Die Auslagerung hat begonnen:
pi@raspberrypi:~ $ sudo smem -t -p
PID User Command Swap USS PSS RSS
747 root /usr/bin/hciattach /dev/ser 0.05% 0.00% 0.00% 0.01%
53730 root sleep 10 0.00% 0.00% 0.00% 0.04%
559 root /usr/sbin/rngd -r /dev/hwrn 0.01% 0.00% 0.00% 0.04%
962 root /sbin/agetty -o -p -- \u -- 0.00% 0.01% 0.01% 0.04%
460 avahi avahi-daemon: chroot helper 0.01% 0.00% 0.01% 0.04%
438 root /usr/sbin/cron -f 0.00% 0.01% 0.01% 0.07%
481 nobody /usr/sbin/thd --triggers /e 0.00% 0.01% 0.01% 0.07%
53748 root sudo smem -t -p 0.00% 0.00% 0.01% 0.04%
955 root /usr/sbin/dhcpcd -w -q 0.14% 0.01% 0.01% 0.04%
441 root /bin/bash /usr/bin/deCONZ-u 0.00% 0.01% 0.02% 0.09%
53747 root sudo smem -t -p 0.00% 0.02% 0.03% 0.11%
439 messagebus /usr/bin/dbus-daemon --syst 0.00% 0.03% 0.03% 0.11%
437 avahi avahi-daemon: running [rasp 0.00% 0.04% 0.04% 0.11%
405 systemd-timesync /lib/systemd/systemd-timesy 0.00% 0.03% 0.04% 0.18%
1409 pi sshd: pi@pts/0 0.00% 0.02% 0.04% 0.17%
3313 pi sshd: pi@pts/1 0.00% 0.02% 0.04% 0.18%
3431 pi sshd: pi@pts/2 0.00% 0.02% 0.04% 0.18%
1390 pi (sd-pam) 1.58% 0.01% 0.05% 0.12%
459 root /usr/sbin/rsyslogd -n -iNON 0.00% 0.05% 0.05% 0.11%
467 root /lib/systemd/systemd-logind 0.00% 0.03% 0.05% 0.19%
1321 root sshd: pi [priv] 0.00% 0.01% 0.05% 0.26%
3305 root sshd: pi [priv] 0.00% 0.01% 0.05% 0.26%
3424 root sshd: pi [priv] 0.00% 0.01% 0.05% 0.26%
678 root sshd: /usr/sbin/sshd -D [li 0.00% 0.03% 0.05% 0.23%
1410 pi -bash 0.00% 0.04% 0.05% 0.13%
3432 pi -bash 0.00% 0.04% 0.05% 0.13%
784 root /usr/libexec/bluetooth/blue 0.00% 0.05% 0.06% 0.14%
3314 pi -bash 0.00% 0.04% 0.06% 0.13%
1751 homebridge /usr/lib/chromium/chromium 0.00% 0.01% 0.06% 0.43%
662 root /sbin/wpa_supplicant -u -s 0.00% 0.07% 0.07% 0.16%
1389 pi /lib/systemd/systemd --user 0.00% 0.05% 0.09% 0.26%
447 polkitd /usr/lib/polkit-1/polkitd - 0.00% 0.07% 0.10% 0.22%
179 root /lib/systemd/systemd-udevd 0.00% 0.10% 0.10% 0.18%
1810 homebridge /usr/lib/chromium/chromium 0.00% 0.01% 0.12% 0.42%
1 root /sbin/init 0.00% 0.05% 0.13% 0.34%
665 root /usr/sbin/ModemManager 0.00% 0.12% 0.15% 0.27%
146 root /lib/systemd/systemd-journa 0.00% 0.32% 0.34% 0.47%
1771 homebridge /usr/lib/chromium/chromium 0.00% 0.11% 0.39% 2.19%
53749 root /usr/bin/python3 /usr/bin/s 0.00% 0.39% 0.39% 0.45%
2003 iobroker /opt/iobroker/node_modules/ 0.00% 0.41% 0.41% 0.41%
1856 homebridge /usr/lib/chromium/chromium 0.00% 0.12% 0.43% 2.34%
1749 homebridge /usr/lib/chromium/chromium 0.00% 0.01% 0.61% 3.25%
1748 homebridge /usr/lib/chromium/chromium 0.00% 0.02% 0.67% 3.24%
673 root /usr/sbin/tailscaled --stat 0.00% 0.93% 0.93% 0.93%
1699 iobroker io.discovery.0 0.00% 0.95% 0.98% 1.91%
1768 homebridge /usr/lib/chromium/chromium 0.00% 0.42% 1.04% 3.65%
1629 iobroker io.backitup.0 0.00% 1.05% 1.10% 2.15%
1636 iobroker io.cloud.0 0.00% 1.09% 1.13% 2.08%
442 pi /usr/bin/deCONZ -platform m 0.00% 1.12% 1.16% 1.43%
1981 iobroker io.simple-api.0 0.00% 1.16% 1.20% 2.12%
2132 iobroker io.followthesun.0 0.00% 1.17% 1.22% 2.28%
1882 iobroker io.logparser.0 0.00% 1.19% 1.24% 2.29%
1542 iobroker io.mqtt.0 0.00% 1.21% 1.25% 2.17%
1871 iobroker io.info.0 0.00% 1.29% 1.33% 2.28%
2080 iobroker io.yahka.0 0.00% 1.30% 1.34% 2.28%
1706 homebridge /usr/lib/chromium/chromium 0.00% 0.69% 1.35% 4.11%
1651 iobroker io.deconz.0 0.00% 1.34% 1.38% 2.32%
2159 iobroker io.shuttercontrol.1 0.00% 1.36% 1.41% 2.46%
1379 iobroker io.modbus.0 0.00% 1.38% 1.41% 2.34%
2073 iobroker io.wiffi-wz.0 0.00% 1.38% 1.42% 2.34%
1496 homebridge homebridge: @milo526/homebr 0.00% 1.29% 1.44% 2.45%
22282 homebridge /usr/lib/chromium/chromium 0.00% 0.94% 1.45% 3.83%
1497 homebridge homebridge: homebridge-ewel 0.00% 1.33% 1.47% 2.49%
1510 homebridge homebridge: homebridge-shel 0.00% 1.37% 1.50% 2.47%
3656 homebridge /usr/lib/chromium/chromium 0.00% 1.00% 1.50% 3.87%
2777 homebridge /usr/lib/chromium/chromium 0.00% 1.02% 1.51% 3.87%
1921 iobroker io.shuttercontrol.0 0.00% 1.46% 1.51% 2.57%
1505 homebridge homebridge: homebridge-webs 0.00% 1.45% 1.58% 2.56%
1211 iobroker io.telegram.0 0.00% 1.61% 1.66% 2.73%
1728 iobroker io.eusec.0 0.00% 1.83% 1.89% 2.98%
1809 homebridge /usr/lib/chromium/chromium 0.00% 1.56% 1.90% 3.04%
1427 iobroker io.shelly.1 0.00% 1.90% 1.94% 2.86%
2051 iobroker io.vw-connect.0 0.00% 1.89% 1.95% 2.92%
1503 homebridge homebridge: homebridge-home 0.00% 1.87% 2.01% 3.01%
2058 iobroker io.web.0 0.00% 2.03% 2.07% 3.01%
1512 homebridge homebridge: homebridge-eufy 0.00% 2.26% 2.40% 3.40%
1138 homebridge hb-service 0.00% 2.38% 2.52% 3.52%
1300 iobroker io.tuya.0 0.00% 2.49% 2.54% 3.61%
1323 homebridge homebridge 0.00% 2.42% 2.56% 3.55%
1077 iobroker io.admin.0 0.00% 2.68% 2.73% 3.81%
1150 iobroker io.javascript.0 0.00% 3.66% 3.71% 4.78%
1291 iobroker io.shelly.0 0.00% 4.92% 4.96% 5.89%
666 iobroker iobroker.js-controller 0.00% 8.77% 8.84% 9.93%
83 9 1.79% 73.52% 81.53% 140.42%
Alles anzeigen
Und der Speicher geht auch weiterhin in die Knie:
pi@raspberrypi:~ $ free -m
total used free shared buff/cache available
Mem: 3743 2518 465 1 835 1224
Swap: 99 0 99
Mem: 3743 2621 245 1 953 1122
Swap: 99 0 99
Mem: 3743 2707 192 1 920 1036
Swap: 99 0 99
Mem: 3743 2845 156 0 816 897
Swap: 99 1 98
Mem: 3743 2890 136 0 791 852
Swap: 99 3 96
pi@raspberrypi:~ $
Alles anzeigen
Hab zwischendurch auch mal
ausgeführt. Hat aber nicht zu einer signifikanten Änderung des Speicherverhaltens geführt.
