:::: Installation settings ::::
PLAT=Raspbian
OSCN=buster
USING_UFW=0
IPv4dev=eth0
dhcpReserv=1
IPv4addr=http://192.168.0.XXX/24
IPv4gw=192.168.0.1
install_user=AAA
install_home=/home/AAA
VPN=wireguard
pivpnPORT=XXXXX
pivpnDNS1=10.6.0.1
pivpnDNS2=
pivpnHOST=REDACTED
INPUT_CHAIN_EDITED=0
FORWARD_CHAIN_EDITED=0
pivpnPROTO=udp
pivpnDEV=wg0
pivpnNET=10.6.0.0
subnetClass=24
ALLOWED_IPS="0.0.0.0/0, ::0/0"
UNATTUPG=1
INSTALLED_PACKAGES=(wireguard-tools wireguard-dkms qrencode)
:::: Server configuration shown below ::::
[Interface]
PrivateKey = server_priv
Address = 10.6.0.1/24
ListenPort = XXXXX
### begin BBB ###
[Peer]
PublicKey = BBB_pub
PresharedKey = BBB_psk
AllowedIPs = 10.6.0.2/32
### end BBB ###
:::: Client configuration shown below ::::
[Interface]
PrivateKey = BBB_priv
Address = 10.6.0.2/24
DNS = 10.6.0.1
[Peer]
PublicKey = server_pub
Endpoint = REDACTED:XXXXX
AllowedIPs = 0.0.0.0/0, ::0/0
:::: Recursive list of files in ::::
::::[4m/etc/wireguard shown below ::::
/etc/wireguard:
configs
keys
wg0.conf
/etc/wireguard/configs:
clients.txt
BBB.conf
/etc/wireguard/keys:
BBB_priv
BBB_psk
BBB_pub
server_priv
server_pub
:::: Self check ::::
:: [OK] IP forwarding is enabled
:: [OK] Iptables MASQUERADE rule set
:: [OK] WireGuard is running
:: [OK] WireGuard is enabled (it will automatically start on reboot)
:: [OK] WireGuard is listening on port XXXXX/udp
:::: Having trouble connecting? Take a look at the FAQ:
:::: https://github.com/pivpn/pivpn/wiki/FAQ
:::: WARNING: This script should have automatically masked sensitive ::::
:::: information, however, still make sure that PrivateKey, PublicKey ::::
:::: and PresharedKey are masked before reporting an issue. An example key ::::
:::: that you should NOT see in this log looks like this: ::::
:::: YIAoJVsdIeyvXfGGDDadHh6AxsMRymZTnnzZoAb9cxRe ::::
:::: Debug complete ::::
::: Debug output completed above.
::: Copy saved to /tmp/debug.log
