[ 0.000000] Booting Linux on physical CPU 0xa00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.8.13.16 (root@m1server) (gcc version 4.7.2 (crosstool-NG 1.17.0) ) #1 SMP PREEMPT Tue Feb 11 10:47:21 BRST 2014 ()
[ 0.000000] Kernel was built at commit id 'd222295'
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: ODROID-U2/U3
[ 0.000000] cma: CMA: reserved 64 MiB at 43000000
[ 0.000000] cma: CMA: reserved 64 MiB at 51000000
[ 0.000000] cma: CMA: reserved 128 MiB at 67800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] CPU EXYNOS4412 (id 0xe4412220)
[ 0.000000] exynos4_init_clocks: initializing clocks
[ 0.000000] S3C24XX Clocks, Copyright 2004 Simtec Electronics
[ 0.000000] s3c_register_clksrc: clock armclk has no registers set
[ 0.000000] s3c_register_clksrc: clock audiocdclk has no registers set
[ 0.000000] audiocdclk: no parent clock specified
[ 0.000000] exynos4_setup_clocks: registering clocks
[ 0.000000] exynos4_setup_clocks: xtal is 24000000
[ 0.000000] EXYNOS4: PLL settings, A=1000000000, M=880000000, E=96000000 V=350000000
[ 0.000000] EXYNOS4: ARMCLK=1000000000, DMC=440000000, ACLK200=176000000
[ 0.000000] ACLK100=110000000, ACLK160=176000000, ACLK133=146666666
[ 0.000000] sclk_pwm: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_csis: source is xusbxti (1), rate is 1500000
[ 0.000000] sclk_cam0: source is xusbxti (1), rate is 1500000
[ 0.000000] sclk_cam1: source is xusbxti (1), rate is 1500000
[ 0.000000] sclk_fimc: source is xusbxti (1), rate is 1500000
[ 0.000000] sclk_fimd: source is mout_mpll_user (6), rate is 55000000
[ 0.000000] sclk_mfc: source is mout_mfc0 (0), rate is 55000000
[ 0.000000] sclk_g3d: source is mout_g3d0 (0), rate is 55000000
[ 0.000000] On node 0 totalpages: 524032
[ 0.000000] Normal zone: 1520 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 193040 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2574 pages used for memmap
[ 0.000000] HighMem zone: 326898 pages, LIFO batch:31
[ 0.000000] Running under secure firmware.
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c16bf000 s7936 r8192 d12544 u32768
[ 0.000000] pcpu-alloc: s7936 r8192 d12544 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519938
[ 0.000000] Kernel command line: console=tty1 console=ttySAC1,115200 mem=2047M fbcon=map:1111111111111111111111111111 console=tty1 console=ttySAC1,115200n8 drm_kms_helper.edid_firmware=edid/1920x1080.bin root=UUID=e139ce78-9841-40fe-8823-96a304a09859 rootwait ro mem=2047M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] Memory: 2047MB = 2047MB total
[ 0.000000] Memory: 1806336k/3612672k available, 579584k reserved, 1317888K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05dc580 (5970 kB)
[ 0.000000] .init : 0xc05dd000 - 0xc0607f00 ( 172 kB)
[ 0.000000] .data : 0xc0608000 - 0xc066d960 ( 407 kB)
[ 0.000000] .bss : 0xc066d960 - 0xc06a9d50 ( 241 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:549
[ 0.000000] MCT clocksource init timer with clk_rate=24000000 hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000804] Calibrating delay loop... 1992.29 BogoMIPS (lpj=4980736)
[ 0.045063] pid_max: default: 32768 minimum: 301
[ 0.045348] Mount-cache hash table entries: 512
[ 0.046361] Initializing cgroup subsys cpuacct
[ 0.046397] Initializing cgroup subsys devices
[ 0.046457] CPU: Testing write buffer coherency: ok
[ 0.046778] CPU0: thread -1, cpu 0, socket 10, mpidr 80000a00
[ 0.046900] Setting up static identity map for 0x4044ee48 - 0x4044eea0
[ 0.046975] L310 cache controller enabled
[ 0.047002] l2x0: 16 ways, CACHE_ID 0x4100c4c8, AUX_CTRL 0x7e470001, Cache size: 1048576 B
[ 0.097130] CPU1: Booted secondary processor
[ 0.116833] CPU1: thread -1, cpu 1, socket 10, mpidr 80000a01
[ 0.127120] CPU2: Booted secondary processor
[ 0.146833] CPU2: thread -1, cpu 2, socket 10, mpidr 80000a02
[ 0.157137] CPU3: Booted secondary processor
[ 0.176834] CPU3: thread -1, cpu 3, socket 10, mpidr 80000a03
[ 0.176865] Brought up 4 CPUs
[ 0.176938] SMP: Total of 4 processors activated (7969.17 BogoMIPS).
[ 0.177764] devtmpfs: initialized
[ 0.184092] regulator-dummy: no parameters
[ 0.191273] NET: Registered protocol family 16
[ 0.198605] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.203706] s5p_hdmi_cec_set_platdata()
[ 0.208048] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.208074] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.208169] S3C Power Management, Copyright 2004 Simtec Electronics
[ 0.208257] EXYNOS4x12 PMU Initialize
[ 0.210155] EXYNOS: Initializing architecture
[ 0.210926] s3c24xx-pwm s3c24xx-pwm.0: tin at 110000000, tdiv at 110000000, tin=divclk, base 0
[ 0.211004] s3c24xx-pwm s3c24xx-pwm.1: tin at 110000000, tdiv at 110000000, tin=divclk, base 8
[ 0.223986] bio: create slab <bio-0> at 0
[ 0.224513] hdmi_5v: 5000 mV
[ 0.225881] usbcore: registered new interface driver usbfs
[ 0.225998] usbcore: registered new interface driver hub
[ 0.226128] usbcore: registered new device driver usb
[ 0.226756] i2c-gpio i2c-gpio.2: using pins 6 (SDA) and 7 (SCL)
[ 0.226953] i2c-gpio i2c-gpio.4: using pins 200 (SDA) and 199 (SCL)
[ 0.227140] s3c-i2c s3c2440-i2c.0: slave address 0x10
[ 0.227164] s3c-i2c s3c2440-i2c.0: bus frequency set to 214 KHz
[ 0.227702] max77686 0-0009: device found
[ 0.229630] LDO1 VDD_ALIVE: 1000 mV
[ 0.231101] LDO2 VDDQ_M1_1V8: 1800 mV
[ 0.232555] LDO3 VDDQ_AUD_1V8: 1800 mV
[ 0.234060] LDO4 VDDQ_MMC2_2V8: 2800 mV
[ 0.235503] LDO5 VDDQ_MMC1_1V8: 1800 mV
[ 0.236950] LDO6 VDD10_MPLL_1V0: 1000 mV
[ 0.238394] LDO7 VDD10_EPLL_1V0: 1000 mV
[ 0.239849] LDO8 VDD10_MIPI_1V0: 1000 mV
[ 0.241094] LDO9 VT_CORE_1V0: ODROIDU2: Disabled regulator
[ 0.241114] LDO9 VT_CORE_1V0: 1000 mV
[ 0.241934] LDO10 VDD18_MIPI_1V8: 1800 mV
[ 0.244158] LDO11 VDD18_ABB1_1V8: 1800 mV
[ 0.244996] vdd_ldo12 range: 3300 mV
[ 0.246442] LDO13 VDD18_MIPIHSI_1V8: 1800 mV
[ 0.247908] LDO14 VDD18_ADC_1V8: 1800 mV
[ 0.248727] vdd_ldo15 range: 1000 mV
[ 0.250178] LDO16 VDD18_HSIC: 1800 mV
[ 0.251622] LDO17 VDDQ_CAM_1V8: 1800 mV
[ 0.252870] LDO18 VDDQ_ISP_1V8: ODROIDU2: Disabled regulator
[ 0.252889] LDO18 VDDQ_ISP_1V8: 1800 mV
[ 0.253506] LDO19 VT_CAM_1V8: ODROIDU2: Disabled regulator
[ 0.253525] LDO19 VT_CAM_1V8: 1800 mV
[ 0.254501] vddq_emmc_1V8: 1800 <--> 3000 mV at 1800 mV
[ 0.255948] LDO21 TFLASH_2V8: 2800 mV
[ 0.257393] vddf_emmc_2V85: 2850 mV
[ 0.258637] LDO23 VDD_TOUCH_2V8: ODROIDU2: Disabled regulator
[ 0.258657] LDO23 VDD_TOUCH_2V8: 2800 mV
[ 0.259912] LDO24 VDD_TOUCHLED_3V3: ODROIDU2: Disabled regulator
[ 0.259933] LDO24 VDD_TOUCHLED_3V3: 3300 mV
[ 0.261383] LDO25 VDDQ_LCD_3V0: 1800 mV
[ 0.262621] LDO26 VDD_MOTOR_3V0: ODROIDU2: Disabled regulator
[ 0.262640] LDO26 VDD_MOTOR_3V0: 3000 mV
[ 0.263261] BUCK1 vdd_mif: 1100 mV
[ 0.264081] BUCK2 vdd_arm: 800 <--> 1500 mV at 1350 mV
[ 0.264710] BUCK3 vdd_int: 1125 mV
[ 0.265535] BUCK4 vdd_g3d: 850 <--> 1200 mV at 1125 mV
[ 0.266982] BUCK5 VDDQ_CKEM1_2: 1200 mV
[ 0.268430] BUCK6 1V35: 1350 mV
[ 0.269881] BUCK7 2V0: 2000 mV
[ 0.270710] ODROIDU2: Regulator BUCK8
[ 0.391565] BUCK8 3V0: 3300 mV
[ 0.392824] BUCK9 1V2: ODROIDU2: Disabled regulator
[ 0.392841] BUCK9 1V2: 1200 mV
[ 0.393377] s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter
[ 0.393455] s3c-i2c s3c2440-i2c.1: slave address 0x10
[ 0.393477] s3c-i2c s3c2440-i2c.1: bus frequency set to 214 KHz
[ 0.393762] s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter
[ 0.393830] s3c-i2c s3c2440-i2c.3: slave address 0x10
[ 0.393853] s3c-i2c s3c2440-i2c.3: bus frequency set to 214 KHz
[ 0.394009] s3c-i2c s3c2440-i2c.3: i2c-3: S3C I2C adapter
[ 0.394077] s3c-i2c s3c2440-i2c.7: slave address 0x10
[ 0.394098] s3c-i2c s3c2440-i2c.7: bus frequency set to 214 KHz
[ 0.394257] s3c-i2c s3c2440-i2c.7: i2c-7: S3C I2C adapter
[ 0.394326] s3c-i2c s3c2440-hdmiphy-i2c: slave address 0x10
[ 0.394347] s3c-i2c s3c2440-hdmiphy-i2c: bus frequency set to 214 KHz
[ 0.394624] s3c-i2c s3c2440-hdmiphy-i2c: i2c-8: S3C I2C adapter
[ 0.394741] media: Linux media interface: v0.10
[ 0.394848] Linux video capture interface: v2.00
[ 0.395592] Advanced Linux Sound Architecture Driver Initialized.
[ 0.396533] cfg80211: Calling CRDA to update world regulatory domain
[ 0.397180] Switching to clocksource mct-frc
[ 0.409162] NET: Registered protocol family 2
[ 0.409636] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.409769] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 0.409930] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.409993] TCP: reno registered
[ 0.410014] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 0.410059] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 0.410292] NET: Registered protocol family 1
[ 0.410456] Trying to unpack rootfs image as initramfs...
[ 0.558357] Freeing initrd memory: 2872K
[ 0.558572] CPU PMU: probing PMU on CPU 1
[ 0.558600] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.560430] bounce pool size: 64 pages
[ 0.569647] msgmni has been set to 1471
[ 0.570452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.570463] io scheduler noop registered
[ 0.570478] io scheduler deadline registered
[ 0.570682] io scheduler cfq registered (default)
[ 0.578789] s3c-fb exynos4-fb.0: start latency exceeded, new value 584 ns
[ 0.578847] s3c-fb exynos4-fb.0: state restore latency exceeded, new value 33250 ns
[ 0.588322] s3c-fb exynos4-fb.0: window 0: fb
[ 0.592832] dma-pl330 dma-pl330.0: Loaded driver for PL330 DMAC-267056
[ 0.592857] dma-pl330 dma-pl330.0: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.596973] dma-pl330 dma-pl330.1: Loaded driver for PL330 DMAC-267056
[ 0.596998] dma-pl330 dma-pl330.1: DBUFF-32x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32
[ 0.598343] dma-pl330 dma-pl330.2: Loaded driver for PL330 DMAC-267056
[ 0.598366] dma-pl330 dma-pl330.2: DBUFF-64x8bytes Num_Chans-8 Num_Peri-1 Num_Events-32
[ 0.672076] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.673334] exynos4210-uart.0: ttySAC0 at MMIO 0x13800000 (irq = 84) is a S3C6400/10
[ 0.673635] exynos4210-uart.1: ttySAC1 at MMIO 0x13810000 (irq = 85) is a S3C6400/10
[ 1.691618] console [ttySAC1] enabled
[ 1.695583] exynos4210-uart.2: ttySAC2 at MMIO 0x13820000 (irq = 86) is a S3C6400/10
[ 1.703260] exynos4210-uart.3: ttySAC3 at MMIO 0x13830000 (irq = 87) is a S3C6400/10
[ 1.711289] [drm] Initialized drm 1.1.0 20060810
[ 1.715634] i2c i2c-2: attached s5p_ddc into i2c adapter successfully
[ 1.721855] i2c i2c-8: attached s5p_hdmiphy into i2c adapter successfully
[ 1.728864] exynos-mixer s5p-mixer: probe start
[ 1.733561] s5p-g2d s5p-g2d.0: The exynos g2d(ver 4.1) successfully probed
[ 1.740750] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 1.746445] [drm] No driver support for vblank timestamp query.
[ 1.753037] exynos-drm exynos-drm: No connectors reported connected with modes
[ 1.759549] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.779161] Console: switching to colour frame buffer device 128x48
[ 1.787134] exynos-drm exynos-drm: fb1: frame buffer device
[ 1.792772] exynos-drm exynos-drm: registered panic notifier
[ 1.798412] [drm] Initialized exynos 1.0.0 20110530 on minor 0
[ 1.804229] Mali<2>: Inserting Mali v19 device driver.
[ 1.809379] Mali<2>: Compiled: Feb 11 2014, time: 10:25:44.
[ 1.814934] Mali<2>: Driver revision:
[ 1.818638] Mali<2>: mali_module_init() registering driver
[ 1.824164] Mali<2>: mali_probe(): Called for platform device mali-utgard
[ 1.830915] Mali<2>: Memory system initializing
[ 1.835379] Mali<2>: Using device defined memory settings (dedicated: 0x00000000@0x00000000, shared: 0x10000000)
[ 1.845618] Mali<2>: Mali OS memory allocator created with max allocation size of 0x10000000 bytes, cpu_usage_adjust 0x00000000
[ 1.857088] Mali<2>: Using device defined frame buffer settings (0x00000000@0x00000000)
[ 1.868490] mali-utgard mali-utgard.0: start latency exceeded, new value 500 ns
[ 1.875815] mali-utgard mali-utgard.0: state restore latency exceeded, new value 2916 ns
[ 1.883871] Mali<2>: Mali PP: Creating Mali PP core: Mali_PP0
[ 1.889525] Mali<2>: Mali PP: Base address of PP core: 0x13008000
[ 1.895632] Mali<2>: Found Mali GPU Mali-400 MP r1p1
[ 1.901662] Mali<2>: Mali L2 cache: Creating Mali L2 cache: Mali_L2
[ 1.906746] Mali<2>: Mali MMU: Creating Mali MMU: Mali_GP_MMU
[ 1.912462] Mali<2>: Mali GP: Creating Mali GP core: Mali_GP
[ 1.918054] Mali<2>: Mali MMU: Creating Mali MMU: Mali_PP0_MMU
[ 1.923821] Mali<2>: Mali PP: Creating Mali PP core: Mali_PP0
[ 1.929492] Mali<2>: Mali PP: Base address of PP core: 0x13008000
[ 1.935550] Mali<2>: Mali MMU: Creating Mali MMU: Mali_PP1_MMU
[ 1.941312] Mali<2>: Mali PP: Creating Mali PP core: Mali_PP1
[ 1.946981] Mali<2>: Mali PP: Base address of PP core: 0x1300a000
[ 1.953083] Mali<2>: Mali MMU: Creating Mali MMU: Mali_PP2_MMU
[ 1.958856] Mali<2>: Mali PP: Creating Mali PP core: Mali_PP2
[ 1.964520] Mali<2>: Mali PP: Base address of PP core: 0x1300c000
[ 1.970594] Mali<2>: Mali MMU: Creating Mali MMU: Mali_PP3_MMU
[ 1.976349] Mali<2>: Mali PP: Creating Mali PP core: Mali_PP3
[ 1.982032] Mali<2>: Mali PP: Base address of PP core: 0x1300e000
[ 1.988107] Mali<2>: 4+0 PP cores initialized
[ 1.992402] Mali<2>: Mali GPU Utilization: No utilization handler installed
[ 1.999394] Mali<2>: = clk_set_rate : 533 , 1000000
[ 2.004660] Mali<2>: = clk_get_rate: 533
[ 2.008194] Mali: init_mali_clock mali_clock c062faa8
[ 2.013624] Mali<1>: = regulator_enable -> use cnt: 1
[ 2.018399] Mali<2>: = regulator_set_voltage: 1125000, 1125000
[ 2.025417] Mali<1>: = regulator_get_voltage: 1125000
[ 2.029310] Mali<2>: MALI Clock is set at mali driver
[ 2.034766] Mali<2>: mali_probe(): Successfully initialized driver for platform device mali-utgard
[ 2.043370] mali-utgard mali-utgard.0: stop latency exceeded, new value 500 ns
[ 2.050642] mali-utgard mali-utgard.0: state save latency exceeded, new value 4000 ns
[ 2.058782] Mali: Mali device driver loaded
[ 2.062796] UMP: UMP device driver loaded
[ 2.074086] brd: module loaded
[ 2.081037] loop: module loaded
[ 2.084086] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.088213] s5p-ehci s5p-ehci: S5P EHCI Host Controller
[ 2.093218] s5p-ehci s5p-ehci: new USB bus registered, assigned bus number 1
[ 2.100621] s5p-ehci s5p-ehci: irq 102, io mem 0x12580000
[ 2.112247] s5p-ehci s5p-ehci: USB 2.0 started, EHCI 1.00
[ 2.115075] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.121486] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.128647] usb usb1: Product: S5P EHCI Host Controller
[ 2.133836] usb usb1: Manufacturer: Linux 3.8.13.16 ehci_hcd
[ 2.139436] usb usb1: SerialNumber: s5p-ehci
[ 2.144155] hub 1-0:1.0: USB hub found
[ 2.147385] hub 1-0:1.0: 3 ports detected
[ 2.151699] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.157626] exynos-ohci exynos-ohci: Already power on PHY
[ 2.162930] exynos-ohci exynos-ohci: EXYNOS OHCI Host Controller
[ 2.168915] exynos-ohci exynos-ohci: new USB bus registered, assigned bus number 2
[ 2.176502] exynos-ohci exynos-ohci: irq 102, io mem 0x12590000
[ 2.241289] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.245102] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.252342] usb usb2: Product: EXYNOS OHCI Host Controller
[ 2.257771] usb usb2: Manufacturer: Linux 3.8.13.16 ohci_hcd
[ 2.263405] usb usb2: SerialNumber: exynos-ohci
[ 2.268358] hub 2-0:1.0: USB hub found
[ 2.271614] hub 2-0:1.0: 3 ports detected
[ 2.392483] usb3503 0-0008: USB3503_SP_ILOCK = 0x32
[ 2.462250] usb 1-2: new high-speed USB device number 2 using s5p-ehci
[ 2.497242] usb3503 0-0008: switched to HUB mode
[ 2.499961] usb3503 0-0008: usb3503_probe: probed on hub mode
[ 2.504863] s3c-hsotg s3c-hsotg: regs f0080000, irq 103
[ 2.510502] s3c-hsotg s3c-hsotg: Already power on PHY
[ 2.514950] s3c-hsotg s3c-hsotg: EPs:15
[ 2.518693] s3c-hsotg s3c-hsotg: dedicated fifos
[ 2.523293] s3c-hsotg s3c-hsotg: still being used
[ 2.528400] max77686-rtc max77686-rtc: max77686_rtc_probe
[ 2.592639] usb 1-2: New USB device found, idVendor=0424, idProduct=9730
[ 2.596373] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.632941] max77686-rtc max77686-rtc: rtc core: registered max77686-rtc as rtc0
[ 2.639893] s5p-fimc exynos4-fimc.0: sclk_fimc rate is 176000000
[ 2.643369] s5p-fimc exynos4-fimc.0: start latency exceeded, new value 625 ns
[ 2.650445] s5p-fimc exynos4-fimc.0: state restore latency exceeded, new value 16167 ns
[ 2.658449] s5p-fimc exynos4-fimc.0: stop latency exceeded, new value 458 ns
[ 2.665481] s5p-fimc exynos4-fimc.0: state save latency exceeded, new value 3333 ns
[ 2.665550] s5p-fimc exynos4-fimc.1: sclk_fimc rate is 176000000
[ 2.679075] s5p-fimc exynos4-fimc.0: stop latency exceeded, new value 500 ns
[ 2.686107] s5p-fimc exynos4-fimc.1: start latency exceeded, new value 459 ns
[ 2.693229] s5p-fimc exynos4-fimc.1: state restore latency exceeded, new value 15417 ns
[ 2.701209] s5p-fimc exynos4-fimc.1: stop latency exceeded, new value 500 ns
[ 2.708245] s5p-fimc exynos4-fimc.1: state save latency exceeded, new value 2625 ns
[ 2.708309] s5p-fimc exynos4-fimc.2: sclk_fimc rate is 176000000
[ 2.721819] s5p-fimc exynos4-fimc.2: start latency exceeded, new value 458 ns
[ 2.728949] s5p-fimc exynos4-fimc.2: state restore latency exceeded, new value 15292 ns
[ 2.736932] s5p-fimc exynos4-fimc.2: stop latency exceeded, new value 459 ns
[ 2.743960] s5p-fimc exynos4-fimc.2: state save latency exceeded, new value 2500 ns
[ 2.747304] s5p-fimc exynos4-fimc.3: sclk_fimc rate is 176000000
[ 2.757615] s5p-fimc exynos4-fimc.3: start latency exceeded, new value 458 ns
[ 2.764731] s5p-fimc exynos4-fimc.3: state restore latency exceeded, new value 15083 ns
[ 2.772709] s5p-fimc exynos4-fimc.3: stop latency exceeded, new value 458 ns
[ 2.779733] s5p-fimc exynos4-fimc.3: start latency exceeded, new value 500 ns
[ 2.786907] s5p-fimc exynos4-fimc.3: state save latency exceeded, new value 2791 ns
[ 2.787413] s5p-fimc-md: Registered fimc.0.m2m as /dev/video10
[ 2.787588] s5p-fimc-md: Registered fimc.0.capture as /dev/video11
[ 2.787762] s5p-fimc-md: Registered fimc.1.m2m as /dev/video12
[ 2.787930] s5p-fimc-md: Registered fimc.1.capture as /dev/video13
[ 2.788102] s5p-fimc-md: Registered fimc.2.m2m as /dev/video14
[ 2.788281] s5p-fimc-md: Registered fimc.2.capture as /dev/video15
[ 2.788455] s5p-fimc-md: Registered fimc.3.m2m as /dev/video16
[ 2.788629] s5p-fimc-md: Registered fimc.3.capture as /dev/video17
[ 2.789460] sclk_mfc rate is: 220
[ 2.789683] s5p-mfc s5p-mfc: decoder registered as /dev/video8
[ 2.789873] s5p-mfc s5p-mfc: encoder registered as /dev/video9
[ 2.790413] Exynos: Kernel Thermal management registered
[ 2.790646] cpuidle: using governor ladder
[ 2.790738] sdhci: Secure Digital Host Controller Interface driver
[ 2.790739] sdhci: Copyright(c) Pierre Ossman
[ 2.790826] s3c-sdhci exynos4-sdhci.2: clock source 2: mmc_busclk.2 (440000000 Hz)
[ 2.790890] mmc0: no vqmmc regulator found
[ 2.790898] mmc0: no vmmc regulator found
[ 2.817247] mmc0: SDHCI controller on samsung-hsmmc [exynos4-sdhci.2] using ADMA
[ 2.837265] usb 1-3: new high-speed USB device number 3 using s5p-ehci
[ 2.839965] mmc0: new high speed SDHC card at address b368
[ 2.840339] mmcblk0: mmc0:b368 NCard 7.48 GiB
[ 2.841686] mmcblk0: p1 p2
[ 2.919153] s5p-fimc exynos4-fimc.3: stop latency exceeded, new value 792 ns
[ 2.926536] dw_mmc dw_mmc: Using internal DMA controller.
[ 2.957264] DWMMC: Div 2 = 130
[ 2.957291] dw_mmc dw_mmc: Version ID is 240a
[ 2.957298] dw_mmc dw_mmc: DW MMC controller at irq 109, 32 bit host data width, 128 deep fifo
[ 2.970342] mmc_host mmc1: Bus speed (slot 0) = 104000000Hz (slot req 400000Hz, actual 400000HZ div = 130)
[ 2.972772] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.973229] usbcore: registered new interface driver usbhid
[ 2.973231] usbhid: USB HID core driver
[ 2.973347] cec: Probe start
[ 2.973350] s5p_cec_probe: pdata=e70b9640
[ 2.973373] s5p_cec_mem_probe(): mapped cec_base to f00a6000, size 0x1000
[ 2.973562] cec: Requesting irq 146 for s5p-cec
[ 2.973598] cec: probe successful
[ 2.997468] max98090 1-0010: MAX98090 REVID=0x43
[ 3.021641] usb 1-3: New USB device found, idVendor=0424, idProduct=3503
[ 3.028038] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.036099] hub 1-3:1.0: USB hub found
[ 3.036105] hkdk-snd-max98090 hkdk-snd-max98090: HiFi <-> samsung-i2s.0 mapping ok
[ 3.046641] hub 1-3:1.0: 3 ports detected
[ 3.052477] hkdk-snd-max98090 hkdk-snd-max98090: HiFi <-> samsung-i2s.0 mapping ok
[ 3.059822] TCP: cubic registered
[ 3.062733] NET: Registered protocol family 17
[ 3.065971] NET: Registered protocol family 15
[ 3.067253] DWMMC: Div 1 = 174
[ 3.067263] mmc_host mmc1: Bus speed (slot 0) = 104000000Hz (slot req 300000Hz, actual 298850HZ div = 174)
[ 3.083204] NET: Registered protocol family 35
[ 3.087956] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 3.095358] ThumbEE CPU extension supported.
[ 3.099623] Registering SWP/SWPB emulation handler
[ 3.106631] LDO10 VDD18_MIPI_1V8: incomplete constraints, leaving on
[ 3.111228] DRM: mali_platform_drm_probe()
[ 3.114810] mali_drm_init(), driver name: mali_drm, version 0.1
[ 3.121026] DRM: mali_driver_load()
[ 3.124244] [drm] Initialized mali_drm 0.1.0 20100520 on minor 1
[ 3.152767] max77686-rtc max77686-rtc: setting system clock to 2015-04-07 10:28:31 UTC (1428402511)
[ 3.160882] exynos4_dvfs_hotplug_init, max(2000000),min(0)
[ 3.163585] ALSA device list:
[ 3.166466] #0: Built-in Audio
[ 3.167236] DWMMC: Div 1 = 255
[ 3.167243] mmc_host mmc1: Bus speed (slot 0) = 104000000Hz (slot req 203922Hz, actual 203921HZ div = 255)
[ 3.182770] Freeing init memory: 168K
[ 3.222883] systemd-udevd[1349]: starting version 204
[ 3.247271] DWMMC: Div 2 = 130
[ 3.249234] mmc_host mmc1: Bus speed (slot 0) = 104000000Hz (slot req 400000Hz, actual 400000HZ div = 130)
[ 3.297253] DWMMC: Div 1 = 174
[ 3.299257] mmc_host mmc1: Bus speed (slot 0) = 104000000Hz (slot req 300000Hz, actual 298850HZ div = 174)
[ 3.332526] usb 1-3.2: new high-speed USB device number 4 using s5p-ehci
[ 3.352464] DWMMC: Div 1 = 255
[ 3.354714] mmc_host mmc1: Bus speed (slot 0) = 104000000Hz (slot req 203922Hz, actual 203921HZ div = 255)
[ 3.433890] usb 1-3.2: New USB device found, idVendor=04b4, idProduct=6572
[ 3.437375] usb 1-3.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.444760] usb 1-3.2: Product: USB2.0 Hub
[ 3.450030] hub 1-3.2:1.0: USB hub found
[ 3.453388] hub 1-3.2:1.0: 4 ports detected
[ 3.527840] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 3.727514] usb 1-3.2.1: new full-speed USB device number 5 using s5p-ehci
[ 3.821511] usb 1-3.2.1: New USB device found, idVendor=08bb, idProduct=2902
[ 3.826318] usb 1-3.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.832557] usb 1-3.2.1: Product: USB Audio CODEC
[ 3.837271] usb 1-3.2.1: Manufacturer: Burr-Brown from TI
[ 3.845477] input: Burr-Brown from TI USB Audio CODEC as /devices/platform/s5p-ehci/usb1/1-3/1-3.2/1-3.2.1/1-3.2.1:1.3/input/input0
[ 3.859361] hid-generic 0003:08BB:2902.0001: input,hidraw0: USB HID v1.00 Device [Burr-Brown from TI USB Audio CODEC ] on usb-s5p-ehci-3.2.1/input3
[ 4.449792] init: ureadahead main process (1404) terminated with status 5
[ 5.363350] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 5.380751] systemd-udevd[1562]: starting version 204
[ 6.245430] input: gpio-keys as /devices/platform/gpio-keys.0/input/input1
[ 6.330436] s5p-fimc exynos4-fimc.0: state restore latency exceeded, new value 18292 ns
[ 6.331793] s5p-fimc exynos4-fimc.1: start latency exceeded, new value 584 ns
[ 6.331822] s5p-fimc exynos4-fimc.1: state restore latency exceeded, new value 16959 ns
[ 6.331997] s5p-fimc exynos4-fimc.2: state restore latency exceeded, new value 16083 ns
[ 6.332016] s5p-fimc exynos4-fimc.2: start latency exceeded, new value 500 ns
[ 6.332026] s5p-fimc exynos4-fimc.2: state save latency exceeded, new value 3041 ns
[ 6.350900] s5p-mfc s5p-mfc: start latency exceeded, new value 500 ns
[ 6.350915] s5p-mfc s5p-mfc: state restore latency exceeded, new value 2417 ns
[ 6.354272] s5p-fimc exynos4-fimc.3: state restore latency exceeded, new value 19167 ns
[ 6.354306] s5p-fimc exynos4-fimc.3: start latency exceeded, new value 625 ns
[ 6.354317] s5p-fimc exynos4-fimc.3: state save latency exceeded, new value 3583 ns
[ 6.603346] init: plymouth main process (1414) killed by ABRT signal
[ 6.604120] init: plymouth-splash main process (1677) terminated with status 2
[ 6.612216] s5p-mfc s5p-mfc: stop latency exceeded, new value 958 ns
[ 6.612264] s5p-mfc s5p-mfc: state save latency exceeded, new value 2375 ns
[ 6.813582] smsc95xx v1.0.4
[ 6.822005] [smsc95xx_read_mac_addr] Mac address = 1E:F6:D7:BE:00:AD
[ 6.834455] init: plymouth-upstart-bridge main process (1725) terminated with status 1
[ 6.866954] smsc95xx 1-2:1.0 eth0: register 'smsc95xx' at usb-s5p-ehci-2, smsc95xx USB 2.0 Ethernet, 1e:f6:d7:be:00:ad
[ 6.867059] usbcore: registered new interface driver smsc95xx
[ 7.306982] init: avahi-cups-reload main process (1753) terminated with status 1
[ 7.721512] usbcore: registered new interface driver snd-usb-audio
[ 7.843480] init: Failed to spawn smbd main process: unable to execute: No such file or directory
[ 8.280556] Bluetooth: Core ver 2.16
[ 8.280609] NET: Registered protocol family 31
[ 8.280614] Bluetooth: HCI device and connection manager initialized
[ 8.280637] Bluetooth: HCI socket layer initialized
[ 8.280646] Bluetooth: L2CAP socket layer initialized
[ 8.280665] Bluetooth: SCO socket layer initialized
[ 8.348404] Bluetooth: RFCOMM TTY layer initialized
[ 8.348442] Bluetooth: RFCOMM socket layer initialized
[ 8.348448] Bluetooth: RFCOMM ver 1.11
[ 8.425518] NET: Registered protocol family 10
[ 8.427182] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.515395] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.515404] Bluetooth: BNEP filters: protocol multicast
[ 8.515426] Bluetooth: BNEP socket layer initialized
[ 9.759280] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 9.760257] smsc95xx 1-2:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 10.992350] init: failsafe main process (1786) killed by TERM signal
[ 11.245868] init: Failed to spawn nmbd main process: unable to execute: No such file or directory
[ 11.878997] init: zram-config pre-start process (2128) terminated with status 1
[ 12.006593] init: zram-config post-stop process (2255) terminated with status 1
[ 12.849937] Bridge firewalling registered
[ 13.007717] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 13.209533] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 18.714033] init: plymouth-stop pre-start process (2955) terminated with status 1
