Posts by Momonga
    Fritz.box hat die Firmware: 8.25
    Hardwarebeschleunigung ist aktiv
    Das einzige was per USB angeschlossen ist, ist das Netzteil.
    Alle anderen Verbindungen machen ich per SSH oder Raspery PI Connect.
    Ergebnis Befehl 1:
    net.ipv4.tcp_window_scaling = 1
    net.ipv4.tcp_moderate_rcvbuf = 1
    net.core.default_qdisc = fq_codel
    net.ipv4.tcp_congestion_control = cubic
    Ergebnis Befehl 2:
    Connecting to host speedtest.studiofunk.de, port 5200
    Reverse mode, remote host speedtest.studiofunk.de is sending
    [ 5] local 192.168.178.20 port 48134 connected to 185.209.244.2 port 5200
    [ ID] Interval Transfer Bitrate
    [ 5] 0.00-1.00 sec 7.25 MBytes 60.8 Mbits/sec
    [ 5] 1.00-2.00 sec 7.88 MBytes 66.1 Mbits/sec
    [ 5] 2.00-3.00 sec 7.88 MBytes 66.1 Mbits/sec
    [ 5] 3.00-4.00 sec 8.00 MBytes 67.1 Mbits/sec
    [ 5] 4.00-5.00 sec 7.88 MBytes 66.1 Mbits/sec
    [ 5] 5.00-6.00 sec 7.88 MBytes 66.1 Mbits/sec
    [ 5] 6.00-7.00 sec 8.00 MBytes 67.1 Mbits/sec
    [ 5] 7.00-8.00 sec 7.75 MBytes 65.0 Mbits/sec
    [ 5] 8.00-9.00 sec 6.12 MBytes 51.4 Mbits/sec
    [ 5] 9.00-10.00 sec 7.62 MBytes 64.0 Mbits/sec
    [ ID] Interval Transfer Bitrate Retr
    [ 5] 0.00-10.02 sec 79.0 MBytes 66.1 Mbits/sec 429 sender
    [ 5] 0.00-10.00 sec 76.2 MBytes 64.0 Mbits/sec receiver
    iperf Done.
    Ergebnis nach (sudo ethtool --set-eee eth0 tx-lpi off)
    [ 5] local 192.168.178.20 port 57518 connected to 185.209.244.2 port 5200
    [ 5] 0.00-1.00 sec 6.88 MBytes 57.7 Mbits/sec
    [ 5] 1.00-2.00 sec 8.12 MBytes 68.1 Mbits/sec
    [ 5] 2.00-3.00 sec 8.12 MBytes 68.2 Mbits/sec
    [ 5] 3.00-4.00 sec 8.12 MBytes 68.1 Mbits/sec
    [ 5] 4.00-5.00 sec 8.00 MBytes 67.2 Mbits/sec
    [ 5] 5.00-6.00 sec 8.12 MBytes 68.1 Mbits/sec
    [ 5] 7.00-8.00 sec 8.00 MBytes 67.1 Mbits/sec
    [ 5] 8.00-9.00 sec 7.88 MBytes 66.1 Mbits/sec
    [ 5] 9.00-10.00 sec 8.00 MBytes 67.1 Mbits/sec
    [ 5] 0.00-10.03 sec 80.6 MBytes 67.5 Mbits/sec 49 sender
    [ 5] 0.00-10.00 sec 79.2 MBytes 66.5 Mbits/sec receiver
    iperf Done.
    Hi hyle,
    Also der Pi hat
    im Lan die feste IP 192.168.178.20
    im WLan die 192.168.178.21
    In der Fritzbox ist beim lokalen DNS die 192.168.178.20 eingetragen.
    Der DHCP der Firritzbox geht von 192.168.178.25 bis 192.168.178.200
    Die Grundgeräte (Desktop PCs, NAs Lamptops) haben alle fest eingestellt IPs.
    Wenn ich per Lan und Wirelss Lan verbunden bin und machte ein Ping auf die Lan IP des PI erhalte ich folgendes:
    Ping-Statistik für 192.168.178.20:
    Pakete: Gesendet = 4, Empfangen = 2, Verloren = 2
    (50% Verlust),
    Ca. Zeitangaben in Millisek.:
    Minimum = 1ms, Maximum = 2ms, Mittelwert = 1ms
    mach es es auf die Wireless Lan IP:
    Ping-Statistik für 192.168.178.21:
    Pakete: Gesendet = 4, Empfangen = 3, Verloren = 1
    (25% Verlust),
    Minimum = 4ms, Maximum = 203ms, Mittelwert = 54ms
    stelle ich um auf 100 Mbit erhalte ich beim Ping auf Lan folgendes:
    Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
    (0% Verlust),
    Minimum = 0ms, Maximum = 1ms, Mittelwert = 0ms
    bei Wireless lan seht es dann so aus:
    (0% Verlust),
    Minimum = 5ms, Maximum = 23ms, Mittelwert = 9ms
    Probleme die bei 1Gbit auftretten sind:
    - Seitenanfragen sehr Langsam
    - Darstellungsfehler im Browser auch z.B bei Amazon, Bilder werden nicht mehr angezeigt also nix was eigentlich durch die Blockliste blockiert werden sollte.
    - Webseiten werden teilweise sehr langsam oder nicht richtig geladen ... und ich sprehe hier nicht von Werbung, Es fehlen Teile von Texten. Videos auf Youtube oder Crunchyroll haben Aussetzer, Hängen oder Puffern sehr langsam
    Führe ich auf dem Pi den Befehl ip -s link show eth0 erhalte ich folgndes Ergebnis:
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
    link/ether 88:a2:9e:9a:1f:fe brd ff:ff:ff:ff:ff:ff
    RX: bytes packets errors dropped missed mcast
    555010 6615 38 1714 0 552
    TX: bytes packets errors dropped carrier collsns
    1353385 2141 0 1 0 0
    Selbst wenn ich google.de oder heise an pinge habe ich Verluste:
    Ping wird ausgeführt für google.de [192.178.183.94] mit 32 Bytes Daten:
    Zeitüberschreitung der Anforderung.
    Antwort von 192.178.183.94: Bytes=32 Zeit=14ms TTL=109
    Antwort von 192.178.183.94: Bytes=32 Zeit=13ms TTL=109
    Ping-Statistik für 192.178.183.94:
    (25% Verlust),
    Minimum = 13ms, Maximum = 14ms, Mittelwert = 13ms
    ing wird ausgeführt für heise.de [193.99.144.80] mit 32 Bytes Daten:
    Antwort von 193.99.144.80: Bytes=32 Zeit=15ms TTL=248
    Antwort von 193.99.144.80: Bytes=32 Zeit=14ms TTL=248
    Ping-Statistik für 193.99.144.80:
    (50% Verlust),
    Minimum = 14ms, Maximum = 15ms, Mittelwert = 14ms
    Und ichhabe keine Ahnung in welchen Zusammen das mit dem PI und Adguard Home steht. Ich weiß nur, dass wenn ich den Pi aus dem Netzwerk entferne oder den Lan Port auf 100 Mbit umstelle alles ohne Fehler funktioniert.
    Guten Abend,
    Ich bin seit kurzem Besitzer meines ersten Raspberry Pi 5. (Gb Variante mit ner 512 GB SSD.
    Diesen nutze ich mit Adguard Home in meinem Netzwerk. Der Raspberry Pi ist per LAN und Wireless Lan verbunden.
    Kurz nach der Einrichtung hatte ich seltsame Probleme. Das aufrufen von Webseiten dauerten sehr lange oder Sie waren mit einmal nicht mehr erreichbar.
    Seltsame Fehlermeldung in allen Möglichen Browsern bis hin zu Fehlfunktionen von Alexa. Hängen von Video Streams auf TV usw.
    Entfernte ich den PI als DNS lief alles wieder...
    Also aus unwissenheit, alles neu aufgesetzt da ich das Problem irgendwie nicht festmachen konnte oder dachte ich hab bei den Anleitungen irgenwie mist gebaut.
    Leider tratt das Problem danach wieder auf....
    Also man geschaut was in meinem Netzwerk so ab geht und siehe da, Anfragen verschwanden im Nirvana...
    Also Dauerping auf den PI und siehe an, sporadisch bis zu 40% Verlust und das bei Lan und Wireless Lan....
    Aktuell nutze ich ein Firtzbox 7590 AX + Netgear MS308E + 2 x FRITZ!Repeater 6000 + Repeater 1200 AX in meinem Haus.
    Da hängt alles dran was WLAN und LAN hat ... ca.: 30 Geräte inkl. NAS usw.
    Sowie ich den Raspberry Pi mit Adguard Home als DNS einbinde, fangen jedoch Probleme bei allen Geräten an.
    Also versucht das Problem ein zu grenzen und naja, nach etwas experimentieren Problem gefunden aber erklären kann ich es mir nicht.
    Daher suche ich hier mal nach Hilfe.
    Was habe ich bis jetzt rausgefunden:
    - IP V6 deaktivieren brachte keine Lösung
    - Manuelle IP Vergabe bracht auch nix
    Den PI nur per Wireless Lan einbinden - Problem gelöst, keine DNS Probleme oder packet verluste aber grottige Geschwindigkeit.
    Sowie ich den PI nur per Lan oder Lan und WLan verbinde fangen die Probleme wieder an. (Hierbei ist es egal ob der PI am LAN der Firtzbox oder am Netgear MS308E hängt.)
    Also weiter gesucht und folgendes konnte ich dabei feststellen. Drossle ichmanuell bei der Fritzbox oder dem Netgear MS308E den Port wo der PI dran hängt auf 100 Mbit funktioniert alles ohne Fehler.
    Egal ob nur LAN oder LAN und WLan. Es gibt dann kein Ping verluste mehr, keine DNS Probleme... Geschwiindigkeit ist supper.
    Sowie er aber an einen 1 Gbit Port hängt ist es vorbei und die probleme beginnen von vorn.
    Leider konnte ich nix so richtig passendes hierzu finden. Da meine Englisch kenntnisse zu wünschen überig lassen, dachte ich dass ich hier mal um Hilfe frage.
    Ist euch so etwas schon untergekommen? Mache ich einen Fehler?
    Vielleicht habt Ihr ja ein Paar Tips für mich.
