http://ip-der-pv//Log/2026/06/06.log
ist genau das was ich anfrage... mit einer SW die unverändert auf Bookworm läuft.
curl https://192.168.178.28//Log/2026/06/06.log --verbose --insecure
getestet, Antwort ist im Header
* Trying 192.168.178.28:443...
* schannel: disabled automatic use of client certificate
* schannel: using IP address, SNI is not supported by OS.
* ALPN: curl offers http/1.1
* ALPN: server accepted http/1.1
* Established connection to 192.168.178.28 (192.168.178.28 port 443) from 192.168.178.37 port 52539
* using HTTP/1.x
> GET //Log/2026/06/06.log HTTP/1.1
> Host: 192.168.178.28
> User-Agent: curl/8.19.0
> Accept: */*
* Request completely sent off
< HTTP/1.1 200 OK
< Server: nginx/1.17.7
< Date: Wed, 10 Jun 2026 08:55:47 GMT
< Content-Type: text/plain; charset=utf-8
< Content-Length: 54142
< Connection: keep-alive
und danach kommen genau die Daten die ich haben will... in Windows, im Dos-Prompt.
Auf dem Raspi kommt als Header (vor den Daten):
* ALPN: curl offers h2,http/1.1
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES256-GCM-SHA384 / x25519 / RSASSA-PSS
* Server certificate:
* subject: C=DE; ST=Saxony; L=Leipzig; O=SENEC GmbH; CN=senecGuiSelf
* start date: Apr 20 09:29:51 2026 GMT
* expire date: Apr 17 09:29:51 2036 GMT
* issuer: C=DE; ST=Saxony; L=Leipzig; O=SENEC GmbH; CN=SenecGui-Root
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
* Connected to 192.168.178.28 (192.168.178.28) port 443
* using HTTP/1.x
> User-Agent: curl/8.14.1
> Accept: */*
< HTTP/1.1 200 OK
< Date: Wed, 10 Jun 2026 08:58:32 GMT
und danach dann die Daten die ich sehen will.....
