Posts by pi0427
    ein Raspberry braucht im Dauerbetrieb eine sichere Spannungsversorgung, speziell bei mir, da Stromausfall ein Thema ist. Meine Anforderungen an die USV sind Lademanagement, reboot wenn Akkus leer sind und das Netz wieder vorhanden ist sowie kleine Baugruppengröße.
    Meine Frage: hat jemand Erfahrungen mit dem "52pi-ups-board-with-rtc-coulometer" am Raspberry 3B. Oder gibt es bessere Lösungen?
    UPS Board With RTC & Coulometer for Raspberry Pi
    [Description]: UPS board supports Raspberry Pi 4B but also adds type C output. It provides enough power for the Raspberry Pi to make your Raspberry Pi still…
    52pi.com
    Hi, der Schlüssel zum Erfolg war .....
    pi@raspberrypi:/ $ sudo service dhcpcd status
    ● dhcpcd.service - dhcpcd on all interfaces
    Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
    Active: failed (Result: exit-code) since Wed 2021-02-17 13:14:29 UTC; 2 days ago
    Process: 211 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=6)
    Feb 17 13:14:28 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
    Feb 17 13:14:29 raspberrypi dhcpcd[211]: Not running dhcpcd because /etc/network/interfaces
    Feb 17 13:14:29 raspberrypi dhcpcd[211]: defines some interfaces that will use a
    Feb 17 13:14:29 raspberrypi dhcpcd[211]: DHCP client or static address
    Feb 17 13:14:29 raspberrypi systemd[1]: dhcpcd.service: Control process exited, code=exited status=6
    Feb 17 13:14:29 raspberrypi systemd[1]: Failed to start dhcpcd on all interfaces.
    Feb 17 13:14:29 raspberrypi systemd[1]: dhcpcd.service: Unit entered failed state.
    Feb 17 13:14:29 raspberrypi systemd[1]: dhcpcd.service: Failed with result 'exit-code'.
    die interfaces-Datei habe ich wie flogt geändert:
    pi@raspberrypi:/ $ sudo cat /etc/network/interfaces
    # interfaces(5) file used by ifup(8) and ifdown(8)
    # Please note that this file is written to be used with dhcpcd
    # For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
    # Include files from /etc/network/interfaces.d:
    source-directory /etc/network/interfaces.d
    wpa_supplicant-Datei und dhcpcd.conf ebenfalls :
    pi@raspberrypi:/ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
    ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
    update_config=1
    country=GR
    network={
    ssid="*mynet*"
    psk="*mykey*"
    proto=RSN
    key_mgmt=NONE
    pairwise=CCMP
    auth_alg=OPEN
    wep_key0="*mykey*"
    pi@raspberrypi:/ $ sudo cat /etc/dhcpcd.conf
    interface wlan0
    static ip_address=192.168.2.101/24
    static routers=192.168.2.1
    static domain_name_servers=8.8.8.8 4.4.4.4
    static domain_search=
    noipv6
    pi@raspberrypi:/ $ sudo service dhcpcd stop
    pi@raspberrypi:/ $ sudo service dhcpcd start
    Active: active (running) since Sat 2021-02-20 10:52:09 UTC; 3s ago
    Process: 980 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
    Main PID: 982 (dhcpcd)
    CGroup: /system.slice/dhcpcd.service
    └─982 /sbin/dhcpcd -q -b
    Feb 20 10:52:09 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
    Feb 20 10:52:09 raspberrypi dhcpcd[980]: dev: loaded udev
    Feb 20 10:52:09 raspberrypi dhcpcd[980]: forked to background, child pid 982
    Feb 20 10:52:09 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
    Feb 20 10:52:10 raspberrypi dhcpcd[982]: eth0: waiting for carrier
    Feb 20 10:52:10 raspberrypi dhcpcd[982]: wlan0: waiting for carrier
    Sieh´ da eine IP!
    pi@raspberrypi:/ $ ifconfig wlan0
    wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
    inet 192.168.2.101 netmask 255.255.255.0 broadcast 192.168.2.255
    inet6 fe80::c6e9:aff:fe08:16e prefixlen 64 scopeid 0x20<link>
    ether c4:e9:0a:08:01:6e txqueuelen 1000 (Ethernet)
    RX packets 4654 bytes 6101009 (5.8 MiB)
    RX errors 0 dropped 2455 overruns 0 frame 0
    TX packets 3743 bytes 408602 (399.0 KiB)
    TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
    LG
    Hi, danke für den Tip. Heute habe ich einen Pi3 model B, mit integriertem Wlan, erfolgreich in mein Neztwerk eingebunden.
    Auch all unsere Gäste haben, meist mit den Smartphones, kein Probelm unser wlan zu nutzten. Sollte OK sein.
    Ich bin weiterhin ratlos, wo ich nach dem Problem suchen soll. Ist USB OK, ist der Treiber OK, oder sind die Dateien /etc/network/interfaces,
    /etc/wpa_supplicant/wpa_supplicant.conf sowie /etc/dhcpcd.conf das Problem. Antworten auf oben gestellte Fragen könnten Klarheit schaffen.
    "sudo services dhcpcd status" zeigt ,dass DHCP aktive ist. Was macht : sudo systemctl enable dhcpcd ??
    LG
    DWA-131E1 USB-WIFI Adapter am Pi B+ installieren
    Ich denke das chipset ist RTL8192EU. Bitte korregieren, wenn ich falsch liege.
    Im Folgenden versuche ich den Ablauf darzustellen:
    pi@raspberrypi:~ $ uname -a
    Linux raspberrypi 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux
    pi@raspberrypi:/ $ lsusb
    Bus 001 Device 006: ID 2001:3319 D-Link Corp.
    Bus 001 Device 005: ID 413c:2003 Dell Computer Corp. Keyboard
    Bus 001 Device 004: ID 046d:c001 Logitech, Inc. N48/M-BB48/M-UK96A [FirstMouse Plus]
    Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
    pi@raspberrypi:/ $ sudo dmesg -T | grep usb
    [Tue Feb 16 14:15:38 2021] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
    [Tue Feb 16 14:15:38 2021] usb 1-1.5: New USB device found, idVendor=2001, idProduct=3319
    [Tue Feb 16 14:15:38 2021] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [Tue Feb 16 14:15:38 2021] usb 1-1.5: Product: Wireless N Nano USB Adapter
    [Tue Feb 16 14:15:38 2021] usb 1-1.5: Manufacturer: Realtek
    [Tue Feb 16 14:15:38 2021] usb 1-1.5: SerialNumber: 00e04c000001
    [Tue Feb 16 14:15:39 2021] usbcore: registered new interface driver rtl8192eu
    Bis hier denke ich wird der Adapter am USB erkannt und ein Treiber zugewiesen ?
    Ja / Nein ?
    pi@raspberrypi:/ $ apt-cache search rtl8192eu
    firmware-realtek - Binary firmware for Realtek wired/wifi/BT adapters
    pi@raspberrypi:/ $ lsmod
    Module Size Used by
    8192eu 1464640 0
    bluetooth 375121 0
    fuse 94600 3
    cfg80211 527100 1 8192eu
    rfkill 21373 4 bluetooth,cfg80211
    spidev 7034 0
    evdev 11746 4
    snd_bcm2835 23131 1
    snd_pcm 97825 1 snd_bcm2835
    snd_timer 22706 1 snd_pcm
    snd 68784 5 snd_timer,snd_bcm2835,snd_pcm
    i2c_bcm2835 6433 0
    spi_bcm2835 7424 0
    bcm2835_gpiomem 3791 2
    uio_pdrv_genirq 3718 0
    uio 10166 1 uio_pdrv_genirq
    fixed 3029 0
    rtc_pcf8583 3060 0
    i2c_dev 6642 0
    ip_tables 12512 0
    x_tables 20921 1 ip_tables
    ipv6 384613 14
    pi@raspberrypi:~ $ iwconfig
    wlan0 unassociated Nickname:"<WIFI@REALTEK>"
    Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
    Sensitivity:0/0
    Retry:off RTS thr:off Fragment thr:off
    Power Management:off
    Link Quality:0 Signal level:0 Noise level:0
    Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
    Tx excessive retries:0 Invalid misc:0 Missed beacon:0
    lo no wireless extensions.
    eth0 no wireless extensions.
    An dieser Stelle vermute ich der WIFI Adapter ist erkannt und eingebunden.
    Aber mit keinem Netzwerk verbunden, es gibt keine IP Adresse ?
    pi@raspberrypi:/etc/network $ sudo cat interfaces
    auto wlan0
    auto lo
    iface lo inet loopback
    iface eth0 inet dhcp
    allow-hotplug wlan0
    iface wlan0 inet dhcp
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
    iface default inet dhcp
    pi@raspberrypi:/etc/network $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
    country=GR
    update_config=1
    network={
    ssid="**myName**"
    psk="**myPSWD**"
    proto=RSN
    key_mgmt=WPA-PSK
    pairwise=CCMP
    auth_alg=OPEN
    Reboot dauert nun länger, vermutlich wegen "auto wlan0" ??
    Aber es hat sich nichts geändert:
    Sensitivity:0/0
    pi@raspberrypi:~ $ sudo ip link set wlan0 down
    pi@raspberrypi:~ $ sudo ip link set wlan0 up
    Ebenfalls nach diesen Befehlen keine Ändewrung im iwconfig zu sehen.
    pi@raspberrypi:~ $ sudo ifdown wlan0
    Killed old client process
    Internet Systems Consortium DHCP Client 4.3.5
    Copyright 2004-2016 Internet Systems Consortium.
    All rights reserved.
    For info, please visit https://www.isc.org/software/dhcp/
    Listening on LPF/wlan0/c4:e9:0a:08:01:6e
    Sending on LPF/wlan0/c4:e9:0a:08:01:6e
    Sending on Socket/fallback
    pi@raspberrypi:~ $ sudo ifup wlan0
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
    DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
    No DHCPOFFERS received.
    No working leases in persistent database - sleeping.
    Auch mit verschiedenen Einstellungen in wpa_supplicant.conf und interfaces,
    die ich im WEB fand, hatte ich keinen Erfolg.
    Mein Ziel ist es den Pi über DHCP automatisch mit dem Netzwerk zu verbinden.
