Ich hab nun nochmal ein Image neu aufgesetzt. Diesmal 64bit OS Bullseye FULL.
Out of the Box ohne Apt-get update und upgrade libcamera-hello mit dem per Imager angelegten User ausgeführt:
root@raspberrypi:~# libcamera-hello
Preview window unavailable
[0:22:35.584993801] [1837] INFO Camera camera_manager.cpp:299 libcamera v0.0.3+40-9b860a66
[0:22:35.620737477] [1838] WARN CameraSensorProperties camera_sensor_properties.cpp:205 No static properties available for 'imx708_wide'
[0:22:35.620875328] [1838] WARN CameraSensorProperties camera_sensor_properties.cpp:207 Please consider updating the camera sensor properties database
[0:22:35.721591901] [1838] INFO RPI raspberrypi.cpp:1425 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media0 and ISP device /dev/media1
[0:22:35.722486969] [1837] INFO Camera camera.cpp:1028 configuring streams: (0) 2304x1296-YUV420
[0:22:35.722773819] [1838] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
#0 (0.00 fps) exp 32680.00 ag 5.99 dg 1.01
#1 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#2 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#3 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#4 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#5 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#6 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#7 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#8 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#9 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#10 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#11 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#12 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#13 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#14 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#15 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#16 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#17 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#18 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#19 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#20 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#21 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#22 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#23 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#24 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#25 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#26 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#27 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#28 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#29 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#30 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#31 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#32 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#33 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#34 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#35 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#36 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#37 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#38 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#39 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#40 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#41 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#42 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#43 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#44 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#45 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#46 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#47 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#48 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#49 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#50 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#51 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#52 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#53 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#54 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#55 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#56 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#57 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#58 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#59 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#60 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#61 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#62 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#63 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#64 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#65 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#66 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#67 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#68 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#69 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#70 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#71 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#72 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#73 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#74 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#75 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#76 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#77 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#78 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#79 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#80 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#81 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#82 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#83 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#84 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#85 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#86 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#87 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#88 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#89 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#90 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#91 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#92 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#93 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#94 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#95 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#96 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#97 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#98 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#99 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#100 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#101 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#102 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#103 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#104 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#105 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#106 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#107 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#108 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#109 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#110 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#111 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#112 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#113 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#114 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#115 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#116 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#117 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#118 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#119 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#120 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#121 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#122 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#123 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#124 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#125 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#126 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#127 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#128 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#129 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#130 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#131 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#132 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#133 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#134 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#135 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#136 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#137 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#138 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#139 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#140 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
#141 (30.01 fps) exp 32680.00 ag 5.99 dg 1.01
Woran erkenne ich denn, dass die angeschlossene Kamera per se erkannt wird??
