
    TestDAC2Reg = 0x3A
    TestADCReg = 0x3B
    Reserved31 = 0x3C
    Reserved32 = 0x3D
    Reserved33 = 0x3E
    Reserved34 = 0x3F
    serNum = []
    self.spi = spidev.SpiDev()
    self.spi.open(bus, device)
    self.spi.max_speed_hz = spd
    self.logger = logging.getLogger('mfrc522Logger')
    self.logger.addHandler(logging.StreamHandler())
    level = logging.getLevelName(debugLevel)
    self.logger.setLevel(level)
    gpioMode = GPIO.getmode()
    if gpioMode is None:
    GPIO.setmode(pin_mode)
    else:
    pin_mode = gpioMode
    if pin_rst == -1:
    if pin_mode == 11:
    pin_rst = 15
    else:
    pin_rst = 22
    GPIO.setup(pin_rst, GPIO.OUT)
    GPIO.output(pin_rst, 1)
    self.MFRC522_Init()
    def MFRC522_Reset(self):
    self.Write_MFRC522(self.CommandReg, self.PCD_RESETPHASE)
    def Write_MFRC522(self, addr, val):
    val = self.spi.xfer2([(addr << 1) & 0x7E, val])
    def Read_MFRC522(self, addr):
    val = self.spi.xfer2([((addr << 1) & 0x7E) | 0x80, 0])
    return val[1]
    def Close_MFRC522(self):
    self.spi.close()
    GPIO.cleanup()
    def SetBitMask(self, reg, mask):
    tmp = self.Read_MFRC522(reg)
    self.Write_MFRC522(reg, tmp | mask)
    def ClearBitMask(self, reg, mask):
    self.Write_MFRC522(reg, tmp & (~mask))
    def AntennaOn(self):
    temp = self.Read_MFRC522(self.TxControlReg)
    if (~(temp & 0x03)):
    self.SetBitMask(self.TxControlReg, 0x03)
    def AntennaOff(self):
    self.ClearBitMask(self.TxControlReg, 0x03)
    def MFRC522_ToCard(self, command, sendData):
    backData = []
    backLen = 0
    status = self.MI_ERR
    irqEn = 0x00
    waitIRq = 0x00
    lastBits = None
    n = 0
    if command == self.PCD_AUTHENT:
    irqEn = 0x12
    waitIRq = 0x10
    if command == self.PCD_TRANSCEIVE:
    irqEn = 0x77
    waitIRq = 0x30
    self.Write_MFRC522(self.CommIEnReg, irqEn | 0x80)
    self.ClearBitMask(self.CommIrqReg, 0x80)
    self.SetBitMask(self.FIFOLevelReg, 0x80)
    self.Write_MFRC522(self.CommandReg, self.PCD_IDLE)
    for i in range(len(sendData)):
    self.Write_MFRC522(self.FIFODataReg, sendData[i])
    self.Write_MFRC522(self.CommandReg, command)
    self.SetBitMask(self.BitFramingReg, 0x80)
    i = 2000
    while True:
    n = self.Read_MFRC522(self.CommIrqReg)
    i -= 1
    if ~((i != 0) and ~(n & 0x01) and ~(n & waitIRq)):
    break
    self.ClearBitMask(self.BitFramingReg, 0x80)
    if i != 0:
    if (self.Read_MFRC522(self.ErrorReg) & 0x1B) == 0x00:
    status = self.MI_OK
    if n & irqEn & 0x01:
    status = self.MI_NOTAGERR
    n = self.Read_MFRC522(self.FIFOLevelReg)
    lastBits = self.Read_MFRC522(self.ControlReg) & 0x07
    if lastBits != 0:
    backLen = (n - 1) * 8 + lastBits
    else:
    backLen = n * 8
    if n == 0:
    n = 1
    if n > self.MAX_LEN:
    n = self.MAX_LEN
    for i in range(n):
    backData.append(self.Read_MFRC522(self.FIFODataReg))
    else:
    return (status, backData, backLen)
    def MFRC522_Request(self, reqMode):
    status = None
    backBits = None
    TagType = []
    self.Write_MFRC522(self.BitFramingReg, 0x07)
    TagType.append(reqMode)
    (status, backData, backBits) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, TagType)
    if ((status != self.MI_OK) | (backBits != 0x10)):
    return (status, backBits)
    def MFRC522_Anticoll(self):
    backData = []
    serNumCheck = 0
    serNum = []
    self.Write_MFRC522(self.BitFramingReg, 0x00)
    serNum.append(self.PICC_ANTICOLL)
    serNum.append(0x20)
    (status, backData, backBits) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, serNum)
    if (status == self.MI_OK):
    i = 0
    if len(backData) == 5:
    for i in range(4):
    serNumCheck = serNumCheck ^ backData[i]
    if serNumCheck != backData[4]:
    else:
    return (status, backData)
    def CalulateCRC(self, pIndata):
    self.ClearBitMask(self.DivIrqReg, 0x04)
    for i in range(len(pIndata)):
    self.Write_MFRC522(self.FIFODataReg, pIndata[i])
    self.Write_MFRC522(self.CommandReg, self.PCD_CALCCRC)
    i = 0xFF
    while True:
    n = self.Read_MFRC522(self.DivIrqReg)
    i -= 1
    if not ((i != 0) and not (n & 0x04)):
    break
    pOutData = []
    pOutData.append(self.Read_MFRC522(self.CRCResultRegL))
    pOutData.append(self.Read_MFRC522(self.CRCResultRegM))
    return pOutData
    def MFRC522_SelectTag(self, serNum):
    backData = []
    buf = []
    buf.append(self.PICC_SElECTTAG)
    buf.append(0x70)
    for i in range(5):
    buf.append(serNum[i])
    pOut = self.CalulateCRC(buf)
    buf.append(pOut[0])
    buf.append(pOut[1])
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, buf)
    if (status == self.MI_OK) and (backLen == 0x18):
    self.logger.debug("Size: " + str(backData[0]))
    return backData[0]
    else:
    return 0
    def MFRC522_Auth(self, authMode, BlockAddr, Sectorkey, serNum):
    buff = []
    # First byte should be the authMode (A or B)
    buff.append(authMode)
    # Second byte is the trailerBlock (usually 7)
    buff.append(BlockAddr)
    # Now we need to append the authKey which usually is 6 bytes of 0xFF
    for i in range(len(Sectorkey)):
    buff.append(Sectorkey[i])
    # Next we append the first 4 bytes of the UID
    for i in range(4):
    buff.append(serNum[i])
    # Now we start the authentication itself
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_AUTHENT, buff)
    # Check if an error occurred
    if not (status == self.MI_OK):
    self.logger.error("AUTH ERROR!!")
    if not (self.Read_MFRC522(self.Status2Reg) & 0x08) != 0:
    self.logger.error("AUTH ERROR(status2reg & 0x08) != 0")
    # Return the status
    return status
    def MFRC522_StopCrypto1(self):
    self.ClearBitMask(self.Status2Reg, 0x08)
    def MFRC522_Read(self, blockAddr):
    recvData = []
    recvData.append(self.PICC_READ)
    recvData.append(blockAddr)
    pOut = self.CalulateCRC(recvData)
    recvData.append(pOut[0])
    recvData.append(pOut[1])
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, recvData)
    self.logger.error("Error while reading!")
    if len(backData) == 16:
    self.logger.debug("Sector " + str(blockAddr) + " " + str(backData))
    return backData
    else:
    return None
    def MFRC522_Write(self, blockAddr, writeData):
    buff = []
    buff.append(self.PICC_WRITE)
    buff.append(blockAddr)
    crc = self.CalulateCRC(buff)
    buff.append(crc[0])
    buff.append(crc[1])
    (status, backData, backLen) = self.MFRC522_ToCard(self.PCD_TRANSCEIVE, buff)
    if not (status == self.MI_OK) or not (backLen == 4) or not ((backData[0] & 0x0F) == 0x0A):
    self.logger.debug("%s backdata &0x0F == 0x0A %s" % (backLen, backData[0] & 0x0F))
    if status == self.MI_OK:
    buf = []
    for i in range(16):
    buf.append(writeData[i])
    crc = self.CalulateCRC(buf)
    buf.append(crc[0])
    buf.append(crc[1])
    self.logger.error("Error while writing")
    self.logger.debug("Data written")
    def MFRC522_DumpClassic1K(self, key, uid):
    for i in range(64):
    status = self.MFRC522_Auth(self.PICC_AUTHENT1A, i, key, uid)
    # Check if authenticated
    self.MFRC522_Read(i)
    else:
    self.logger.error("Authentication error")
    def MFRC522_Init(self):
    self.MFRC522_Reset()
    self.Write_MFRC522(self.TModeReg, 0x8D)
    self.Write_MFRC522(self.TPrescalerReg, 0x3E)
    self.Write_MFRC522(self.TReloadRegL, 30)
    self.Write_MFRC522(self.TReloadRegH, 0)
    self.Write_MFRC522(self.TxAutoReg, 0x40)
    self.Write_MFRC522(self.ModeReg, 0x3D)
    self.AntennaOn()
    Der LCD Display ist an den Pins 1-24 angeschlossen und der RFID-Reader an 34-40 und 1 (3.3 V).
    In der /boot/config.txt ist dtoverlay:1-3cs eingetragen und der Reader funktioniert.
    Der Reader reagiert auf spidev1.2
    Der Display funktioniert leider aktuell nicht.
    in /dev ist spidev1.0 spidev1.1 spidev1.2 zusehen. Der Display braucht spidev0.0
    verschiedene dtoverlayX.X kombinationen habe ich schon vergebens getestet.
    Wie bekomme ich spidev0.0 und die anderen gleichzeitig aktiviert?
    Vielen Dank
    Hobbi
    Hallo Lars,
    für die Installation des RFID-Moduls bin ich folgedem Tutorial gefolgt: https://pimylifeup.com/raspberry-pi-rfid-rc522/
    für die Installation des Displays: habe ich die Offizielle Anleitung benutzt: https://joy-it.net/files/files…FT-Anleitung_04082020.pdf
    Ein Foto der Verkabelung kann ich erst gegen Abend hochladen.
    Meine Versuche zu dem Thema waren vonzufälligen Internetseiten die ich beim googeln gefunden habe. Quasi immer wenn ich was neues gelesen/entdeckt habe, wurde es ausprobiert. Ich hatte zb. versucht die Pin Belegung anzupassen, das der RFID-Leser auf andere Pins reagiert. allerdings war dadurch /dev/spidevX.X verschwunden
    bei meinem Raspberry Pi handelt es sich um die Version 3B
    ich versuche seit Monaten einen Stechuhr per Raspberry Pi zu bauen. Es soll ein RIFD: RC522-Leser und Joy-IT 3.5" LCD - Display gleichzeitig zu betrieben werden. (über ein Breadboard verkabelt)
    Ich habe den RC522-Chip erfolgreich installiert und er funktioniert tadellos.
    Sobald ich den Display installiere funktioniert zwar der Display aber der RFID-Leser nicht mehr. Ich habe viele Lösungen/Tutorials aus dem Internet vergebens ausprobiert. (Widerstände eingebaut, verschiedene Verkabelungen (Spi0.1 Spi1.0 Spi1.1) etc.) Dies ist mein erstes Raspberry-Projekt und bin leider am Ende meiner Ideen.
    Eine übliche Vorgehensweise/Konfiguration für 2 SPI geräte an einem Raspberry Pi hab ich leider nicht gefunden.
    Wäre schön wenn jemand einen Tipp für mich hätte. Mein aktueller Plan B ist einen kleinen HDMI-Display zu besorgen.
    Mit freundlichen Grüßen
    Hobbi
    Hallo Bernd,
    danke für den Reply.
    Die Pins 1-26 werden von dem Touchscreen verwendet.
    daher habe ich den RFID-Leser an die Pins 35-40 angeschlossen und von meinem Verständniss her müsste dies dann spidev1.2 mit dtoverlay=spi1-3cs sein.
    Oder Irre ich mich hier? Der RFID-Leser funktioniert auch in diesem Setup. Allerding wird der Touchscreen geblockt. Aktuell ist es eine "entweder/oder Situation"
    EDIT: wenn ich dtoverlay=spi1-3cs auskommentiere
    und dtoverlay=spi2-1cs eintrage. Bekomme ich in /dev keine spidev angezeigt. Allerdings wäre in dieser Konstellation /dev/fb1 da.
    Hobbi
    Sehr geehrte Damen und Herren,
    ich versuche einen RC522-RFIDleser und einen 3.5" Joy-IT Touchscreen gleichzeitig zum laufen zu bekommen.
    Ich habe für den RC522-Leser die Python-Scripte so verändert das sie auf spidev1.2 horchen.
    Der Touchscreen funktioniert auch so weit.
    Wenn in der /boot/config.txt die Zeile dtoverlay=spi1-3cs aktiviert ist um spidev1.2 zu aktivieren.
    verschwindet fb1 im /dev folder und der Touchscreen funktioniert nicht mehr.
    Kommentiere ich die Zeile dtoverlay=spi1-3cs wieder aus. Funktioniert der Touchscreen wieder, aber der RFID-Leser nicht.
    fb1 sollte der Framebuffer für den Touchscreen werden.
    fb0 ist HDMI
    Es ist mein erstes Raspberry Pi- Projekt und soll ein Zeiterfassungsterminal werden.
    Hobbi
