Das hab ich ganz vergessen. Ich verwende das Image RaspiOS Buster vom 07.05.2021. Hab es auch bereits mit älteren und jüngeren Images ausprobiert - kein Veränderung
Posts by McApplePie
Hier ein mal die Ausgabe von dmesg:
Display Moredmesg: [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.10.17+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1414 Fri Apr 30 13:16:27 BST 2021 [ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache [ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] Reserved memory: created CMA memory pool at 0x17c00000, size 64 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000000000000-0x000000001bffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff] [ 0.000000] On node 0 totalpages: 114688 [ 0.000000] Normal zone: 1008 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 114688 pages, LIFO batch:31 [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680 [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:8A:C1:C5 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=c72a59e3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait [ 0.000000] Kernel parameter elevator= does not have any effect anymore. Please use sysfs to set IO scheduler for individual devices. [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] Memory: 374456K/458752K available (8638K kernel code, 1324K rwdata, 2816K rodata, 420K init, 837K bss, 18760K reserved, 65536K cma-reserved) [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] ftrace: allocating 30576 entries in 60 pages [ 0.000000] ftrace: allocated 60 pages with 4 groups [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] random: get_random_bytes called from start_kernel+0x324/0x564 with crng_init=0 [ 0.000029] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000111] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000210] bcm2835: system timer (irq = 27) [ 0.000908] Console: colour dummy device 80x30 [ 0.001593] printk: console [tty1] enabled [ 0.001694] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792) [ 0.060390] pid_max: default: 32768 minimum: 301 [ 0.060721] LSM: Security Framework initializing [ 0.061080] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.061158] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear) [ 0.063628] Disabling memory control group subsystem [ 0.063976] CPU: Testing write buffer coherency: ok [ 0.066062] Setting up static identity map for 0x8200 - 0x8238 [ 0.067509] devtmpfs: initialized [ 0.080945] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 [ 0.081415] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.081507] futex hash table entries: 256 (order: -1, 3072 bytes, linear) [ 0.090420] pinctrl core: initialized pinctrl subsystem [ 0.092709] NET: Registered protocol family 16 [ 0.097469] DMA: preallocated 1024 KiB pool for atomic coherent allocations [ 0.104484] audit: initializing netlink subsys (disabled) [ 0.106195] thermal_sys: Registered thermal governor 'step_wise' [ 0.107248] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.107350] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.107647] Serial: AMBA PL011 UART driver [ 0.110868] audit: type=2000 audit(0.100:1): state=initialized audit_enabled=0 res=1 [ 0.131487] bcm2835-mbox 2000b880.mailbox: mailbox enabled [ 0.150952] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-30T13:47:07, variant start [ 0.160973] raspberrypi-firmware soc:firmware: Firmware hash is d7f29d96450abfc77cd6cf011af1faf1e03e5e56 [ 0.224068] bcm2835-dma 20007000.dma: DMA legacy API manager, dmachans=0x1 [ 0.227449] SCSI subsystem initialized [ 0.228027] usbcore: registered new interface driver usbfs [ 0.228202] usbcore: registered new interface driver hub [ 0.228358] usbcore: registered new device driver usb [ 0.231439] clocksource: Switched to clocksource timer [ 2.242448] VFS: Disk quotas dquot_6.6.0 [ 2.242658] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 2.242984] FS-Cache: Loaded [ 2.243468] CacheFiles: Loaded [ 2.264901] NET: Registered protocol family 2 [ 2.266406] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear) [ 2.266581] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear) [ 2.266704] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear) [ 2.266810] TCP: Hash tables configured (established 4096 bind 4096) [ 2.267048] UDP hash table entries: 256 (order: 0, 4096 bytes, linear) [ 2.267134] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear) [ 2.267671] NET: Registered protocol family 1 [ 2.269119] RPC: Registered named UNIX socket transport module. [ 2.269203] RPC: Registered udp transport module. [ 2.269244] RPC: Registered tcp transport module. [ 2.269279] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.270892] hw perfevents: no irqs for PMU, sampling events not supported [ 2.271034] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available [ 2.276391] Initialise system trusted keyrings [ 2.277079] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 2.289979] zbud: loaded [ 2.293540] FS-Cache: Netfs 'nfs' registered for caching [ 2.295179] NFS: Registering the id_resolver key type [ 2.295307] Key type id_resolver registered [ 2.295354] Key type id_legacy registered [ 2.295630] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.297768] Key type asymmetric registered [ 2.297856] Asymmetric key parser 'x509' registered [ 2.297994] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 2.298052] io scheduler mq-deadline registered [ 2.298094] io scheduler kyber registered [ 2.301713] bcm2708_fb soc:fb: FB found 1 display(s) [ 2.339472] Console: switching to colour frame buffer device 170x48 [ 2.339746] random: fast init done [ 2.358596] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1360x768 [ 2.367915] bcm2835-rng 20104000.rng: hwrng registered [ 2.368797] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB) [ 2.370949] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000 [ 2.397251] brd: module loaded [ 2.415481] loop: module loaded [ 2.418318] Loading iSCSI transport class v2.0-870. [ 2.421395] libphy: Fixed MDIO Bus: probed [ 2.422232] usbcore: registered new interface driver smsc95xx [ 2.422501] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 3.151164] Core Release: 2.80a [ 3.151369] Setting default values for core params [ 3.158192] Finished setting default values for core params [ 3.365362] Using Buffer DMA mode [ 3.371873] Periodic Transfer Interrupt Enhancement - disabled [ 3.378310] Multiprocessor Interrupt Enhancement - disabled [ 3.384729] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 3.391214] Dedicated Tx FIFOs mode [ 3.398643] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = d7d14000 dma = 0x97d14000 len=9024 [ 3.411561] FIQ FSM acceleration enabled for : Non-periodic Split Transactions Periodic Split Transactions High-Speed Isochronous Endpoints Interrupt/Control Split Transaction hack enabled [ 3.443767] dwc_otg: Microframe scheduler enabled [ 3.444082] WARN::hcd_init_fiq:457: FIQ on core 0 [ 3.456718] WARN::hcd_init_fiq:458: FIQ ASM at c0652330 length 36 [ 3.469182] WARN::hcd_init_fiq:497: MPHI regs_base at dc810000 [ 3.481871] dwc_otg 20980000.usb: DWC OTG Controller [ 3.488390] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1 [ 3.495048] dwc_otg 20980000.usb: irq 56, io mem 0x00000000 [ 3.501544] Init: Port Power? op_state=1 [ 3.507935] Init: Power Port (0) [ 3.514909] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 3.521364] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.527840] usb usb1: Product: DWC OTG Controller [ 3.534303] usb usb1: Manufacturer: Linux 5.10.17+ dwc_otg_hcd [ 3.540779] usb usb1: SerialNumber: 20980000.usb [ 3.548690] hub 1-0:1.0: USB hub found [ 3.555348] hub 1-0:1.0: 1 port detected [ 3.563696] dwc_otg: FIQ enabled [ 3.563726] dwc_otg: NAK holdoff enabled [ 3.563743] dwc_otg: FIQ split-transaction FSM enabled [ 3.563773] Module dwc_common_port init [ 3.564436] usbcore: registered new interface driver usb-storage [ 3.571367] mousedev: PS/2 mouse device common for all mice [ 3.579808] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer [ 3.590123] sdhci: Secure Digital Host Controller Interface driver [ 3.596481] sdhci: Copyright(c) Pierre Ossman [ 3.603794] mmc-bcm2835 20300000.mmcnr: could not get clk, deferring probe [ 3.611349] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe [ 3.618395] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.625842] ledtrig-cpu: registered to indicate activity on CPUs [ 3.632941] hid: raw HID events driver (C) Jiri Kosina [ 3.639665] usbcore: registered new interface driver usbhid [ 3.646131] usbhid: USB HID core driver [ 3.660384] Initializing XFRM netlink socket [ 3.667593] NET: Registered protocol family 17 [ 3.674610] Key type dns_resolver registered [ 3.681958] registered taskstats version 1 [ 3.688164] Loading compiled-in X.509 certificates [ 3.713293] uart-pl011 20201000.serial: cts_event_workaround enabled [ 3.719901] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2 [ 3.730388] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver [ 3.739727] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0 [ 3.746313] mmc-bcm2835 20300000.mmcnr: DMA channel allocated [ 3.781549] sdhost: log_buf @ (ptrval) (97d13000) [ 3.788936] Indeed it is in host mode hprt0 = 00021501 [ 3.904911] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1) [ 3.916372] of_cfs_init [ 3.948696] of_cfs_init: OK [ 3.957812] Waiting for root device PARTUUID=c72a59e3-02... [ 4.022855] usb 1-1: new full-speed USB device number 2 using dwc_otg [ 4.030815] Indeed it is in host mode hprt0 = 00021501 [ 4.113559] mmc0: host does not support reading read-only switch, assuming write-enable [ 4.132089] mmc0: new high speed SDXC card at address aaaa [ 4.144863] mmcblk0: mmc0:aaaa SC64G 59.5 GiB [ 4.157725] mmcblk0: p1 p2 [ 4.224744] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 4.231895] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 4.250079] devtmpfs: mounted [ 4.264126] Freeing unused kernel memory: 420K [ 4.270736] Kernel memory protection not selected by kernel config. [ 4.278711] Run /sbin/init as init process [ 4.285407] with arguments: [ 4.285429] /sbin/init [ 4.285443] with environment: [ 4.285457] HOME=/ [ 4.285492] TERM=linux [ 4.286703] usb 1-1: New USB device found, idVendor=05e3, idProduct=0606, bcdDevice= 7.02 [ 4.293685] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.300528] usb 1-1: Product: USB Hub 2.0 [ 4.307422] usb 1-1: Manufacturer: ALCOR [ 4.317722] hub 1-1:1.0: USB hub found [ 4.326385] hub 1-1:1.0: 4 ports detected [ 4.651627] usb 1-1.1: new full-speed USB device number 3 using dwc_otg [ 4.784353] usb 1-1.1: New USB device found, idVendor=1997, idProduct=2433, bcdDevice=20.12 [ 4.791193] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.797885] usb 1-1.1: Product: Mini Keyboard [ 4.804473] usb 1-1.1: Manufacturer: [ 4.848407] input: Mini Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1997:2433.0001/input/input0 [ 4.933435] hid-generic 0003:1997:2433.0001: input,hidraw0: USB HID v1.01 Keyboard [ Mini Keyboard] on usb-20980000.usb-1.1/input0 [ 4.956760] input: Mini Keyboard Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input1 [ 4.966447] input: Mini Keyboard System Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input2 [ 5.052563] input: Mini Keyboard Consumer Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:1997:2433.0002/input/input3 [ 5.062875] hid-generic 0003:1997:2433.0002: input,hidraw1: USB HID v1.01 Mouse [ Mini Keyboard] on usb-20980000.usb-1.1/input1 [ 5.150160] systemd[1]: System time before build time, advancing clock. [ 5.334260] NET: Registered protocol family 10 [ 5.344945] Segment Routing with IPv6 [ 5.482969] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 5.502275] systemd[1]: Detected architecture arm. [ 5.557101] systemd[1]: Set hostname to <raspberrypi>. [ 8.565693] random: systemd: uninitialized urandom read (16 bytes read) [ 8.603989] random: systemd: uninitialized urandom read (16 bytes read) [ 8.618538] systemd[1]: Created slice User and Session Slice. [ 8.637752] random: systemd: uninitialized urandom read (16 bytes read) [ 8.646618] systemd[1]: Reached target Slices. [ 8.667737] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 8.688533] systemd[1]: Listening on udev Kernel Socket. [ 8.714099] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 8.733363] systemd[1]: Reached target Swap. [ 8.753043] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 10.532083] systemd[1]: Started Restore / save the current clock. [ 10.687627] systemd[1]: Starting File System Check on Root Device... [ 10.857977] systemd[1]: Starting Apply Kernel Variables... [ 10.971897] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 11.123028] systemd[1]: Mounting Kernel Configuration File System... [ 11.515618] systemd[1]: Mounted Kernel Configuration File System. [ 11.725630] systemd[1]: Started File System Check Daemon to report status. [ 11.842323] systemd[1]: Started Apply Kernel Variables. [ 11.981858] systemd[1]: Started Journal Service. [ 13.692991] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 14.485588] systemd-journald[87]: Received request to flush runtime journal from PID 1 [ 17.114465] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned. [ 17.117561] bcm2835_vc_sm_cma_probe: Videocore shared memory driver [ 17.117605] [vc_sm_connected_init]: start [ 17.138493] mc: Linux media interface: v0.10 [ 17.182236] [vc_sm_connected_init]: installed successfully [ 17.428065] videodev: Linux video capture interface: v2.00 [ 17.520104] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 17.542596] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 17.544832] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned. [ 17.577990] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned. [ 17.579311] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned. [ 17.581315] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned. [ 17.622727] bcm2835_audio bcm2835_audio: there is not valid maps for state default [ 17.667821] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13 [ 17.673558] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14 [ 17.695628] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned. [ 17.703053] bcm2835_audio bcm2835_audio: card created with 8 channels [ 17.704373] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15 [ 17.737922] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16 [ 17.737998] bcm2835-isp bcm2835-isp: Register output node 0 with media controller [ 17.738074] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller [ 17.738113] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller [ 17.738146] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller [ 17.761957] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp [ 17.790391] bcm2835-codec bcm2835-codec: Device registered as /dev/video10 [ 17.790491] bcm2835-codec bcm2835-codec: Loaded V4L2 decode [ 17.872374] bcm2835-codec bcm2835-codec: Device registered as /dev/video11 [ 17.872471] bcm2835-codec bcm2835-codec: Loaded V4L2 encode [ 17.902580] bcm2835-codec bcm2835-codec: Device registered as /dev/video12 [ 17.902678] bcm2835-codec bcm2835-codec: Loaded V4L2 isp [ 27.900641] random: crng init done [ 27.900680] random: 7 urandom warning(s) missed due to ratelimiting [ 30.761364] 8021q: 802.1Q VLAN Support v1.8 [ 31.010995] uart-pl011 20201000.serial: no DMA platform data [ 31.215745] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS [ 31.573505] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 32.074718] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 35.655885] Bluetooth: Core ver 2.22 [ 35.656091] NET: Registered protocol family 31 [ 35.656108] Bluetooth: HCI device and connection manager initialized [ 35.661325] Bluetooth: HCI socket layer initialized [ 35.661365] Bluetooth: L2CAP socket layer initialized [ 35.666212] Bluetooth: SCO socket layer initialized [ 35.682106] Bluetooth: HCI UART driver ver 2.3 [ 35.682139] Bluetooth: HCI UART protocol H4 registered [ 35.682320] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 35.682702] Bluetooth: HCI UART protocol Broadcom registered [ 36.510505] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 36.510532] Bluetooth: BNEP filters: protocol multicast [ 36.510571] Bluetooth: BNEP socket layer initialized
Die Meldungen im Kernel sehen unverdächtig aus. Keine Warnungen oder kritische Fehler die auf ein Problem mit dem Netzwerk hinweisen. Soll ich den Output posten?
Tut mir Leid das ich mich erst jetzt melde - ich war im Urlaub.
Die anderen GPIO's scheinen zu funktionieren, weshalb ich nun einfach davon ausgehe das der Zero nicht mit der Spannungsversorgung via GPIO klar kommt. Sehr schade. Ich danke euch allen für die Hilfsbereitschaft!
In Ordnung, das werde ich machen.
Es könnte aber auch sein, dass dein Messgerät nicht genau bzw. zu träge für eine genaue Messung ist. Es sind ja keine Elko's mit allzu großer Kapazität auf dem StepUp Wandler verbaut, so dass schnelle Laständerungen u.U. zu kurzen Spannungspeaks führen, was dem RPi dann evtl. nicht gut bekommt. Falls Du Zugriff auf auf ein Oszi hast, wäre dies eine weitere Möglichkeit dem Problem auf den Grund zu gehen.
Das wäre natürlich möglich. Mein Messgerät ist wirklich kein hochwertiges Gerät. Auf ein Oszi habe ich nur leider gar keinen Zugriff. Also könnte man zusammengefasst sagen dass das WLAN-Modul des Raspberrys durch die Stromversorgung via GPIO gegrillt wurde? Wäre es also möglich das dies durch die möglichen Spannungsspitzen gekommen ist oder einfach weil der Raspberry Zero das nicht verträgt?
So, hier im Anhang ein Foto vom Spannungswandler. Während des Bootvorgangs und unter Last habe ich die Spannung mehrere Minuten gemessen - diese schwankte nur selten zwischen 5,20 und 5,22 Volt. Dies scheint also auch nicht der Auslöser gewesen zu sein.
Das deutet doch darauf hin, dass durch die Stromversorgung per GPIO irgendetwas ausgelöst (zerstört / beschädigt) wurde.
Das ist wohl leider das wahrscheinlichste Szenario
@McApplePie Zeig doch mal ein Bild (o. nenne das Modell) von deinem Spannungswandler, wie hoch ist denn die Spannung des Wandlers im Leerlauf? (ohne RPi und mit vollem Akku)
Zur Zeit bin ich nicht zu Hause, aber Montag kann ich direkt ein Bild machen und die Spannung messen.
Dann ist m. E. an deinem PI Zero W (d. h. an der Hardware) etwas zerstört worden (... durch diese Art von Stromversorgung).
Langsam glaube ich das auch. Aber eigentlich darf das dadurch doch gar nicht passieren. Schließlich sind die GPIO's für solche Sachen da.
Vielleicht gibt's ja einen Hinweis in den Boot-Meldungen des Kernels. Ich kenne mich mit dem Zero leider nicht aus, vielleicht kann man ja eine Art Firmwareupdate machen oder man versucht mal den Status aller GPIO Port's ( auch die nur intern verwendet werden ) auszulesen und vergleicht diese Daten dann mit einem anderen Zero.
Das wäre auch noch eine Möglichkeit.
D. h. das laden des wifi-Treibers hat auch nichts bewirkt. Das wlan-Interface wird nicht gezeigt.
Versuch mal mit eine Neuinstallation (buster-lite) und am PI, die Stromversorgung von Anfang an (schon beim 1. Booten) mit der Zelle und nicht mit dem micro-usb-Netzteil.
Hab ich auch schon ein paar mal versucht. Auch mit anderen SD-Karten - leider ohne Erfolg
Quote from Fliegenhals- die 5,2V wurden unter Last gemessen?
- dein Spannungswandler kann in Betrieb auch genug Strom liefern?
Das ist schon ein wenig seltsam. Könnte es vielleicht sein, dass die 5,2V mal an einem dafür nicht vorgesehenen GPIO Pin angeschlossen waren?
Unter Last wurde gemessen - blieb stabil bei den eingestellten 5,2V. Ich denke schon das der Spannungswandler genug Strom liefert.
Also die Stromversorung habe ich ein mal an PIN 2 (5V) und PIN 6 (GROUND) und ein anderes mal an PIN 4 (5V) und PIN 6 (GROUND) angeschlossen. Mit anderen Pins gab es keinen Kontakt
Lass mal bei
den "Strich" vor dem a weg!
Und die Ausgabe von iwconfig fehlt noch.
Oh man, das erklärt warum bei ip -a nichts bei rum gekommen ist
Danke
Hier im Anhang nochmal die vollständige Ausgabe der Befehle: -
Bisher musste ich die Befehle immer in Dateien umleiten um sie dann via USB-Stick an meinen Hauptrechnen zu übertragen damit ich diese Ausgaben hier posten kann. Diesmal hat das warum auch immer nicht funktioniert, darum habe ich die Befehle mit Ausgabe als Bild angehängt. Ich hoffe das ist soweit in Ordnung.
Das werde ich nachher direkt ausprobieren und dann wieder berichten
Schon mal vielen Dank für die Hilfe! Ich finde es einfach merkwürdig dass das Wifi ohne Probleme funktioniert hat und erst nachdem es erstmalig via GPIO mit Strom versorgt wurde geht es nicht mehr, egal was man macht.
Hier ist die Ausgabe von cat /boot/config.txt:
Display More# For more options and information see # http://rpf.io/configtxt # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment this if your display has a black border of unused pixels visible # and your display can output without overscan #disable_overscan=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border #overscan_left=16 #overscan_right=16 #overscan_top=16 #overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. #framebuffer_width=1280 #framebuffer_height=720 # uncomment if hdmi display is not detected and composite is being output #hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=1 #hdmi_mode=1 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # Uncomment this to enable infrared communication. #dtoverlay=gpio-ir,gpio_pin=17 #dtoverlay=gpio-ir-tx,gpio_pin=18 # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on [pi4] # Enable DRM VC4 V3D driver on top of the dispmanx display stack dtoverlay=vc4-fkms-v3d max_framebuffers=2 [all] #dtoverlay=vc4-fkms-v3d
Wie hast Du denn das angestellt? Eine 18650 Zelle hat für 5V eine zu geringe und für 3,3V eine zu hohe Spannung.
Mittels Spannungswandler wird das ganze auf ca. 5.2V hochgeregelt
Hier ist die Ausgabe von lsmod:
Display MoreModule Size Used by sg 32768 0 uas 24576 0 fuse 106496 5 rfcomm 53248 4 bnep 20480 2 hci_uart 40960 1 btbcm 16384 1 hci_uart serdev 20480 1 hci_uart bluetooth 409600 29 hci_uart,bnep,btbcm,rfcomm ecdh_generic 28672 1 bluetooth sha256_generic 20480 0 cfg80211 643072 0 rfkill 28672 4 bluetooth,cfg80211 8021q 32768 0 garp 16384 1 8021q stp 16384 1 garp llc 16384 2 garp,stp evdev 24576 7 joydev 20480 0 raspberrypi_hwmon 16384 0 hwmon 16384 1 raspberrypi_hwmon snd_bcm2835 24576 2 snd_pcm 98304 1 snd_bcm2835 snd_timer 32768 1 snd_pcm snd 73728 7 snd_timer,snd_bcm2835,snd_pcm bcm2835_codec 36864 0 bcm2835_v4l2 45056 0 v4l2_mem2mem 24576 1 bcm2835_codec bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2 v4l2_common 16384 1 bcm2835_v4l2 videobuf2_dma_contig 20480 1 bcm2835_codec videobuf2_vmalloc 16384 1 bcm2835_v4l2 videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc videobuf2_v4l2 24576 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem videobuf2_common 45056 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2 videodev 192512 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2 media 36864 3 bcm2835_codec,videodev,v4l2_mem2mem vc_sm_cma 36864 1 bcm2835_mmal_vchiq fixed 16384 0 uio_pdrv_genirq 16384 0 uio 20480 1 uio_pdrv_genirq i2c_dev 16384 0 ip_tables 24576 0 x_tables 32768 1 ip_tables ipv6 446464 16
Schon mal vielen Dank dafür! Ich probiere das nachher direkt aus und melde mich dann
Hallo liebe Community,
ich habe einen Raspberry Zero W 1.1 der mit einer 18650-Zelle betrieben wird und den Raspberry via GPIO mit Strom versorgt (5,2V). Darauf habe ich das Raspberry OS installiert. Allerdings zeigt er mir beim WLAN folgendes an: "No wireless interface found". Egal ob ich ein neues, älteres oder völlig anderes Betriebssystem verwende - es bleibt bei der Meldung. Allerdings funktioniert Bluetooth ohne Probleme. Dann habe ich einen anderen Raspberry Zero W 1.1 ausprobiert - darauf hat es ohne Probleme direkt funktioniert. Also habe ich die Stromversorgung nun an diesem über GPIO angeschlossen. Und ab dann ging das WLAN wieder nicht und er zeigt wieder an das er keine wifi Interfaces gefunden hat. Selbst wenn ich den Raspberry nun doch wieder über micro-usb mit Strom versorgen möchte funktioniert das nicht mehr. Er findet kein wifi-interface mehr. Hat jemand zufällig eine Ahnung woran das liegen und wie man das Problem beheben könnte?
