// Automatically generated configuration file for 'Hyperion daemon'
// Generated by: HyperCon (The Hyperion deamon configuration file builder
/// Device configuration contains the following fields:
/// * 'name' : The user friendly name of the device (only used for display purposes)
/// * 'type' : The type of the device or leds (known types for now are 'ws2801', 'ldp8806',
/// 'lpd6803', 'sedu', 'adalight', 'lightpack', 'test' and 'none')
/// * 'output' : The output specification depends on selected device. This can for example be the
/// device specifier, device serial number, or the output file name
/// * 'rate' : The baudrate of the output to the device
/// * 'colorOrder' : The order of the color bytes ('rgb', 'rbg', 'bgr', etc.).
"device" :
"name" : "MyPi",
"type" : "ws2801",
"output" : "/dev/spidev0.0",
"rate" : 250000,
"colorOrder" : "rbg"
/// Color manipulation configuration used to tune the output colors to specific surroundings.
/// The configuration contains a list of color-transforms. Each transform contains the
/// following fields:
/// * 'id' : The unique identifier of the color transformation (eg 'device_1') /// * 'leds' : The indices (or index ranges) of the leds to which this color transform applies
/// (eg '0-5, 9, 11, 12-17'). The indices are zero based. /// * 'hsv' : The manipulation in the Hue-Saturation-Value color domain with the following
/// tuning parameters:
/// - 'saturationGain' The gain adjustement of the saturation
/// - 'valueGain' The gain adjustement of the value
/// * 'red'/'green'/'blue' : The manipulation in the Red-Green-Blue color domain with the
/// following tuning parameters for each channel:
/// - 'threshold' The minimum required input value for the channel to be on
/// (else zero)
/// - 'gamma' The gamma-curve correction factor
/// - 'blacklevel' The lowest possible value (when the channel is black)
/// - 'whitelevel' The highest possible value (when the channel is white)
/// Next to the list with color transforms there is also a smoothing option.
/// * 'smoothing' : Smoothing of the colors in the time-domain with the following tuning
/// parameters:
/// - 'type' The type of smoothing algorithm ('linear' or 'none')
/// - 'time_ms' The time constant for smoothing algorithm in milliseconds
/// - 'updateFrequency' The update frequency of the leds in Hz
"color" :
"transform" :
"id" : "default",
"leds" : "*",
"hsv" :
"saturationGain" : 1.1000,
"valueGain" : 1.7000
"red" :
"threshold" : 0.1600,
"gamma" : 1.9000,
"blacklevel" : 0.0000,
"whitelevel" : 0.7000
"green" :
"gamma" : 1.8500,
"whitelevel" : 0.8000
"blue" :
"gamma" : 1.8000,
"whitelevel" : 0.9000
"smoothing" :
"type" : "linear",
"time_ms" : 150,
"updateFrequency" : 30.0000
/// The configuration for each individual led. This contains the specification of the area
/// averaged of an input image for each led to determine its color. Each item in the list
/// contains the following fields:
/// * index: The index of the led. This determines its location in the string of leds; zero
/// being the first led.
/// * hscan: The fractional part of the image along the horizontal used for the averaging
/// (minimum and maximum inclusive)
/// * vscan: The fractional part of the image along the vertical used for the averaging
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.9800, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.9375, "maximum" : 1.0000 }
"index" : 1,
"vscan" : { "minimum" : 0.8875, "maximum" : 0.9625 }
"index" : 2,
"vscan" : { "minimum" : 0.8375, "maximum" : 0.9125 }
"index" : 3,
"vscan" : { "minimum" : 0.7875, "maximum" : 0.8625 }
"index" : 4,
"vscan" : { "minimum" : 0.7375, "maximum" : 0.8125 }
"index" : 5,
"vscan" : { "minimum" : 0.6875, "maximum" : 0.7625 }
"index" : 6,
"vscan" : { "minimum" : 0.6375, "maximum" : 0.7125 }
"index" : 7,
"vscan" : { "minimum" : 0.5875, "maximum" : 0.6625 }
"index" : 8,
"vscan" : { "minimum" : 0.5375, "maximum" : 0.6125 }
"index" : 9,
"vscan" : { "minimum" : 0.4875, "maximum" : 0.5625 }
"index" : 10,
"vscan" : { "minimum" : 0.4375, "maximum" : 0.5125 }
"index" : 11,
"vscan" : { "minimum" : 0.3875, "maximum" : 0.4625 }
"index" : 12,
"vscan" : { "minimum" : 0.3375, "maximum" : 0.4125 }
"index" : 13,
"vscan" : { "minimum" : 0.2875, "maximum" : 0.3625 }
"index" : 14,
"vscan" : { "minimum" : 0.2375, "maximum" : 0.3125 }
"index" : 15,
"vscan" : { "minimum" : 0.1875, "maximum" : 0.2625 }
"index" : 16,
"vscan" : { "minimum" : 0.1375, "maximum" : 0.2125 }
"index" : 17,
"vscan" : { "minimum" : 0.0875, "maximum" : 0.1625 }
"index" : 18,
"vscan" : { "minimum" : 0.0375, "maximum" : 0.1125 }
"index" : 19,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0625 }
"index" : 20,
"hscan" : { "minimum" : 0.9662, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0300 }
"index" : 21,
"hscan" : { "minimum" : 0.9392, "maximum" : 0.9797 },
"index" : 22,
"hscan" : { "minimum" : 0.9122, "maximum" : 0.9527 },
"index" : 23,
"hscan" : { "minimum" : 0.8851, "maximum" : 0.9257 },
"index" : 24,
"hscan" : { "minimum" : 0.8581, "maximum" : 0.8986 },
"index" : 25,
"hscan" : { "minimum" : 0.8311, "maximum" : 0.8716 },
"index" : 26,
"hscan" : { "minimum" : 0.8041, "maximum" : 0.8446 },
"index" : 27,
"hscan" : { "minimum" : 0.7770, "maximum" : 0.8176 },
"index" : 28,
"hscan" : { "minimum" : 0.7500, "maximum" : 0.7905 },
"index" : 29,
"hscan" : { "minimum" : 0.7230, "maximum" : 0.7635 },
"index" : 30,
"hscan" : { "minimum" : 0.6959, "maximum" : 0.7365 },
"index" : 31,
"hscan" : { "minimum" : 0.6689, "maximum" : 0.7095 },
"index" : 32,
"hscan" : { "minimum" : 0.6419, "maximum" : 0.6824 },
"index" : 33,
"hscan" : { "minimum" : 0.6149, "maximum" : 0.6554 },
"index" : 34,
"hscan" : { "minimum" : 0.5878, "maximum" : 0.6284 },
"index" : 35,
"hscan" : { "minimum" : 0.5608, "maximum" : 0.6014 },
"index" : 36,
"hscan" : { "minimum" : 0.5338, "maximum" : 0.5743 },
"index" : 37,
"hscan" : { "minimum" : 0.5068, "maximum" : 0.5473 },
"index" : 38,
"hscan" : { "minimum" : 0.4797, "maximum" : 0.5203 },
"index" : 39,
"hscan" : { "minimum" : 0.4527, "maximum" : 0.4932 },
"index" : 40,
"hscan" : { "minimum" : 0.4257, "maximum" : 0.4662 },
"index" : 41,
"hscan" : { "minimum" : 0.3986, "maximum" : 0.4392 },
"index" : 42,
"hscan" : { "minimum" : 0.3716, "maximum" : 0.4122 },
"index" : 43,
"hscan" : { "minimum" : 0.3446, "maximum" : 0.3851 },
"index" : 44,
"hscan" : { "minimum" : 0.3176, "maximum" : 0.3581 },
"index" : 45,
"hscan" : { "minimum" : 0.2905, "maximum" : 0.3311 },
"index" : 46,
"hscan" : { "minimum" : 0.2635, "maximum" : 0.3041 },
"index" : 47,
"hscan" : { "minimum" : 0.2365, "maximum" : 0.2770 },
"index" : 48,
"hscan" : { "minimum" : 0.2095, "maximum" : 0.2500 },
"index" : 49,
"hscan" : { "minimum" : 0.1824, "maximum" : 0.2230 },
"index" : 50,
"hscan" : { "minimum" : 0.1554, "maximum" : 0.1959 },
"index" : 51,
"hscan" : { "minimum" : 0.1284, "maximum" : 0.1689 },
"index" : 52,
"hscan" : { "minimum" : 0.1014, "maximum" : 0.1419 },
"index" : 53,
"hscan" : { "minimum" : 0.0743, "maximum" : 0.1149 },
"index" : 54,
"hscan" : { "minimum" : 0.0473, "maximum" : 0.0878 },
"index" : 55,
"hscan" : { "minimum" : 0.0203, "maximum" : 0.0608 },
"index" : 56,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0338 },
"index" : 57,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0200 },
"index" : 58,
"index" : 59,
"index" : 60,
"index" : 61,
"index" : 62,
"index" : 63,
"index" : 64,
"index" : 65,
"index" : 66,
"index" : 67,
"index" : 68,
"index" : 69,
"index" : 70,
"index" : 71,
"index" : 72,
"index" : 73,
"index" : 74,
"index" : 75,
"index" : 76,
"index" : 77,
"vscan" : { "minimum" : 0.9700, "maximum" : 1.0000 }
"index" : 78,
"index" : 79,
"index" : 80,
"index" : 81,
"index" : 82,
"index" : 83,
"index" : 84,
"index" : 85,
"index" : 86,
"index" : 87,
"index" : 88,
"index" : 89,
"index" : 90,
"index" : 91,
"index" : 92,
"index" : 93,
"index" : 94,
"index" : 95,
"index" : 96,
"index" : 97,
"index" : 98,
"index" : 99,
"index" : 100,
"index" : 101,
"index" : 102,
"index" : 103,
"index" : 104,
"index" : 105,
"index" : 106,
"index" : 107,
"index" : 108,
"index" : 109,
"index" : 110,
"index" : 111,
"index" : 112,
"index" : 113,
/// The black border configuration, contains the following items:
/// * enable : true if the detector should be activated
/// * threshold : Value below which a pixel is regarded as black (value between 0.0 and 1.0)
"blackborderdetector" :
"enable" : true,
"threshold" : 0.1
/// The configuration of the effect engine, contains the following items:
/// * paths : An array with absolute location(s) of directories with effects
/// * bootsequence : The effect selected as 'boot sequence'
"effects" :
"paths" :
"/opt/hyperion/effects"
"bootsequence" :
"duration_ms" : 5000
/// The configuration for the frame-grabber, contains the following items:
/// * width : The width of the grabbed frames [pixels]
/// * height : The height of the grabbed frames [pixels]
/// * frequency_Hz : The frequency of the frame grab [Hz]
// "framegrabber" :
// "width" : 64,
// "height" : 64,
// "frequency_Hz" : 10.0
/// The configuration of the XBMC connection used to enable and disable the frame-grabber. Contains the following fields:
/// * xbmcAddress : The IP address of the XBMC-host
/// * xbmcTcpPort : The TCP-port of the XBMC-server
/// * grabVideo : Flag indicating that the frame-grabber is on(true) during video playback
/// * grabPictures : Flag indicating that the frame-grabber is on(true) during picture show
/// * grabAudio : Flag indicating that the frame-grabber is on(true) during audio playback
/// * grabMenu : Flag indicating that the frame-grabber is on(true) in the XBMC menu
/// * grabScreensaver : Flag indicating that the frame-grabber is on(true) when XBMC is on screensaver
/// * enable3DDetection : Flag indicating that the frame-grabber should switch to a 3D compatible modus if a 3D video is playing
// "xbmcVideoChecker" :
// "xbmcAddress" : "127.0.0.1",
// "xbmcTcpPort" : 9090,
// "grabVideo" : true,
// "grabPictures" : true,
// "grabAudio" : true,
// "grabMenu" : false,
// "grabScreensaver" : true,
// "enable3DDetection" : true
/// The configuration of the Json server which enables the json remote interface
/// * port : Port at which the json server is started
"jsonServer" :
"port" : 19444
/// The configuration of the Proto server which enables the protobuffer remote interface
/// * port : Port at which the protobuffer server is started
"protoServer" :
"port" : 19445
/// The configuration of the boblight server which enables the boblight remote interface
/// * port : Port at which the boblight server is started
// "boblightServer" :
// "port" : 19333
"grabber-v4l2" :
"device" : "/dev/video0",
"input" : 0,
"standard" : "PAL",
"width" : -1,
"height" : -1,
"frameDecimation" : 2,
"sizeDecimation" : 8,
"priority" : 1100,
"mode" : "2D",
"cropLeft" : 5,
"cropRight" : 5,
"cropTop" : 5,
"cropBottom" : 5,
"redSignalThreshold" : 0.1,
"greenSignalThreshold" : 0.1,
"blueSignalThreshold" : 0.1
"endOfJson" : "endOfJson"
Alles anzeigen
