Posts by cmeckler
    Also biniou sieht vielversprechend aus
    sudo apt-get install lebiniou
    lebiniou -i random
    ich musste dem raspberry mehr ram geben
    sudo nano /etc/dphys-swapfile
    sudo service dphys-swapfile stop
    sudo service dphys-swapfile start
    ProjectM startet nicht
    sudo apt-get install libvisual-projectm projectm-pulseaudio
    sudo apt-get install fonts-dejavu fonts-dejavu-core
    projectM-pulseaudio
    connection failure Verbindung verweigert
    evtl. geht es so
    https://github.com/projectM-visualizer/projectm/issues/115
    Hallo bin gerade dabei auf meinen RPI2 einen PI-Hole server aufzusetzen,
    jedoch bricht die Installation ohne Meldung ab.
    Vermutlich ist das Packet dns-root-date der grund.
    Leider kann ich es nicht von Hand installieren
    apt-cache search dns-root-data
    zeigt nichts an
    das Packet sollte in Main jedoch vorhanden sein,
    http://archive.raspbian.org/raspbian/pool/…/dns-root-data/
    /etc/apt/sources.list
    deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
    deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free
    apt-get update
    Holen: 1 http://archive.raspbian.org wheezy Release.gpg [473 B]
    Holen: 2 http://archive.raspbian.org wheezy Release [14,4 kB]
    Holen: 3 http://archive.raspbian.org wheezy/main Sources [6.097 kB]
    Holen: 4 http://archive.raspbian.org wheezy/contrib Sources [53,2 kB]
    Holen: 5 http://archive.raspbian.org wheezy/non-free Sources [98,4 kB]
    Holen: 6 http://archive.raspbian.org wheezy/main armhf Packages [7.680 kB]
    Holen: 7 http://archive.raspbian.org wheezy/contrib armhf Packages [35,0 kB]
    Holen: 8 http://archive.raspbian.org wheezy/non-free armhf Packages [73,6 kB]
    Ign http://archive.raspbian.org wheezy/contrib Translation-de_DE
    Ign http://archive.raspbian.org wheezy/contrib Translation-en
    Ign http://archive.raspbian.org wheezy/main Translation-de_DE
    Ign http://archive.raspbian.org wheezy/main Translation-en
    Ign http://archive.raspbian.org wheezy/non-free Translation-de_DE
    Ign http://archive.raspbian.org wheezy/non-free Translation-en
    Es wurden 14,1 MB in 1 min 52 s geholt (125 kB/s).
    apt-get install dns-root-data
    E: Paket dns-root-data kann nicht gefunden werden.
    warum wird mir das Packet nicht angezeigt?
    wie bekomme ich es installiert?
    Display geht nicht, Hintergrundbeleuchtung ist immer an.
    schein Konsoletechnisch alles zu gehen.
    ich tippe auf einen ESD SCHADEN
    [ 11.102508] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
    [ 11.203115] spi-bcm2835 20204000.spi: chipselect 1 already in use
    [ 11.203157] spi_master spi0: spi_device register error /soc/spi@7e204000/waveshare35a-ts@1
    [ 11.203185] spi_master spi0: Failed to create SPI device for /soc/spi@7e204000/waveshare35a-ts@1
    [ 16.749378] ads7846 spi0.1: touchscreen, irq 177
    [ 16.758207] input: ADS7846 Touchscreen as /devices/platform/soc/http://20204000.spi/spi_master/spi0/spi0.1/input/input0
    [ 16.912713] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
    [ 17.030924] fb_ili9486: module is from the staging directory, the quality is unknown, you have been warned.
    [ 17.036564] pinctrl-bcm2835 20200000.gpio: pin gpio17 already requested by spi0.1; cannot claim for spi0.0
    [ 17.036607] pinctrl-bcm2835 20200000.gpio: pin-17 (spi0.0) status -22
    [ 17.036631] pinctrl-bcm2835 20200000.gpio: could not request pin 17 (gpio17) from group gpio17 on device pinctrl-bcm2835
    [ 17.036650] fb_ili9486 spi0.0: Error applying setting, reverse things back
    [ 19.187818] graphics fb1: fb_ili9486 frame buffer, 480x320, 300 KiB video memory, 32 KiB DMA buffer memory, fps=33, spi0.0 at 15 MHz
    config.txt
    dtoverlay=ads7846,cs=1,penirq=17,penirq_pull=2,speed=1000000,keep_vref_on=1,swapxy=1,pmax=255,xohms=60,xmin=200,xmax=3900,ymin=200,ymax=3900
    pi@raspberrypi:~ $ cat /boot/cmdline.txt
    dwc_otg.lpm_enable=0 console=tty1 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:ProFont6x11 logo.nologo
    pi@raspberrypi:/boot $ cat /proc/interrupts
    CPU0
    17: 17 ARMCTRL-level 1 Edge 2000b880.mailbox
    18: 805 ARMCTRL-level 2 Edge VCHIQ doorbell
    27: 13841 ARMCTRL-level 35 Edge timer
    33: 1 ARMCTRL-level 41 Edge
    40: 0 ARMCTRL-level 48 Edge bcm2708_fb dma
    42: 3952 ARMCTRL-level 50 Edge DMA IRQ
    44: 1109 ARMCTRL-level 52 Edge DMA IRQ
    45: 1109 ARMCTRL-level 53 Edge DMA IRQ
    56: 626852 ARMCTRL-level 64 Edge dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
    73: 0 ARMCTRL-level 81 Edge 20200000.gpio:bank0
    74: 0 ARMCTRL-level 82 Edge 20200000.gpio:bank1
    77: 0 ARMCTRL-level 85 Edge 20205000.i2c
    78: 0 ARMCTRL-level 86 Edge 20204000.spi
    80: 409 ARMCTRL-level 88 Edge mmc0
    81: 606 ARMCTRL-level 89 Edge uart-pl011
    177: 0 pinctrl-bcm2835 17 Edge ads7846
    FIQ: usb_fiq
    Auf dieser Website sind ähnliche zustände beschrieben, jedoch funktioniert da scheinbar trozdem das Display...
    https://github.com/Fourdee/DietPi/issues/439
    also wird das Display angesprochen oder sehe ich es nur nicht?
    nach Deiner ausführlichen Beschreibung, was Du genau gemacht hast, ist leider die Glaskugel beschlagen. Interessant wären so Sachen wie System, Updates, Treiber usw. Gelle?
    Gruß, STF
    1.schritt
    Orginal Image für das Display welches mit dieser Hardware bereits funktioniert hat.
    geht nach einer gewissen zeit nicht mehr:
    Fehlermeldung vermutlich:
    [font="monospace"][ 9.239089] pinctrl-bcm2835 20200000.gpio: pin-1 (20205000.i2c) status -22[/font]
    [font="monospace"][ 9.401286] pinctrl-bcm2835 20200000.gpio: could not request pin 1 (gpio1) from group gpio1 on device pinctrl-bcm2835[/font]
    [font="monospace"][ 9.579303] bcm2708_i2c 20205000.i2c: Error applying setting, reverse things back[/font]
    [font="monospace"][ 9.671537] bcm2708_i2c 20205000.i2c: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100000)[/font]
    2.schritt
    neues Image für das Display aufgespielt.
    Display keine Funktion, kein SSH Zugriff möglich.
    Treiber nach Anleitung Installiert
    3. Schritt
    aktuelles Raspi Image aufgespielt
    Fehlermeldung:
    [font="monospace"][ 10.496678] spi-bcm2835 20204000.spi: chipselect 1 already in use[/font]
    [font="monospace"][ 10.496725] spi_master spi0: spi_device register error /soc/spi@7e204000/waveshare35a-ts@1[/font]
    [font="monospace"][ 10.496759] spi_master spi0: Failed to create SPI device for /soc/spi@7e204000/waveshare35a-ts@1[/font]
    Was ich gemacht hat?
    Eigentlich nur Image aufgespielt und Treiber geladen und rpi-update.
    Hab auch einmal versucht ein Bild auf fb1 anzuzeigen, welches nicht dargestellt worden ist.
    [font="monospace"]Gruß[/font]
    [font="monospace"]chris[/font]
    [font="monospace"]
    pi@raspberrypi:~ $ cat /proc/cpuinfo | grep Revision[/font][/size][/color]Revision        : 0002pi@raspberrypi:~ $ cat /etc/os-releasePRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"NAME="Raspbian GNU/Linux"VERSION_ID="8"VERSION="8 (jessie)"ID=raspbianID_LIKE=debianHOME_URL="http://www.raspbian.org/"SUPPORT_URL="http://www.raspbian.org/RaspbianForums"BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"pi@raspberrypi:~ $ cat /etc/issueRaspbian GNU/Linux 8 \n \lpi@raspberrypi:~ $ uname -aLinux raspberrypi 4.4.32+ #924 Tue Nov 15 18:06:42 GMT 2016 armv6l GNU/Linuxpi@raspberrypi:~ $ hostnamectl   Static hostname: raspberrypi         Icon name: computer           Chassis: n/a        Machine ID: fe1d4a4d0ac7441e817d011e70da2471           Boot ID: ade21bab1450446ba8270e178d320117  Operating System: Raspbian GNU/Linux 8 (jessie)            Kernel: Linux 4.4.32+      Architecture: arm[color=#333333][size=10][font="monospace"]
    Display geht mit Raspy image nicht!
    also das Display wurde im getestet und in die Ecke gestellt als es noch lief. Seit dem nicht mehr angerührt. paar monate schon her.
    nun geht es nicht mehr obwohl nichts verändert worden ist.
    dann
    RPI-Firmware aktualisiert, hat nichts gebracht
    aktuelle ISO runtergeladen und installiert
    -> geht auch nicht
    Kann mich leider über SSH nicht anmelden da ich die kennwoerter nicht kenne
    pi und raspberry klappt auf jedenfall nicht. zum glück gibts autologin an der konsole
    kann das daran liegen das ich von USB boote? hatte nämlich keine Passende SD Karte da.
    werde morgen mal Raspian installieren und da schauen ob es läuft
    hab mir vor einiger Zeit das Display gekauft und erfolgreich getestestet.
    IMAGE ist LCD35-150602
    Also ich Image neu aufgespielt doch das Display geht nicht mehr.
    bei HDMI bekommt er einen freez nach "[font="monospace, monospace"]fbtft_register_backlight(): led pin not set, exiting[/font]"
    Werde morgen noch neues Image vom Hersteller ausprobieren http://www.waveshare.com/wiki/3.5inch_RPi_LCD_(A)
    aber ich verstehe nicht warum das plötzlich nicht mehr geht obwohl vorher alles topp war.
    firmware ist aktualisiert, bring auch nichts.
    Bitte um hilfestellung was ich alles durchprobieren darf
    gruß
    chris
    ich will meinen Raspberry zu Freunden mitnehmen und die Filme von zuhause schauen.
    Hab außreichend Upload, was bei kleineren Filmen kein Problem sein sollte.
    soll ich besser den VPN Zugang der Fritzbox nutzen oder die von der Synology DiskStation?
    Synology kann
    pptp
    openvpn
    l2tp/ipsec
    habe mein System neu aufsetzen müssen, diesmal habe ich den rasbian netinstaller verwendet.
    Bei diesem Minimal system habe ich schon etliches nachinstallierenen müssen.
    Nun läuft das System, jedoch der WLAN stick nicht.
    lsusb liefert:
    Atheros Communications, Inc. AR9271 802.11n
    dmesg liefert:
    lsmod liefert
    beim letzten mal hab ich nur apt-get install firmaware-Atheros ausgeführt und los gings.
    was mach ich falsch?
    Jep so muss dat sein. Also ohne kentniss Der Windows netzwerkeinstellungen und derer von Linux kommst du nicht weiter.
    Ich fuer meinen fall setzt in diesen fall gerne einen dhcp server auf. Ob auf win auf Linux ist da ziehmlich egal.
